I plan to use maas to deploy to 100 machines. Each server has the same CPU, the same disk size and number;
The server needs to use the same disk partition to deploy centos7
Partition:
/boot/ 1G
/ 100G
/data all
I now have to create disk partitions one by one. Then deploy. This efficiency is too low.
Is there any quick way? , For example, save disk partitions as templates and apply them to all machines in batches.
@billwear, I don’t think those templates you linked are for storage and as far as I can tell there is still no way to customize the existing storage templates/layouts (which aren’t suitable in most cases).
