Delete a DNS resource record
maas $PROFILE dnsresource-record delete [--help] [-d] [-k] id [data ...]
Positional arguments
- id
Delete a DNS resource record with the given id.
Command-line options
| Option | Effect |
Read a DNS resource record description Read a DNS resource record with the given id.
maas $PROFILE dnsresource-record read [--help] [-d] [-k] id [data ...]
- id
| Option | Effect |
Update a DNS resource record
maas $PROFILE dnsresource-record update [--help] [-d] [-k] id [data ...]
- id
Update a DNS resource record with the given id.
Keyword “rrtype”
Optional String. Resource type.
Keyword “rrdata”
Optional String. Resource data (everything to the right of type.)
| Option | Effect |
Create a DNS resource record
maas $PROFILE dnsresource-records create [--help] [-d] [-k] [data ...]
Create a new DNS resource record.
Keyword “fqdn”
Optional String. Hostname (with domain) for the dnsresource. Either fqdn or name and domain must be specified. fqdn is ignored if either name or domain is given (e.g. www.your-maas.maas).
Keyword “name”
Optional String. The name (or hostname without a domain) of the DNS resource record (e.g. www.your-maas)
Keyword “domain”
Optional String. The domain (name or id) where to create the DNS resource record (Domain (e.g. ‘maas’)
Keyword “rrtype”
Optional String. The resource record type (e.g cname, mx, ns, srv, sshfp, txt).
Keyword “rrdata”
Optional String. The resource record data (e.g. ‘your-maas’, ‘10 mail.your-maas.maas’)
| Option | Effect |
List all DNS resource records
maas $PROFILE dnsresource-records read [--help] [-d] [-k] [data ...]
List all DNS resource records.
Keyword “domain”
Optional String. Restricts the listing to entries for the domain.
Keyword “name”
Optional String. Restricts the listing to entries of the given name.
Keyword “rrtype”
Optional String. Restricts the listing to entries which have records of the given rrtype.
| Option | Effect |
Keyword “domain”
Keyword “name”
Keyword “rrtype”
| Option | Effect |
