is there a way to enlarge columns width ? Or to configure it.
On a 4k display there are tons of wasted space and can’t barely read fabric column for example, or tags columns when there are multiple tags.
Maybe even hide and unhide columns would be great for smaller resolution.
BR
Francesco
Hi @phrancesco,
Thank you for your feedback! We’re currently prototyping a new version of MAAS where you should be able to customise the columns such as show/hide. Unfortunately, that won’t be available in the upcoming release yet. Here is what we’ve been investigating MAAS UI: Improving the performance of MAAS UI on the UI side. Hopefully, you won’t have to wait to long
Thanks @amylily, It would be even great to use the whole screen resolution in case it’s available…
Some like preferences#behavior in gitlab, where Layout Width:
“Choose between fixed (max. 1280px) and fluid (100%) application layout.”
save my days…
Thanks
BR
Francesco
@phrancesco Would you mind sharing a screenshot of what you meant so we can look into it?
here’s a couple of pic, gitlab fluid layout vs MAAS
BR
Francesco
