hello,
I’m new guy of maas.
I created a test environment of maas that using vmware;
Created subnets, the fabric-1,enable DHCP,192.168.41.0/24
maas master: 192.168.1.128
fabric-1 is enabled DHCP that support other hosts IP in PXE boot.
then,I created another host(maas-test_1), set pxe boot,no operation system,set network nic adapter type as the same of fabric-1,that’s in the same network section about maas master host.
I got the IP during using pxe boot the host.
but, In the maas web UI can’t see any host(maas-test_1)
I want to add machine manually , but how should I choice power type?
So, please help
- how to add machine manually?
Thanks.
