I had a machine for which Deployment failed, after some fixes in storage template, the Deployment worked again.
For some reason, now, MAAS dns is holding 2 A records for this machine, the correct one. I guess in the failed deployment some kind of DNS clean up did not take place.
If I look in the DNS tab only the correct A record is listed. But attempting to resolve the machine will bring either IP.
I guess I should be able to re-generate the DNS setup or something.
Has anybody experienced this before? How do I fix DNS?
