Deployment failure
When I deploy system in a machine ( a server), it stucked every time.
It seems that the deployment is complete:
Maas log:
TIME
EVENT
Wed, 07 Aug. 2024 12:03:12  Marking node failed - Node operation 'Deploying' timed out after 30 minutes.
Wed, 07 Aug. 2024 12:03:12  Node changed status - From 'Deploying' to 'Failed deployment'
Wed, 07 Aug. 2024 11:32:28  HTTP Request - ipxe.cfg
Wed, 07 Aug. 2024 11:32:28  HTTP Request - ipxe.cfg-**:**:**:**:a0:0d
Wed, 07 Aug. 2024 11:32:28  HTTP Request - ipxe.cfg-default-amd64
Wed, 07 Aug. 2024 11:32:28  HTTP Request - /images/3c025aba630a30f7d03d6b02f4947ebc1edf80fc1dcfc********3a3352203bc/ubuntu/amd64/ga-22.04/jammy/stable/boot-kernel
Wed, 07 Aug. 2024 11:32:28  HTTP Request - /images/b2e605796fbeca4801cf393a8db53d7c8557dc03c10********49a6e6681254c/ubuntu/amd64/ga-22.04/jammy/stable/boot-initrd
Wed, 07 Aug. 2024 11:28:28  Script result - /tmp/install.log changed status from 'Running' to 'Passed'
Wed, 07 Aug. 2024 11:28:28  Rebooting
Wed, 07 Aug. 2024 11:28:28  Node installation - 'cloudinit' running config-install_hotplug with frequency once-per-instance
Wed, 07 Aug. 2024 11:28:28  Node installation - 'cloudinit' running config-final_message with frequency always
Wed, 07 Aug. 2024 11:28:28  Node installation - 'cloudinit' running config-keys_to_console with frequency once-per-instance
Wed, 07 Aug. 2024 11:28:28  Node installation - 'cloudinit' running config-ssh_authkey_fingerprints with frequency once-per-instance
Wed, 07 Aug. 2024 11:28:28  Node installation - 'cloudinit' running config-power_state_change with frequency once-per-instance
Wed, 07 Aug. 2024 11:28:27  Node installation - 'curtin' executing late commands
Wed, 07 Aug. 2024 11:28:27  Installation complete - Node disabled netboot
Wed, 07 Aug. 2024 11:28:27  Node installation - 'curtin' curtin command hook
Wed, 07 Aug. 2024 11:28:27  Node installation - 'curtin' running 'wget --no-proxy http://***.***.***.***:5248/MAAS/metadata/latest/by-id/fr388p/ --post-data op=netboot_off -O /dev/null'
Wed, 07 Aug. 2024 11:28:26  Node installation - 'curtin' finalizing installation
Wed, 07 Aug. 2024 11:28:26  Node installation - 'curtin' running 'curtin hook'
Wed, 07 Aug. 2024 11:28:25  Node installation - 'curtin' configuring target system bootloader
Wed, 07 Aug. 2024 11:28:25  Node installation - 'curtin' installing grub to target devices
Wed, 07 Aug. 2024 11:28:02  Node installation - 'curtin' writing etc/fstab
Wed, 07 Aug. 2024 11:28:02  Node installation - 'curtin' updating packages on target system
Wed, 07 Aug. 2024 11:28:02  Node installation - 'curtin' configuring pollinate user-agent on target
Can any one help?
