Hello!
Thanks.
POC Server with external DHCP config.
New one that i would like to configure “external dhcp”.
                r00ta
                    6 March 2024 12:29
                  2
              Hi @elperro  ,
You simply don’t set it. It will be discovered automatically
              There has been no change for about two days. Is there a setting I need to do on the DHCP server side?
in fact, MAAS automatically finds the machines on the  subnet…I’m just digging if the other issue may be related to this external dhcp setting.
errno-101-network-is-uncreachable
                r00ta
                    6 March 2024 12:40
                  4
              do you have network discovery enabled?
              Yes I have. It has the same settings as the old one.
                r00ta
                    6 March 2024 12:56
                  6
              every rack should check every 10 minutes for external dhcp servers and report the info back to the regions. If you definitely have an external dhcp server on a subnet of a rack it should work. If not, I’d check the rackd logs
              How can I see the rackd logs ?
              Thanks. I did not see an error, the last line has the following message : " External DHCP probe complete."
2024-03-06 14:04:07 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=55928, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=5253, flowInfo=0, scopeID=0))
2024-03-06 14:04:07 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=55932, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=5253, flowInfo=0, scopeID=0))
2024-03-06 14:04:07 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=55942, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:192.168.36.26', port=5253, flowInfo=0, scopeID=0))
2024-03-06 14:04:07 provisioningserver.rpc.clusterservice: [info] Event-loop 'srvmaas:pid=1242' authenticated.
2024-03-06 14:04:07 provisioningserver.rpc.clusterservice: [info] Rack controller 'r6c37t' registered (via srvmaas:pid=1242) with MAAS version 3.4.0-14321-g.1027c7664.
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:custom:amd64:generic:ubuntu2204-DESKTOP: to_add=['20240305'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:grub-efi-signed:amd64:generic:uefi: to_add=['20231004.0'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:grub-efi:arm64:generic:uefi: to_add=['20231004.0'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:grub-ieee1275:ppc64el:generic:open-firmware: to_add=['20210509.0'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:pxelinux:i386:generic:pxe: to_add=['20210203.0'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:rhel:amd64:generic:8-custom: to_add=['20240305'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:ga-18.04-lowlatency:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:ga-18.04:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:ga-22.04-lowlatency:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:ga-22.04:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-18.04-edge:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-18.04-lowlatency-edge:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-18.04-lowlatency:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-18.04:bionic: to_add=['20230607'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-22.04-edge:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-22.04-lowlatency-edge:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-22.04-lowlatency:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:amd64:hwe-22.04:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:armhf:ga-22.04:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:armhf:generic-lpae:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:armhf:hwe-22.04-edge:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:07:07 sstreams: [info] maas:v2:download/maas:boot:ubuntu:armhf:hwe-22.04:jammy: to_add=['20240301'] to_remove=[]
2024-03-06 14:12:07 provisioningserver.rackdservices.dhcp_probe_service: [info] Probe for external DHCP servers started on interfaces: ens160.
2024-03-06 14:12:17 provisioningserver.rackdservices.dhcp_probe_service: [info] External DHCP probe complete.
                r00ta
                    6 March 2024 13:59
                  10
are you 100% the external dhcp server is properly working on the subnet where the rack interface
              I solved it.
Thanks.
I’m leaving the working configs below
BEFORE:
AFTER
network:
                system
                    8 March 2024 14:10
                  12
