snap v3.3.3
Is there a way to disable bind on ipv6?
snap v3.3.3
Hi @zmance ,
As far as I know nope, it’s not currently possible to disable bind on ipv6 only
@r00ta okay thanks for the info. Is it possible to do with apt installed MAAS and not snap?
In such case, I think you can edit /etc/bind/named.conf.options and manipulate listen-on-v6 { any; }; accordingly
