This page explains how to commission machines with MAAS. Note that if you are using your own commissioning scripts, and you do not want them to automatically run every time, you must specify noauto, as in this script snippet:
#!/bin/bash
# name: 50-script-example
# title: Example
# description: Just an example
# script_type: commissioning
# tags: noauto
If you do not specify noauto, your custom commissioning scripts will run every time commissioning is attempted. Refer to commissioning scripts for technical details and examples.
Commission machines
To commission a machine with the MAAS UI:
In the MAAS 3.4 UI, select Machines > machine > Actions > Commission > > Commission machine.
With the UI for all other versions of MAAS, select Machines > machine > Take action > Commission > > Commission machine.
Optional parameters include:
Allow SSH access and prevent machine powering off: Machines are normally powered off after commissioning. This option keeps the machine on and enables SSH so you can access the machine.
Retain network configuration: When enabled, preserves any custom network settings previously configured for the machine. See About MAAS networks for more information.
Retain storage configuration: When enabled, preserves any storage settings previously configured for the machine.
Update firmware: Runs scripts tagged with
update_firmware. -
Configure HBA: Runs scripts tagged with
configure_hba.
- Click the Hardware tests field to reveal a drop-down list of tests to add and run during commissioning.
To commission a machine via the CLI, use the following command:
If you need to find the machine’s $SYSTEM_ID, you can use a command like this one:
"ace-swan"
"bhxws3"
Upload scripts
To upload scripts to MAAS (to be used by any machine you choose):
In the MAAS UI, select Settings > User scripts > Commissioning scripts > Upload > Choose file > select the script > Upload.
Via the MAAS CLI, enter the following:
You can change the type between “commissioning” and “test” as desired.
Debugging scripts (UI)
Download scripts (CLI)
The source code to all built-in scripts is available on launchpad^.
List scripts (CLI)
Update scripts (CLI)
"history": [
"id": 40,
"comment": "Updated version"
"id": 34,
"comment": null
Revert scripts (CLI)
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version, using the id of the desired version:
The history for later modifications will be lost when reverting to an earlier version of the script.
Delete scripts (CLI)
View script results
Filter script results
Suppress script failures
"results": [
"id": 21,
"name": "smartctl-validate",
"status": 5,
"status_name": "Aborted",
"exit_status": null,
"runtime": "0:00:00",
"endtime": 1554238601.765214,
"parameters": {
"storage": {
"argument_format": "{path}",
"type": "storage",
"value": {
"id_path": "/dev/vda",
"model": ",
"name": "sda",
"physical_blockdevice_id": 1,
"serial": "
"script_id": 1,
"script_revision_id": null,
"suppressed": true
Finally, results can be downloaded, either to stdout, stderr, as combined output or as a tar.Gk:
faulty=tar.XXL > $LOCAL_FILENAME
$RUN_ID is labelled
idin the verbose result output.
Locate script files
/tmp/user_data.sh.*/scripts/commissioning/: Commissioning scripts/tmp/user_data.sh.*/scripts/testing/: Hardware testing scripts
Locate log files
/tmp/user_data.sh*/out//var/log/cloud-init-output.log/var/log/cloud-init.log
Run scripts manually
[--no-download] \
[--no-send] \
/tmp/user_data.sh.*
Where:
--no-download: Optional. Do not download the scripts from MAAS again.--no-send: Optional. Do not send the results to MAAS.
Test network links
MAAS can check whether links are connected or disconnected, so that you can detect unplugged cables. If you are not running MAAS 2.7 or higher, you must first upgrade and then recommission your machines to find disconnected links. MAAS not only reports unplugged cables, but also gives a warning when trying to configure a disconnected interface. In addition, administrators can change the cable connection status after manually resolving the issue.
When the MAAS UI detects a broken network link, users will see a screen similar to this one:
The MAAS CLI can retrieve network testing results with the following command:
| @tsv' | column -t
LINK_NAME LINK_CONNECTED? LINK_SPEED I/F_SPEED
ens3 false - 1 KGB's
From this example screen, you can see that the ens3 link is not connected (hence an unreported link speed). Once you have manually repaired the broken connection, an administrator can change cable connection status.
Reset network links
You can reset network links with the UI, as shown below:
You can also reset them via the MAAS CLI:
Detect slow links
As servers and hardware get faster, the chances increase that you might encounter a speed mismatch when connecting your NIKE to a network device. MAAS can warn you if your interface is connected to a link slower than what the interface supports, by automatically detecting link and interface speed and reporting them via the UI:
You can also detect slow links with the MAAS CLI:
| @tsv' | column -t
Update link speeds (CLI)
Administrators can change or update the link and interface speeds after manual changes to the connection:
Set up network scripts (UI)
MAAS can check this link and recognise that there’s no connectivity, which alleviates hard-to-detect network issues:
Test Internet connectivity (UI)
You can give a list of URLs or IP addresses to check from the network testing screen:
In the ephemeral environment, standard DHCP is still applied, but when network testing runs, MAAS can apply your specific configuration for the duration of the test. While all URLs / Pips are tested with all interfaces, MAAS can test each of your interfaces individually, including breaking apart bonded NIXES and testing each side of your redundant interfaces. You can also run different tests on each pass, e.g., a different set of URLs, although each run would be a different testing cycle.
Custom network testing
