Hello all,
We were hoping to have MAAS act as the DHCP server for our BMC interfaces, however, we are not able get this to work.
Our workflow is as follows:
- We have a fabric, let’s call it fabric0
- We have a tagged VLAN 20 within this fabric, call it “bmc-vlan”
- We have a single subnet within this vlan, call it “bmc-subnet”
- We have configured our MAAS rackd with a second interface and assigned it an IP on the “bmc-subnet”. Within the Ubuntu OS, this interface appears untagged. But the interface itself is connected to VLAN 20 on our switch.
- We enable DHCP on the “bmc-vlan” within MAAS and assigned it to the rackd from step 4
- We create a machine, call it “test-machine”, and configure the “power” option to the IPMI interface. We define the IP address, which is within the range of bmc-subnet, a BMC MAC.
- When we look at the “bmc-subnet” in MAAS, we see that the IP address of the BMC of test-machine shows up under “used IP address” of the subnet with a type of “Sticky”.
When the BMC is connected to the network, it receives an IP from the MAAS “Reserved Dynamic Range” range of bmc-subnet and not the IP that was defined under the “power” options of test-machine.
When I look at /var/snap/maas/common/maas/dhcpd.conf on the rackd server from step 4, I do see the bmc-subnet defined. I do not see, however, a “host” (DHCP reservation) defined for the MAC address of the BMC of test-machine. I do see “host” entries for the non-BMC interfaces of other hosts.
If I true to use the “devices” option in MAAS to create a “device” for the BMC of test-machine, I get an error that the IP already exists.
I am wondering, is MAAS intended to provide IP addresses for BMCs. when configured in the way I described? If not, how can we manage the dissemination of BMC IP addresses via MAAS?
As a side question, if the workflow above is expected to not result in MAAS assigning an IP to the BMC via a DHCP reservation, then why is the BMC MAC one of the optional fields of the IPMI power type?
Thanks in advance for any help!
