How to address unit test failures in merge proposal?
I’ve submitted a merge proposal here:
Merge into master : default_boot_interface_link_type : lp:~andrew-boatrocker/maas : Git : Code : MAAS (launchpad.net)
I see that it has unit test failures. However, the link to the log for the unit tests goes to an internal MAAS address that I can’t reach.
When I try running “make test” in my own repository, it takes a couple of days to run and reports 174 failures. I’m pretty sure those aren’t the result of the ~15 lines of code I submitted (which work when deployed).
How should I resolve those failures so that the merge proposal can move forward?
Thanks.
Hey,
I’m following up on the MP
