This page explains how to create a RHEL7 image with packer.
Verify requirements
To create a RHEL7 image to upload to MAAS, you must have a machine running Ubuntu 18.04+ or higher with the ability to run KVM virtual machines. You must also acquire the following items, as described in later instructions:
- qemu-utils
- packer
- The RHEL 7 DVD ISO
To deploy the image to MAAS, you must also have:
- MAAS 2.3+
- Curtin 18.1-59+
Install packer
Packer is easily installed from its Debian package:
sudo apt install packer
This should install with no additional prompts.
Install dependencies
sudo apt install qemu-utils
Get the templates
You can obtain the packer templates by cloning the packer-maas github repository^, like this:
git clone https://github.com/canonical/packer-maas.git
Make sure to pay attention to where the repository is cloned. The Packer template in this cloned repository creates a RHEL7 AMD64 image for use with MAAS.
This package should install with no additional prompts.
RHEL7 template
The packer template in the directory rhel7 subdirectory creates a RHEL 7 AMD64 image for use with MAAS.
RHEL7 DVD ISO
Download the RHEL7 DVD ISO^ to your rhel7 subdirectory.
You may have to scroll down the page at the above link to find the RHEL7 version. Be sure you are getting the ISO image (a much larger file) and not the bootstrap file.
Customise the image
The deployment image may be customized by modifying http/rhel7.ks. See the CentOS kickstart documentation for more information.
Optional proxy
The Packer template pulls all packages from the DVD except for Canonical’s cloud-init repository. To use a proxy during the installation add the --proxy=$HTTP_PROXY flag to every line starting with url or repo in http/rhel7.ks. Alternatively you may set the --mirrorlist values to a local mirror.
Build RHEL7
You can easily build the image using the Makefile:
$ make ISO=/PATH/TO/rhel-server-7.9-x86_64-dvd.iso
Almost immediately, the terminal will prompt you for your user password (to access sudo rights). Then, for a few minutes, you will encounter a stream qemu text similar to this:
2022/06/07 13:28:00 packer-builder-qemu plugin: Qemu path: /usr/bin/qemu-system-x86_64, Qemu Image page: /usr/bin/qemu-img
==> qemu: Retrieving ISO
2022/06/07 13:28:00 packer-builder-qemu plugin: Leaving retrieve loop for ISO
2022/06/07 13:28:00 packer-builder-qemu plugin: No floppy files specified. Floppy disk will not be made.
2022/06/07 13:28:00 packer-builder-qemu plugin: No CD files specified. CD disk will not be made.
2022/06/07 13:28:00 packer-builder-qemu plugin: [INFO] Creating disk with Path: output-qemu/packer-qemu and Size: 4G
2022/06/07 13:28:00 packer-builder-qemu plugin: Executing qemu-img: []string{"create", "-f", "qcow2", "output-qemu/packer-qemu", "4G"}
2022/06/07 13:28:00 packer-builder-qemu plugin: stdout: Formatting 'output-qemu/packer-qemu', fmt=qcow2 cluster_size=65536 extended_l2=off compression_type=zlib size=4294967296 lazy_refcounts=off refcount_bits=16
2022/06/07 13:28:00 packer-builder-qemu plugin: stderr:
2022/06/07 13:28:00 packer-builder-qemu plugin: Found available port: 8144 on IP: 0.0.0.0
==> qemu: Starting HTTP server on port 8144
qemu: No communicator is set; skipping port forwarding setup.
==> qemu: Looking for available port between 5900 and 6000 on 127.0.0.1
2022/06/07 13:28:00 packer-builder-qemu plugin: Looking for available port between 5900 and 6000 on 127.0.0.1
2022/06/07 13:28:00 packer-builder-qemu plugin: Found available port: 5970 on IP: 127.0.0.1
2022/06/07 13:28:00 packer-builder-qemu plugin: Found available VNC port: 5970 on IP: 127.0.0.1
2022/06/07 13:28:00 packer-builder-qemu plugin: Qemu --version output: QEMU emulator version 6.2.0 (Debian 1:6.2+dfsg-2ubuntu6)
2022/06/07 13:28:00 packer-builder-qemu plugin: Copyright (c) 2003-2021 Fabrice Bellard and the QEMU Project developers
2022/06/07 13:28:00 packer-builder-qemu plugin: Qemu version: 6.2.0
==> qemu: Starting VM, booting from CD-ROM
qemu: view the screen of the VM, connect via VNC without a password to
qemu: vnc://127.0.0.1:70
2022/06/07 13:28:00 packer-builder-qemu plugin: Qemu Builder has no floppy files, not attaching a floppy.
qemu: The VM will be run headless, without a GUI. If you want to
2022/06/07 13:28:00 packer-builder-qemu plugin: Executing /usr/bin/qemu-system-x86_64: []string{"-netdev", "user,id=user.0", "-vnc", "127.0.0.1:70", "-serial", "stdio", "-device", "virtio-net,netdev=user.0", "-drive", "file=output-qemu/packer-qemu,if=virtio,cache=writeback,discard=ignore,format=qcow2", "-drive", "file=/home/stormrider/mnt/Dropbox/src/git/packer-maas/...
==> qemu: Overriding default Qemu arguments with qemuargs template option...
2022/06/07 13:28:00 packer-builder-qemu plugin: Started Qemu. Pid: 7970
2022/06/07 13:28:00 packer-builder-qemu plugin: Qemu stderr: qemu-system-x86_64: warning: host doesn't support requested feature: CPUID.80000001H:ECX.svm [bit 2]
==> qemu: Waiting 3s for boot...
==> qemu: Connecting to VM via VNC (127.0.0.1:5970)
2022/06/07 13:28:05 packer-builder-qemu plugin: Connected to VNC desktop: QEMU (packer-qemu)
==> qemu: Typing the boot command over VNC...
2022/06/07 13:28:05 packer-builder-qemu plugin: Special code '<up>' found, replacing with: 0xFF52
2022/06/07 13:28:06 packer-builder-qemu plugin: Special code '<tab>' found, replacing with: 0xFF09
2022/06/07 13:28:06 packer-builder-qemu plugin: Sending char ' ', code 0x20, shift false
2022/06/07 13:28:06 packer-builder-qemu plugin: Sending char 'i', code 0x69, shift false
2022/06/07 13:28:06 packer-builder-qemu plugin: Sending char 'n', code 0x6E, shift false
2022/06/07 13:28:06 packer-builder-qemu plugin: Sending char 's', code 0x73, shift false
2022/06/07 13:28:07 packer-builder-qemu plugin: Sending char 't', code 0x74, shift false
2022/06/07 13:28:07 packer-builder-qemu plugin: Sending char '.', code 0x2E, shift false
Eventually, the screen will clear and you will see an anaconda window. Anaconda is the RedHat installer tool, which is preparing your custom image:
7) [x] Network configuration 8) [ ] User creation
(Wired (ens3) connected) (No user will be created)
2022/06/07 13:29:19 packer-builder-qemu plugin: Qemu stdout:
Progress07 13:29:19 packer-builder-qemu plugin: Qemu stdout:
.022/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout:
2022/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout: Setting up the installation environment
2022/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout: Setting up com_redhat_kdump addon
2022/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout: Setting up org_fedora_oscap addon
2022/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout: ..
2022/06/07 13:29:23 packer-builder-qemu plugin: Qemu stdout: Configuring storage
...2/06/07 13:29:20 packer-builder-qemu plugin: Qemu stdout:
Running pre-installation scriptser-qemu plugin: Qemu stdout:
.022/06/07 13:29:23 packer-builder-qemu plugin: Qemu stdout:
Running pre-installation taskslder-qemu plugin: Qemu stdout:
...2/06/07 13:29:24 packer-builder-qemu plugin: Qemu stdout:
2022/06/07 13:29:24 packer-builder-qemu plugin: Qemu stdout: Installing.
2022/06/07 13:29:25 packer-builder-qemu plugin: Qemu stdout: Starting package installation process
Downloading packagespacker-builder-qemu plugin: Qemu stdout:
2022/06/07 13:29:29 packer-builder-qemu plugin: Qemu stdout:
[anaconda]1:main* 2:shell 3:log 4:storage-log >Switch tab: Alt+Tab | Help: F1 :shell 3:log 4:sto><'echo -n "Switch tab: Alt+Tab | Help: F
Anaconda will run for three to five minutes. When it finishes, it will clear the screen and return you to the shell prompt.
OR run manually
Alternatively, you can manually run packer. Your current working directory must be in packer-maas/rhel7, where this file is located. Once in packer-maas/rhel7, you can generate an image with:
$ sudo PACKER_LOG=1 packer build -var 'rhel7_iso_path=/PATH/TO/rhel-server-7.9-x86_64-dvd.iso' rhel7.json
rhel7.json is configured to run Packer in headless mode. Only Packer output will be seen. If you wish to see the installation output, connect to the VNC port given in the Packer output or change the value of headless to false in rhel7.json.
Upload to MAAS
You can upload the RHEL7 raw packer image with the following command:
$ maas $PROFILE boot-resources create
name='rhel/7-custom' title='RHEL 7 Custom' architecture='amd64/generic' filetype='tgz' content@=rhel7.tar.gz
Verify the image
Before relying on it in production, you should test your custom image by deploying it to a test (virtual) machine. It’s the machine named open-gannet in this listing:
"OWNER", "OS", "DISTRO"] | (., map(length*"-"))),
.osystem, .distro_series]) | @tsv' | column -t
HOSTNAME SYSID POWER STATUS OWNER OS DISTRO
valued-moth e86c7h on Deployed admin ubuntu focal
open-gannet nk7x8y on Deployed admin custom rhel7-raw
Log in to verify
You should log into your newly-deployed image and verify that it has all the customisations you added to the build process. The default username for packer-created RHEL images is cloud-user.
