I’m fedup composing machines “by hand” using the MaaS UI because it is way too slow when you want to compose 10 VMs with exactly the same specs.
I know Juju can dynamically create machines based on constraints but doing this way, you can’t have finer indepth regarding network or machines specs.
So I tried with the MaaS CLI and ended up with something like this :
maas <PROFILE> vm-host compose <VM_HOST_ID> \
cores=4 memory=16384 \
storage=mylabel:50(default) \
interfaces=ens4:space=SPACE-PXE \
hostname=<VM_NAME>
This works well when creating a 4 vCPUs/16GB RAM/50GB disk and 1 interface plugged on the provisionning network.
But now, I’d like to add a few vlans on this interface.
I can do it very easily through the MaaS UI but I didn’t find a way to do it the CLI way.
Can somebody help me on this ?
Best regards.
