When I try to create a LXD POD (server instaled via maas, with option “this is a kvm host”)
The host appears, but when we try to compose a pod, this error is raised:
Hello @vasartori,
This issue most probably has to do with the version of the LXD installed in the KVM Host. I suspect that it is 5.20
or 5.21/stable
which, as we speak points to 5.20
(snap info lxd
). On 5.20
there is a known issue that is preventing the creation of VMs from MAAS: Bug #2048399 “MAAS LXD VM creation issue (Ensure this value is l...” : Bugs : MAAS.
MAAS has already been configured to use LXD 5.21/stable
, LXD team has released 5.21, but the snap channel 5.21/stable
has not been updated yet. Until this is done, you could pick 5.21/candidate
or any other version that is different from 5.20
. But I expect it to be updated soon.
Kind regards,
Stamatis
