WHile deploying a server from MaaS Deployment is getting failed..I have attached the logs below. Please provide reason & fix for this issue.
curtin: Installation failed with exception: Unexpected error while running command.
Command: ['curtin', 'block-meta', 'custom']
Exit code: 3
Reason: -
Stdout: start: cmd-install/stage-partitioning/builtin/cmd-block-meta: curtin command block-meta
get_path_to_storage_volume for volume nvme0n1({'id': 'nvme0n1', 'model': 'SAMSUNG MZQL27T6HBLA-00A07', 'name': 'nvme0n1', 'serial': 'S6CKNN0X500782', 'type': 'disk', 'wipe': 'superblock'})
Processing serial S6CKNN0X500782 via udev to S6CKNN0X500782
lookup_disks found: ['nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500782', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500782_1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500782-part1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500782_1-part1']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/nvme2n1'] with allowed return codes [0] (capture=True)
/dev/nvme2n1 is multipath device? False
/dev/nvme2n1 is multipath device member? False
block.lookup_disk() returning path /dev/nvme2n1
Running command ['partprobe', '/dev/nvme2n1'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.047
devsync happy - path /dev/nvme2n1 now exists
return volume path /dev/nvme2n1
get_path_to_storage_volume for volume nvme5n1({'id': 'nvme5n1', 'model': 'SAMSUNG MZQL27T6HBLA-00A07', 'name': 'nvme5n1', 'serial': 'S6CKNN0X500452', 'type': 'disk', 'wipe': 'superblock'})
Processing serial S6CKNN0X500452 via udev to S6CKNN0X500452
lookup_disks found: ['nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500452', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500452_1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500452-part1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500452_1-part1']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/nvme0n1'] with allowed return codes [0] (capture=True)
/dev/nvme0n1 is multipath device? False
/dev/nvme0n1 is multipath device member? False
block.lookup_disk() returning path /dev/nvme0n1
Running command ['partprobe', '/dev/nvme0n1'] with allowed return codes [0, 1] (capture=False)
devsync happy - path /dev/nvme0n1 now exists
return volume path /dev/nvme0n1
get_path_to_storage_volume for volume nvme7n1({'id': 'nvme7n1', 'model': 'SAMSUNG MZQL27T6HBLA-00A07', 'name': 'nvme7n1', 'serial': 'S6CKNN0X500442', 'type': 'disk', 'wipe': 'superblock'})
Processing serial S6CKNN0X500442 via udev to S6CKNN0X500442
lookup_disks found: ['nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500442', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500442_1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500442-part1', 'nvme-SAMSUNG_MZQL27T6HBLA-00A07_S6CKNN0X500442_1-part1']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/nvme6n1'] with allowed return codes [0] (capture=True)
