Can I get MAAS to deploy 20.04.1 instead of 20.04.1? I need to test that particular version.
MAAS image configuration shows only the base versions such as 20.04, 21.04 but not the subversions. When I deploy 20.04, the deployed node showed 20.04.2 in response to the command:
ubuntu@newvm:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
Thanks,
Ram
