Disk erasure pertains to the erasing of data on each of a machine’s disks when the machine has been released (see Release action) back into the pool of available machines. The user can choose from among three erasure types before confirming the Release action, and a default erasure configuration can also be set. This section will help you learn:
- About disk erasure types
- About standard erasure
- About secure erasure
- About quick erasure
- About erasure order of preference
- Standard erasure
- Secure erasure
- Quick erasure
About quick erasure
If all three options are checked when the machine is released, the following order of preference is applied:
- Use ‘secure erase’ if the disk supports it
- If it does not, then use ‘quick erase’
