NOTE: I don’t use UEFI, neither GPT.
Literally all my production-ready physical Machines have RAID1 for its root file system, in a layout that it’s for sure, the simplest possible.
Also, MOST IMPORTANT, both devices are bootable! If /dev/sda dies, I can easily boot into /dev/sdb by just removing /dev/sda and that’s it.
With MaaS, this looks “impossible” to do, I’ll try to exemplify here…
What I do manually (1), what I do via MaaS (2) and what I’m getting out of it (3)? As follows:
1- When I manually install Ubuntu 18.04 or Debian 9 in a machine with 2 identical storage devices, here is the end result:
root@server-1:~# sfdisk -l /dev/sda
Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x4ffe919d
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 468860927 468858880 223.6G fd Linux raid autodetect
root@server-1:~# sfdisk -l /dev/sdb
Disk /dev/sdb: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Disklabel type: dos
Disk identifier: 0x05877edb
/dev/sdb1 2048 468862127 468860080 223.6G fd Linux raid autodetect
See how simple it’s? Two SSDs, 1 primary parition on each and NOTHING more.
Now, the Linux RAID1:
root@server-1:~# cat /proc/mdstat
Personalities : [raid1] [linear] [multipath] [raid0] [raid6] [raid5] [raid4] [raid10]
md0 : active raid1 sda1[0] sdb1[2]
234297344 blocks super 1.2 [2/2] [UU]
bitmap: 2/2 pages [8KB], 65536KB chunk
unused devices: <none>
And the root file system:
root@server-1:~# mount | grep md0
/dev/md0 on / type ext4 (rw,relatime,errors=remount-ro)
NOTE: The /boot
is inside of the RAID1 array, Grub works just fine. The only detail, that I can see during Ubuntu/Debian install, is that the installation process is smart enough to install Grub on both /dev/sda
and on /dev/sdb
, but, just to make sure, I run after first boot:
grub-install --recheck /dev/sda
grub-install --recheck /dev/sdb
So far, so good!
Now, when I tried to create the SAME SETUP as above, using MaaS, it fails to do it! The interface MaaS UI even shows layout X but, the deployed result is different!!!
2- What I’m doing via MaaS:
Screenshot:
First problem:
MaaS is using MBR for /dev/sda
and GPT for /dev/sdb
, only God knows why… lol
Second problem, MaaS is a liar ! There is another partition there, created by MaaS, that doesn’t show up on UI!
Third problem, the partition type isn’t RAID Autodetect.
Let me show:
root@maas-deployed-server-1:~# sfdisk -l /dev/sda
Disklabel type: dos
Disk identifier: 0x0a13ea3c
/dev/sda1 2048 468846591 468844544 223.6G 83 Linux
root@maas-deployed-server-1:~# sfdisk -l /dev/sdb
Disklabel type: gpt
Disk identifier: 2B89AF6F-5348-4E6F-B6A7-0165F4503EF8
Device Start End Sectors Size Type
/dev/sdb1 2048 4095 2048 1M BIOS boot
/dev/sdb2 4096 468848639 468844544 223.6G Linux filesystem
I wasn’t expecting MaaS to create /dev/sdb1 with “BIOS boot” and this partition doesn’t show up on MaaS UI!
Two identical disks, asked for RAID1 but, MaaS failed to deliver what I asked.
root@maas-deployed-server-1:~# cat /proc/mdstat
md0 : active raid1 sdb2[1] sda1[0]
234290176 blocks super 1.2 [2/2] [UU]
bitmap: 1/2 pages [4KB], 65536KB chunk
MaaS is using /dev/sda1
and /dev/sdb2
So, bottom line is: How to fix this?
I’m starting to look for custom partitioning, like:
http://caribou.kamikamamak.com/2015/06/26/custom-partitioning-with-maas-and-curtin-2/
But I would rather choose something simpler, like I do with manual setup. I think that I can translate the Ubuntu/Debian manual setup into some simple code for Preseed, using Debian Installer…
Again, I would prefer something KISS.
To fix this manually, since the problem with first SSD is only the type of the partition, I can manually re-do the /dev/sdb
, but it would be AWESOME if MaaS could do what I do manually!
Including an option to select 2 Boot Disks! So Grub will end up being installed on two devices identical devices.
NOTE: I didn’t tried to boot this /dev/sdb
created by MaaS, is it booting? I’m not sure yet, anyway, I would rather keep the two identical disks with the very same scheme / layout anyway.
I appreciate any help!
I love MaaS ideas but I must confess that the implementation is… How can I say… A bit unstable.
Cheers!
Thiago
