Encrypted curtin preseed
I was able to deploy my custom images and during the first deployment I created the partitioning scheme using the UI. Afterwards I had maas create a curtin preseed file based on the deployment. I am able to successfully deploy using this curtin preseed, but anytime I attempt to add encryption it will not pass grub and continually reboot itself, any help on how to resolve this?
How are you adding encryption?
I was adding it using a dm_crypt block to encrypt the lvm partitions. I tested further by creating a test partition and encrypting that only. it looks like it is not being added to /etc/crypttab. I am not using secureboot, and from my understanding maas should now use luks2 by default, is there a good tutorial or documentation on how to deploy using late-commands in curtin?
Does this help Deploying servers with full disk encryption (LUKS2) ?
@r00ta that link along with another post I found where used as starting points
After further testing I have been able to properly edit /etc/fstab and /etc/crypttab in latecommands to successfully encrypt everything other than root. when root is encrypted, grub is still not detecting it
