Hello, dear all.
Maybe someone can help. We have the following situation - physical server with Ubuntu 20.04 on it and MAAS on top. Server has 2 physical NICs which are connected to the switch and we have another server (client) which is connected to the same switch. MAAS discovered those NIC as a fabrics and discovered the subnets. IP settings on Ubuntu applied with Netplan:
network:
version: 2
ethernets:
eno1: (for LAN)
dhcp4: no
addresses: [10.0.0.2/22]
gateway4: 10.0.0.1
eno2: (for MAAS DHCP)
dhcp4: no
addresses: [172.20.0.1/16]
With all default settings, we have DHCP dynamic range configured in MAAS on interface eno2 for subnet 172.20, both server and client connected to the Default VLAN on the switch and the client is able to get an IP from MAAS DHCP.
We created with Netplan a VLAN 100 (the configuration is below) and want to use this VLAN for DHCP. Once this VLAN was created, MAAS server discovered it and I can see both subnets (172.20 and 172.16) in MAAS under the fabric-1.
network:
version: 2
ethernets:
eno1: (LAN)
dhcp4: no
gateway4: 10.0.0.1
eno2:
dhcp4: no
vlans:
test: (for MAAS DHCP)
link: eno2
addresses: [172.16.0.1/16]
We configured in MAAS the DHCP dynamic range on the subnet we want to use (172.16), we created VLAN 100 on a switch and we added the ports of the server and the client to VLAN 100. So, the current state on a switch is:
- MAAS NIC eno2 is connected to port 1, which is tagged to VLAN 1 and 100
- Client server is connected to port 4, which is untagged to VLAN 100
The current state on a MAAS server is:
- fabric-1, subnet 172.20 has a DHCP dynamic range
- fabric-1, subnet 172.16 has a DHCP dynamic range
In that state, the client is not able to get an IP from 172.16.
If we remove port 4 on a switch (client is connected to) from VLAN 100 and add port 4 back to a Default VLAN 1 (untagged), the client is able to get an IP from 172.20 like its should be.
We have checked the MAAS dhcpd.conf file and can see the applied settings are reflected in that file (we can see both pools for 172.20 and 172.16).
Is it possible the MAAS server will be able to provide DHCP service in not in a Default VLAN 1?
PS: I read the documentation, and I saw its mention something about an untagged
VLAN which is MAAS using by default. But looks like this is a MAAS definition of untagged
. There is no clear explanation (for me at least) what does this untagged
means. Not sure if its related or not. In addition, the VLAN 100 we created with Netplan is shown in MAAS server as a TYPE NUMA NODE VLAN (which is ok I guess), but its not saying anything about VLAN ID 100 itself.
Thank you in advance.
