Hi
Only the first machine will get memory information. The rest of added machine get 0 GiB.
If I delete all machines and try with a new HW as the first to be added. That one will get correct memory info. This in a new installation of MAAS 2.6.0. We have this behavior.
The same error will appear during both adding a new HW and when doing commission.
I get this errors in the regiond.log:
2019-09-04 12:40:04 metadataserver.api: [critical] superb-magpie.maas-infra.hpc.scania.com(g83hwx): commissioning script ‘00-maas-01-lshw’ failed during post-processing.
File “/usr/lib/python3/dist-packages/metadataserver/api.py”, line 746, in signal
target_status = process(node, request, status)
File “/usr/lib/python3/dist-packages/metadataserver/api.py”, line 577, in _process_commissioning
node, node.current_commissioning_script_set, request, status)
File “/usr/lib/python3/dist-packages/metadataserver/api.py”, line 493, in _store_results
**args, timedout=(status == SIGNAL_STATUS.TIMEDOUT))
File “/usr/lib/python3/dist-packages/metadataserver/models/scriptresult.py”, line 323, in store_result
exit_status=self.exit_status)
File “/usr/lib/python3/dist-packages/metadataserver/api.py”, line 422, in try_or_log_event
func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/metadataserver/builtin_scripts/hooks.py”, line 326, in update_hardware_details
node.save(update_fields=[‘memory’, ‘hardware_uuid’])
File “/usr/lib/python3/dist-packages/maasserver/models/node.py”, line 1772, in save
super(Node, self).save(*args, **kwargs)
File “/usr/lib/python3/dist-packages/maasserver/models/cleansave.py”, line 213, in save
self.validate_unique(exclude=[self._meta.pk.name])
File “/usr/lib/python3/dist-packages/django/db/models/base.py”, line 1041, in validate_unique
raise ValidationError(errors)
django.core.exceptions.ValidationError: {‘hardware_uuid’: [‘Node with this Hardware uuid already exists.’]}
