We upgraded our MAAS 2.8.2 to 2.9 and since the upgrade our DHCP server is broken and won’t start and this we are unable to do a lot of what we need to with MAAS.
If I check in /var/snap/maas/common/maas the dhcpd.conf is missing. In the UI DHCP is not started.
In the regiond.log it spits out code as follows:
2020-12-17 07:42:51 maasserver.dhcp: [warn] No DNS servers found, DHCP defaulting to region IP.
2020-12-17 07:42:51 maasserver.rack_controller: [critical] Failed configuring DHCP on rack controller ‘id:2’.
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1475, in gotResult
_inlineCallbacks(r, g, status)
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1464, in _inlineCallbacks
status.deferred.errback()
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 501, in errback
self._startRunCallbacks(fail)
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 568, in _startRunCallbacks
self._runCallbacks()
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 654, in _runCallbacks
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/rack_controller.py”, line 277, in
d.addErrback(lambda f: f.trap(NoConnectionsAvailable))
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 439, in trap
self.raiseException()
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 467, in raiseException
raise self.value.with_traceback(self.tb)
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1416, in _inlineCallbacks
result = result.throwExceptionIntoGenerator(g)
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 491, in throwExceptionIntoGenerator
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/dhcp.py”, line 864, in configure_dhcp
config = yield deferToDatabase(get_dhcp_configuration, rack_controller)
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 250, in inContext
result = inContext.theWork()
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 266, in
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/context.py”, line 122, in callWithContext
File “/snap/maas/10851/usr/lib/python3/dist-packages/twisted/python/context.py”, line 85, in callWithContext
return func(*args,**kw)
File “/snap/maas/10851/lib/python3.8/site-packages/provisioningserver/utils/twisted.py”, line 860, in callInContext
return func(*args, **kwargs)
File “/snap/maas/10851/lib/python3.8/site-packages/provisioningserver/utils/twisted.py”, line 192, in wrapper
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/utils/orm.py”, line 737, in call_within_transaction
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/utils/orm.py”, line 540, in retrier
File “/usr/lib/python3.8/contextlib.py”, line 75, in inner
return func(*args, **kwds)
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/dhcp.py”, line 783, in get_dhcp_configuration
config = get_dhcp_configure_for(
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/dhcp.py”, line 663, in get_dhcp_configure_for
make_subnet_config(
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/dhcp.py”, line 444, in make_subnet_config
dns_servers += [
File “/snap/maas/10851/lib/python3.8/site-packages/maasserver/dhcp.py”, line 447, in
if ipaddress in ip_network
File “/snap/maas/10851/usr/lib/python3/dist-packages/netaddr/ip/init.py”, line 1123, in contains
return IPAddress(other) in self
File “/snap/maas/10851/usr/lib/python3/dist-packages/netaddr/ip/init.py”, line 305, in init
raise AddrFormatError('failed to detect a valid IP ’
netaddr.core.AddrFormatError: failed to detect a valid IP address from None
I found this link with someone else who has the exact same problem.
I suspect the dhcpd.conf is not being generated by the maasserver/dhcp.py and this causing this problem.
