After commissioning a few machines, this starts to happen:
Failed to query node’s BMC - Device busy while performing power action. MAAS performed several retries. Please wait and try again…
The maas user it sets up is never enabled and I also want to use a dedicated BMC interface instead of the using standard interface. I also mean it activates BMC function on the standard interface with its own dynamic IP. This is not what we want.
I change the IPMI settings manually to the correct fixed IP and it usually works when checking power after updating the configuration. However, after setting up a few machines this error starts to happen. I can not find any logs to read (everything is empty under /snap/maas/current/var/log/ ) and the user, password, and IP are correct and works when accessing via WEB.
Two questions: How to debug this, and how to change the default behavior so it does not enable the BMC on the standard interface. It has already a dedicated interface with a fixed address.
Update: If it is the SSL certificate for the integrated BMC Web console that is the problem. How can I either upload a certificate that MAAS accept or turn of SSL verification on MAAS?
