Hi all, I have a very strange problem while commissioning a node it always fails on 50-maas-01-commissioning . However the script runs perfectly fine, returns “correct” (?) output and its exit status is 0. It is also interesting that the stderr tab on MaaS has only the output of downloading the script from the rackd controller (with no error or anything that indicates problem). If I ssh to the host during comissioning I can also run the script perfectly fine.
If the output was successfully returned there may have been an error while MAAS processed it. I would check your logs in /var/log/maas/*.log to see if any exceptions where raised during commissioning.
It’s strange I haven’t noticed… I actually get an exception
django.core.exceptions.ValidationError: {'__all__': ['Interface with this Node and Name already exists.']}
I suppose that as this node was in Ready state when re-comissioned, something went wrong. I have done it with a dozen other server with no problem at all.
It shouldn’t be possible to commission while in a ready state. MAAS will reject commissioning results unless the machine is in commissioning. Its hard to say what went wrong without seeing the script output and MAAS logs. From that message it appears that MAAS at least thinks an interface is being duplicated.
The machine was in Ready state and from this state, MaaS allows to go again to Comissioning. In any case, the issue has been solved by deleting the node and enlisting again. Thank you for your assistance!
I can reproduce this issue. I tried deleting my node and re-enlisting, but it continues to happen. MAAS 2.9.3-beta1 (snap install). Script output is here.
2021-08-17 21:21:35 metadataserver.api: [critical] akis.maas(tpcccy): commissioning script '50-maas-01-commissioning' failed during post-processing.
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/api.py", line 820, in signal
target_status = process(node, request, status)
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/api.py", line 641, in _process_commissioning
self._store_results(
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/api.py", line 529, in _store_results
script_result.store_result(
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/models/scriptresult.py", line 384, in store_result
signal_status = try_or_log_event(
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/api.py", line 447, in try_or_log_event
func(*args, **kwargs)
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py", line 783, in process_lxd_results
_process_lxd_resources(node, data["resources"])
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py", line 531, in _process_lxd_resources
update_node_network_information(node, data, numa_nodes)
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py", line 330, in update_node_network_information
update_interface_details(
File "/snap/maas/15419/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py", line 241, in update_interface_details
interface.save(update_fields=["updated", *update_fields])
File "/snap/maas/15419/lib/python3.8/site-packages/maasserver/models/interface.py", line 1627, in save
return super().save(*args, **kwargs)
File "/snap/maas/15419/lib/python3.8/site-packages/maasserver/models/cleansave.py", line 186, in save
self.validate_unique(exclude=[self._meta.pk.name])
File "/snap/maas/15419/usr/lib/python3/dist-packages/django/db/models/base.py", line 987, in validate_unique
raise ValidationError(errors)
