Hello. I tried adapting this for a cheap GPU (GTX 1650):
Unfortunately what I tried did not work and my commission is hanging after it applies the tag:
dw@maas-effect:~/src/homelab/maas_tags$ cat gtx1650_tag.sh
#!/bin/bash
maas dw tags create name=gtx-1650 \
comment="Enable passthrough for gtx1650 GPUs
on Intel" \
definition='
//node[@id="cpu:0"]/capabilities/capability/@id = "vmx"
and //node[@id="display"]/vendor[contains(.,"NVIDIA")]
and //node[@id="display"]/description[contains(.,"VGA")]
and //node[@id="display"]/product[contains(.,"NVIDIA")]' \
kernel_opts="console=tty0 console=ttyS0,115200n8r nomodeset
modprobe.blacklist=nouveau,nvidiafb,snd_hda_intel
nouveau.blacklist=1 nouveau.blacklist=1
nouveau.blacklist=1 video=vesafb:off,efifb:off
intel_iommu=on rd.driver.pre=pci-stub
rd.driver.pre=vfio-pci pci-stub.ids=10de:1f82
vfio-pci.ids=10de:1f82
vfio_iommu_type1.allow_unsafe_interrupts=1
vfio-pci.disable_vga=1"
How can I modify the above to successfully make it work for a gtx1650 instead of a Tesla v100? I have determined that the above tag does prevent MAAS from commissioning my machines. Something is wrong with the kernel_opts I can see. But what?
Thanks!
