Explore MAAS (CLI)
You can get a feel for MAAS without committing real hardware by using virtual machines. This article will show you how, focusing on the web UI. You should realise that this is not an exhaustive introduction, but it will set you up with a good MAAS test configuration.
Installation
We recommend testing MAAS with libvirt and its VM/QEMU hypervisor driver. The majority of Linux distributions, including Ubuntu, support this tool. It is easy to install, and MAAS natively supports power management of VMs created in libvirt. We also recommend that you install the GUI-based virt-manager to ease configuration, but you can use libvirt from the command line.
MAAS also works in a Linux virtual machine running from Oracle’s VirtualBox. VirtualBox may be useful if you want to test MAAS from a Microsoft Windows or macOS environment.
After entering your password, the snap will download and install from the 2.8 channel. However, MAAS needs initialising before it’s ready to go.
Once it is installed, you can use the --help flag with maas init to get these instructions:
$ sudo maas init --help
optional arguments:
run modes:
    sudo maas init region+rack --database-url maas-test-db:///
Note that this step installs a a running PostgreSQL and a MAAS-ready database instantiation. When it’s done, you can double check with a built in PostgreSQL shell:
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb, owned by maas. Note that this database is still empty because MAAS is not yet initialized and, hence, is not yet using the database. Once this is done, you can run the maas init command:
MAAS has been set up.
  sudo maas configauth
  sudo maas createadmin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
Next steps
Once you have completed this process, you can access the web UI from the default URL (above) and begin your configuration journey.
