[Environment]
I deployed MAAS 3.3 by snap. My MAAS has 1 region + 5 racks. 1 region + 5 racks are working on different network segments.
I set “IP mode” as “DHCP” for my machines. The DHCP server is managed by MAAS.
[Problem]
I stopped network hardwares for maintenance. The network connection between region and racks was disconnected.
As a result, every DHCP services on rack nodes were stopped. I confirmed it by “maas status” command. And deployed machines lost its IP addresses after lease time.
The DHCP services and machine’s IP addresses were fixed after I booted network hardwares.
[Question]
I hope that DHCP services will continue to work even if the network connection between region and racks is disconnected.
Is there any solution?
I think that one of the solutions is “preparing external dhcp on each network segments”. But it seems that the external dhcp is not recommended.
Or, can I extend lease time of DHCP service managed by MAAS?
(I wouldn’t like to set “IP mode” as “Static”. It is hard to manage IP addresses.)
