DHCP setup on website does not appear correct:
When selecting a subnet -> vlan:
This is what I see in MAAS 3.1 UI
The docs however say:
How to enable MAAS-managed DHCP
- Under the ‘Take action’ button select ‘Provide DHCP’. A new window will appear.
- Select the primary rack controller. For DHCP HA, select both the primary and the secondary.
- Create a reserved, dynamic IP range. Fill in the fields ‘Dynamic range start IP’ and ‘Dynamic range end IP’.
- Apply your changes with the ‘Provide DHCP’ button.
