Hi ,
i’m pretty new to maas and I’m having an issue I don’t understand.
Deployment to machines work if I deploy an operating system only but when I select deploy and register as kmv the deployment gets stuck at rebooting or powering on until it timesout.
When i ssh to the machine it communicates with maas.
My maas version is 3.2.6
Im adding the deployment logs i’ve tried to deploy and register as kvm lxd on ubuntu 20
Here is the installation output
curtin: Installation started. (22.1-0ubuntu1~20.04.1)
third party drivers not installed or necessary.
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: curtin command block-meta
get_path_to_storage_volume for volume sda({'grub_device': True, 'id': 'sda', 'model': 'QEMU HARDDISK', 'name': 'sda', 'ptable': 'gpt', 'serial': 'drive-scsi0', 'type': 'disk', 'wipe': 'superblock'})
Processing serial drive-scsi0 via udev to drive-scsi0
lookup_disks found: ['scsi-0QEMU_QEMU_HARDDISK_drive-scsi0', 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part1', 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part2']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda'] with allowed return codes [0] (capture=True)
/dev/sda is multipath device? False
/dev/sda is multipath device member? False
block.lookup_disk() returning path /dev/sda
Running command ['partprobe', '/dev/sda'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.115
devsync happy - path /dev/sda now exists
return volume path /dev/sda
get_path_to_storage_volume for volume sda-part1({'device': 'sda', 'flag': 'bios_grub', 'id': 'sda-part1', 'number': 1, 'offset': '4194304B', 'size': '1048576B', 'type': 'partition', 'wipe': 'zero'})
TIMED udevadm_settle(): 0.111
return volume path /dev/sda1
get_path_to_storage_volume for volume sda-part2({'device': 'sda', 'id': 'sda-part2', 'name': 'sda-part2', 'number': 2, 'size': '107365793792B', 'type': 'partition', 'uuid': 'e1fcf2cc-038b-4389-afdf-6e8544d42adb', 'wipe': 'superblock'})
TIMED udevadm_settle(): 0.119
return volume path /dev/sda2
block-meta: extracted devices to clear: ['/dev/sda', '/dev/sda1', '/dev/sda2']
Declared block devices: ['/dev/sda', '/dev/sda1', '/dev/sda2']
clearing devices=['/dev/sda', '/dev/sda1', '/dev/sda2']
start: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: removing previous storage devices
Running command ['mdadm', '--assemble', '--scan', '-v'] with allowed return codes [0, 1, 2] (capture=True)
mdadm assemble scan results:
mdadm: looking for devices for further assembly
mdadm: no recogniseable superblock on /dev/sda2
mdadm: no recogniseable superblock on /dev/sda1
mdadm: Cannot assemble mbr metadata on /dev/sda
mdadm: cannot open device /dev/sr0: No medium found
mdadm: no recogniseable superblock on /dev/loop0
mdadm: No arrays found in config file or automatically
Running command ['mdadm', '--detail', '--scan', '-v'] with allowed return codes [0, 1] (capture=True)
mdadm detail scan after assemble:
TIMED udevadm_settle(): 0.007
Running command ['pvscan', '--cache'] with allowed return codes [0] (capture=True)
Running command ['vgscan', '--cache'] with allowed return codes [0] (capture=True)
Running command ['vgchange', '--activate=y'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.009
Loading kernel module bcache via modprobe
Running command ['modprobe', '--use-blacklist', 'bcache'] with allowed return codes [0] (capture=False)
Generating device storage trees for path(s): ['/dev/sda', '/dev/sda1', '/dev/sda2']
devname '/sys/class/block/sda' had holders: []
/dev/sda is multipath device partition? False
devname '/sys/class/block/sda2' had holders: []
devname '/sys/class/block/sda1' had holders: []
Current device storage tree:
sda
|-- sda2
`-- sda1
sda1
sda2
Shutdown Plan:
{'level': 3, 'device': '/sys/class/block/sda2', 'dev_type': 'partition'}
{'level': 3, 'device': '/sys/class/block/sda1', 'dev_type': 'partition'}
{'level': 1, 'device': '/sys/class/block/sda', 'dev_type': 'disk'}
shutdown running on holder type: 'partition' syspath: '/sys/class/block/sda2'
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sda'] with allowed return codes [0] (capture=True)
get_blockdev_sector_size: info:
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "4096",
"DISC-MAX": "1073741824",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MODE": "brw-rw----",
"MODEL": "QEMU HARDDISK ",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "107374182400",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"device_path": "/dev/sda"
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"device_path": "/dev/sda1"
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "ext4",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "root",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "107372068352",
"STATE": "",
"TYPE": "part",
"UUID": "cba624a8-48c8-4fee-9738-0bc6a4f641ae",
"device_path": "/dev/sda2"
get_blockdev_sector_size: (log=512, phys=512)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID'] with allowed return codes [0] (capture=True)
Checking if /dev/sda2 is a swap device
Found swap magic: b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
wiping superblock on /dev/sda2
wiping /dev/sda2 attempt 1/4
wiping 1M on /dev/sda2 at offsets [0, -1048576]
successfully wiped device /dev/sda2 on attempt 1/4
shutdown running on holder type: 'partition' syspath: '/sys/class/block/sda1'
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "",
"TYPE": "part",
"UUID": "",
Checking if /dev/sda1 is a swap device
Found swap magic: b'5Y\xf2\xe0`\x93e\xf1\xc0\xfa'
wiping superblock on /dev/sda1
wiping /dev/sda1 attempt 1/4
wiping 1M on /dev/sda1 at offsets [0, -1048576]
successfully wiped device /dev/sda1 on attempt 1/4
shutdown running on holder type: 'disk' syspath: '/sys/class/block/sda'
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "",
"TYPE": "part",
"UUID": "",
Checking if /dev/sda is a swap device
wiping /dev/sda attempt 1/4
wiping 1M on /dev/sda at offsets [0, -1048576]
successfully wiped device /dev/sda on attempt 1/4
/sys/class/block/sda had partitions, issuing partition reread
Running command ['blockdev', '--rereadpt', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.036
block.sys_block_path: devname /dev/sda1 does not exist
block.sys_block_path: devname /dev/sda2 does not exist
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: SUCCESS: removing previous storage devices
blockmeta: detected storage config, using mode=custom
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: sda
lookup_disks found: ['scsi-0QEMU_QEMU_HARDDISK_drive-scsi0']
TIMED udevadm_settle(): 0.035
labeling device: '/dev/sda' with 'gpt' partition table
devname '/dev/sda' had holders: []
TIMED udevadm_settle(): 0.051
Running command ['blkid', '-o', 'export', '/dev/sda'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="disk"', 'ENV{ID_SERIAL}=="0QEMU_QEMU_HARDDISK_drive-scsi0"', 'ENV{ID_SERIAL_SHORT}=="drive-scsi0"', 'SYMLINK+="disk/by-dname/sda"\n']'
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_SERIAL}=="0QEMU_QEMU_HARDDISK_drive-scsi0"', 'ENV{ID_SERIAL_SHORT}=="drive-scsi0"', 'SYMLINK+="disk/by-dname/sda-part%n"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: sda
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sda-part1
TIMED udevadm_settle(): 0.040
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
sda logical_block_size_bytes: 512
adding partition 'sda-part1' to disk 'sda' (ptable: 'gpt')
partnum: 1 offset_sectors: 2048 length_sectors: 2047
Preparing partition location on disk /dev/sda
Wiping 1M on /dev/sda at offset 1048576
Running command ['sgdisk', '--new', '1:2048:4095', '--typecode=1:ef02', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.171
TIMED udevadm_settle(exists='/dev/sda1'): 0.000
Wiping partition /dev/sda1 mode=zero
/dev/sda1 is 1048576 bytes. wiping with buflen=4194304
lookup_disks found: ['scsi-0QEMU_QEMU_HARDDISK_drive-scsi0', 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part1']
TIMED udevadm_settle(): 0.103
TIMED udevadm_settle(): 0.100
Running command ['blkid', '-o', 'export', '/dev/sda1'] with allowed return codes [0, 2] (capture=True)
No partition-specific dname
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sda-part1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sda-part2
TIMED udevadm_settle(): 0.104
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
previous partition number for 'sda-part2' found to be '1'
partition_kname=sda1
calc_partition_info: sda1 size_sectors=2048 start_sectors=2048
adding partition 'sda-part2' to disk 'sda' (ptable: 'gpt')
partnum: 2 offset_sectors: 4096 length_sectors: 209698815
Wiping 1M on /dev/sda at offset 2097152
Running command ['sgdisk', '--new', '2:4096:209702911', '--typecode=2:8300', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.186
TIMED udevadm_settle(exists='/dev/sda2'): 0.000
lookup_disks found: ['scsi-0QEMU_QEMU_HARDDISK_drive-scsi0', 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part2', 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part1']
Running command ['blkid', '-o', 'export', '/dev/sda2'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_PART_ENTRY_UUID}=="c01cc892-39cc-4b76-b2e7-1bdb9b074b52"', 'SYMLINK+="disk/by-dname/sda-part2"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sda-part2
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: sda-part2_format
TIMED udevadm_settle(): 0.127
mkfs /dev/sda2 info: {'fstype': 'ext4', 'id': 'sda-part2_format', 'label': 'root', 'type': 'format', 'uuid': '79136780-ade7-40a5-83a9-03ab9048a191', 'volume': 'sda-part2'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sda2'] with allowed return codes [0] (capture=True)
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "107365793792",
"STATE": "",
"TYPE": "part",
"UUID": "",
Running command ['mkfs.ext4', '-F', '-L', 'root', '-U', '79136780-ade7-40a5-83a9-03ab9048a191', '/dev/sda2'] with allowed return codes [0] (capture=True)
Formated device type: partition
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: sda-part2_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: sda-part2_mount
TIMED udevadm_settle(): 0.108
volume_path=/dev/sda2 found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname sda2
Running command ['mount', '-t', 'ext4', '-o', 'defaults', '/dev/sda2', '/tmp/tmperf02snr/target/'] with allowed return codes [0] (capture=True)
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda2'] with allowed return codes [0] (capture=True)
volspec: path=/dev/sda2 type=part
info[DEVLINKS] = ['/dev/disk/by-uuid/79136780-ade7-40a5-83a9-03ab9048a191', '/dev/disk/by-id/scsi-0QEMU_QEMU_HARDDISK_drive-scsi0-part2', '/dev/disk/by-label/root', '/dev/disk/by-partuuid/c01cc892-39cc-4b76-b2e7-1bdb9b074b52', '/dev/disk/by-path/pci-0000:00:05.0-scsi-0:0:0:0-part2']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: sda-part2_mount
TIMED BLOCK_META: 8.264
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: curtin command block-meta
start: cmd-install/stage-network/builtin/cmd-net-meta: curtin command net-meta
net-meta mode is 'custom'. devices=[]
writing to file /tmp/tmperf02snr/state/network_config with network config: network:
bridges:
br-ens18:
addresses:
- 192.168.99.210/24
gateway4: 192.168.99.1
interfaces:
- ens18
macaddress: be:a5:a1:23:46:4c
mtu: 1500
nameservers:
addresses:
- 192.168.99.254
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
ens18:
match:
mtu: 1500
set-name: ens18
version: 2
finish: cmd-install/stage-network/builtin/cmd-net-meta: SUCCESS: curtin command net-meta
start: cmd-install/stage-extract/builtin/cmd-extract: curtin command extract
Installing sources: [{'type': 'tgz', 'uri': 'cp:///media/root-ro'}] to target at /tmp/tmperf02snr/target
start: cmd-install/stage-extract/builtin/cmd-extract: acquiring and extracting image from cp:///media/root-ro
Running command ['sh', '-c', 'mkdir -p "$2" && cd "$2" && rsync -aXHAS --one-file-system "$1/" .', '--', '/media/root-ro', '/tmp/tmperf02snr/target'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: acquiring and extracting image from cp:///media/root-ro
Applying write_files from config.
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: curtin command extract
start: cmd-install/stage-curthooks/builtin/cmd-curthooks: curtin command curthooks
Running curtin builtin curthooks
Configuring target system for distro: ubuntu osfamily: debian
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: configuring apt configuring apt
Transferred {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.99.254:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=QzngySbkCy5XHUduDm&oauth_token_key=2C8txEJ9b9T3nfFwKD&oauth_token_secret=ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: QzngySbkCy5XHUduDm\\n endpoint: http://192.168.99.254:5248/MAAS/metadata/status/dwb6pr\\n token_key: 2C8txEJ9b9T3nfFwKD\\n token_secret: ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\\n type: webhook\\n\n'} into new format: {'preserve_sources_list': False, 'proxy': 'http://192.168.99.254:8000/', 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports restricted main universe multiverse\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.99.254:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=QzngySbkCy5XHUduDm&oauth_token_key=2C8txEJ9b9T3nfFwKD&oauth_token_secret=ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: QzngySbkCy5XHUduDm\\n endpoint: http://192.168.99.254:5248/MAAS/metadata/status/dwb6pr\\n token_key: 2C8txEJ9b9T3nfFwKD\\n token_secret: ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\\n type: webhook\\n\n'}}
curthooks handling apt to target /tmp/tmperf02snr/target with config {'preserve_sources_list': False, 'proxy': 'http://192.168.99.254:8000/', 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security restricted main universe multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports restricted main universe multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports restricted main universe multiverse\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.99.254:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=QzngySbkCy5XHUduDm&oauth_token_key=2C8txEJ9b9T3nfFwKD&oauth_token_secret=ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: QzngySbkCy5XHUduDm\\n endpoint: http://192.168.99.254:5248/MAAS/metadata/status/dwb6pr\\n token_key: 2C8txEJ9b9T3nfFwKD\\n token_secret: ZweBVYRWxFCLyQNaCMZChS4Yw7ZVjDmV\\n type: webhook\\n\n'}}
Running command ['unshare', '--help'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'lsb_release', '--all'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
got primary mirror: None
got security mirror: None
Apt Mirror info: {'PRIMARY': 'http://archive.ubuntu.com/ubuntu/', 'SECURITY': 'http://security.ubuntu.com/ubuntu/', 'MIRROR': 'http://archive.ubuntu.com/ubuntu/'}
Applying debconf selections
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'debconf-set-selections'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-query', '--list'] with allowed return codes [0] (capture=True)
unconfiguring cloud-init
cleaning cloud-init config from: ['/tmp/tmperf02snr/target/etc/cloud/cloud.cfg.d/90_dpkg.cfg']
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-reconfigure', '--frontend=noninteractive', 'cloud-init'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-query', '--show', '--showformat', '${Version}', 'cloud-init'] with allowed return codes [0] (capture=True)
Set preserve_sources_list to True in /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg with: {'apt': {'preserve_sources_list': True}}
write apt proxy info to /tmp/tmperf02snr/target/etc/apt/apt.conf.d/90curtin-aptproxy
renaming /tmp/tmperf02snr/target/etc/overlayroot.local.conf to /tmp/tmperf02snr/target/etc/overlayroot.local.conf.old
Running command ['mount', '--bind', '/dev', '/tmp/tmperf02snr/target/dev'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/proc', '/tmp/tmperf02snr/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/run', '/tmp/tmperf02snr/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/sys', '/tmp/tmperf02snr/target/sys'] with allowed return codes [0] (capture=False)
Diverting original update-initramfs in target.
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-divert', '--add', '--rename', '--divert', '/usr/sbin/update-initramfs.curtin-disabled', '/usr/sbin/update-initramfs'] with allowed return codes [0] (capture=False)
Adding 'local diversion of /usr/sbin/update-initramfs to /usr/sbin/update-initramfs.curtin-disabled'
TIMED subp(['udevadm', 'settle']): 0.015
Running command ['mount', '--make-private', '/tmp/tmperf02snr/target/sys'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmperf02snr/target/sys'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmperf02snr/target/run'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmperf02snr/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmperf02snr/target/proc'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmperf02snr/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmperf02snr/target/dev'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmperf02snr/target/dev'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: SUCCESS: configuring apt configuring apt
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: installing missing packages
Curtin config dependencies requires additional packages: ['e2fsprogs', 'bridge-utils']
Skipping install of {'vlan', 'bridge-utils', 'ifenslave'}. Not needed on netplan system.
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: SUCCESS: installing missing packages
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: configuring iscsi service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: SUCCESS: configuring iscsi service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: configuring raid (mdadm) service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: SUCCESS: configuring raid (mdadm) service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: installing kernel
Running command ['dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpgvqv0beb/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpgvqv0beb/sources.list.d', 'update'] with allowed return codes [0] (capture=False)
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:3 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [83.3 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages [8570 kB]
Get:6 http://archive.ubuntu.com/ubuntu bionic/multiverse amd64 Packages [151 kB]
Get:7 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [2785 kB]
Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1853 kB]
Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [24.9 kB]
Get:10 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [943 kB]
Get:11 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [2445 kB]
Get:12 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [1239 kB]
Get:13 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [19.0 kB]
Get:14 http://archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages [53.3 kB]
Get:15 http://archive.ubuntu.com/ubuntu bionic-backports/universe amd64 Packages [18.1 kB]
Fetched 18.4 MB in 5s (3405 kB/s)
Reading package lists...
TIMED subp(['udevadm', 'settle']): 0.009
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'eatmydata', 'apt-get', '--quiet', '--assume-yes', '--option=Dpkg::options::=--force-unsafe-io', '--option=Dpkg::Options::=--force-confold', 'install', 'linux-generic'] with allowed return codes [0] (capture=False)
Building dependency tree...
Reading state information...
The following additional packages will be installed:
amd64-microcode crda grub-common grub-gfxpayload-lists grub-pc grub-pc-bin
grub2-common intel-microcode iucode-tool iw libdbus-glib-1-2 libnl-3-200
libnl-genl-3-200 linux-firmware linux-headers-4.15.0-194
linux-headers-4.15.0-194-generic linux-headers-generic
linux-image-4.15.0-194-generic linux-image-generic
linux-modules-4.15.0-194-generic linux-modules-extra-4.15.0-194-generic
os-prober thermald wireless-regdb
Suggested packages:
multiboot-doc grub-emu xorriso desktop-base fdutils linux-doc-4.15.0
| linux-source-4.15.0 linux-tools
The following NEW packages will be installed:
libnl-genl-3-200 linux-firmware linux-generic linux-headers-4.15.0-194
0 upgraded, 25 newly installed, 0 to remove and 6 not upgraded.
Need to get 150 MB of archives.
After this operation, 712 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 libnl-3-200 amd64 3.2.29-0ubuntu3 [52.8 kB]
Get:2 http://archive.ubuntu.com/ubuntu bionic/main amd64 libnl-genl-3-200 amd64 3.2.29-0ubuntu3 [11.2 kB]
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 wireless-regdb all 2022.06.06-0ubuntu1~18.04.1 [9888 B]
Get:4 http://archive.ubuntu.com/ubuntu bionic/main amd64 iw amd64 4.14-0.1 [75.4 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic/main amd64 crda amd64 3.18-1build1 [63.5 kB]
Get:6 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 grub-common amd64 2.02-2ubuntu8.23 [1772 kB]
Get:7 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 grub2-common amd64 2.02-2ubuntu8.23 [534 kB]
Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 grub-pc-bin amd64 2.02-2ubuntu8.23 [901 kB]
Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 grub-pc amd64 2.02-2ubuntu8.23 [138 kB]
Get:10 http://archive.ubuntu.com/ubuntu bionic/main amd64 grub-gfxpayload-lists amd64 0.7 [3658 B]
Get:11 http://archive.ubuntu.com/ubuntu bionic/main amd64 iucode-tool amd64 2.3.1-1 [45.6 kB]
Get:12 http://archive.ubuntu.com/ubuntu bionic/main amd64 libdbus-glib-1-2 amd64 0.110-2 [58.3 kB]
Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-firmware all 1.173.21 [74.8 MB]
Get:14 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-modules-4.15.0-194-generic amd64 4.15.0-194.205 [13.4 MB]
Get:15 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-image-4.15.0-194-generic amd64 4.15.0-194.205 [8101 kB]
Get:16 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-modules-extra-4.15.0-194-generic amd64 4.15.0-194.205 [33.7 MB]
Get:17 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 intel-microcode amd64 3.20220809.0ubuntu0.18.04.1 [4069 kB]
Get:18 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 amd64-microcode amd64 3.20191021.1+really3.20181128.1~ubuntu0.18.04.1 [31.6 kB]
Get:19 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-image-generic amd64 4.15.0.194.179 [2532 B]
Get:20 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-headers-4.15.0-194 all 4.15.0-194.205 [11.0 MB]
Get:21 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-headers-4.15.0-194-generic amd64 4.15.0-194.205 [1256 kB]
Get:22 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-headers-generic amd64 4.15.0.194.179 [2428 B]
Get:23 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-generic amd64 4.15.0.194.179 [1868 B]
Get:24 http://archive.ubuntu.com/ubuntu bionic/main amd64 os-prober amd64 1.74ubuntu1 [19.8 kB]
Get:25 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 thermald amd64 1.7.0-5ubuntu5 [192 kB]
Preconfiguring packages ...
Fetched 150 MB in 6s (23.8 MB/s)
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device)
Selecting previously unselected package libnl-3-200:amd64.
(Reading database ... 29092 files and directories currently installed.)
Preparing to unpack .../00-libnl-3-200_3.2.29-0ubuntu3_amd64.deb ...
Unpacking libnl-3-200:amd64 (3.2.29-0ubuntu3) ...
Selecting previously unselected package libnl-genl-3-200:amd64.
Preparing to unpack .../01-libnl-genl-3-200_3.2.29-0ubuntu3_amd64.deb ...
Unpacking libnl-genl-3-200:amd64 (3.2.29-0ubuntu3) ...
Selecting previously unselected package wireless-regdb.
Preparing to unpack .../02-wireless-regdb_2022.06.06-0ubuntu1~18.04.1_all.deb ...
Unpacking wireless-regdb (2022.06.06-0ubuntu1~18.04.1) ...
Selecting previously unselected package iw.
Preparing to unpack .../03-iw_4.14-0.1_amd64.deb ...
Unpacking iw (4.14-0.1) ...
Selecting previously unselected package crda.
Preparing to unpack .../04-crda_3.18-1build1_amd64.deb ...
Unpacking crda (3.18-1build1) ...
Selecting previously unselected package grub-common.
Preparing to unpack .../05-grub-common_2.02-2ubuntu8.23_amd64.deb ...
Unpacking grub-common (2.02-2ubuntu8.23) ...
Selecting previously unselected package grub2-common.
Preparing to unpack .../06-grub2-common_2.02-2ubuntu8.23_amd64.deb ...
Unpacking grub2-common (2.02-2ubuntu8.23) ...
Selecting previously unselected package grub-pc-bin.
Preparing to unpack .../07-grub-pc-bin_2.02-2ubuntu8.23_amd64.deb ...
Unpacking grub-pc-bin (2.02-2ubuntu8.23) ...
Selecting previously unselected package grub-pc.
Preparing to unpack .../08-grub-pc_2.02-2ubuntu8.23_amd64.deb ...
Unpacking grub-pc (2.02-2ubuntu8.23) ...
Selecting previously unselected package grub-gfxpayload-lists.
Preparing to unpack .../09-grub-gfxpayload-lists_0.7_amd64.deb ...
Unpacking grub-gfxpayload-lists (0.7) ...
Selecting previously unselected package iucode-tool.
Preparing to unpack .../10-iucode-tool_2.3.1-1_amd64.deb ...
Unpacking iucode-tool (2.3.1-1) ...
Selecting previously unselected package libdbus-glib-1-2:amd64.
Preparing to unpack .../11-libdbus-glib-1-2_0.110-2_amd64.deb ...
Unpacking libdbus-glib-1-2:amd64 (0.110-2) ...
Selecting previously unselected package linux-firmware.
Preparing to unpack .../12-linux-firmware_1.173.21_all.deb ...
Unpacking linux-firmware (1.173.21) ...
Selecting previously unselected package linux-modules-4.15.0-194-generic.
Preparing to unpack .../13-linux-modules-4.15.0-194-generic_4.15.0-194.205_amd64.deb ...
Unpacking linux-modules-4.15.0-194-generic (4.15.0-194.205) ...
Selecting previously unselected package linux-image-4.15.0-194-generic.
Preparing to unpack .../14-linux-image-4.15.0-194-generic_4.15.0-194.205_amd64.deb ...
Unpacking linux-image-4.15.0-194-generic (4.15.0-194.205) ...
Selecting previously unselected package linux-modules-extra-4.15.0-194-generic.
Preparing to unpack .../15-linux-modules-extra-4.15.0-194-generic_4.15.0-194.205_amd64.deb ...
Unpacking linux-modules-extra-4.15.0-194-generic (4.15.0-194.205) ...
Selecting previously unselected package intel-microcode.
Preparing to unpack .../16-intel-microcode_3.20220809.0ubuntu0.18.04.1_amd64.deb ...
Unpacking intel-microcode (3.20220809.0ubuntu0.18.04.1) ...
Selecting previously unselected package amd64-microcode.
Preparing to unpack .../17-amd64-microcode_3.20191021.1+really3.20181128.1~ubuntu0.18.04.1_amd64.deb ...
Unpacking amd64-microcode (3.20191021.1+really3.20181128.1~ubuntu0.18.04.1) ...
Selecting previously unselected package linux-image-generic.
Preparing to unpack .../18-linux-image-generic_4.15.0.194.179_amd64.deb ...
Unpacking linux-image-generic (4.15.0.194.179) ...
Selecting previously unselected package linux-headers-4.15.0-194.
Preparing to unpack .../19-linux-headers-4.15.0-194_4.15.0-194.205_all.deb ...
Unpacking linux-headers-4.15.0-194 (4.15.0-194.205) ...
Selecting previously unselected package linux-headers-4.15.0-194-generic.
Preparing to unpack .../20-linux-headers-4.15.0-194-generic_4.15.0-194.205_amd64.deb ...
Unpacking linux-headers-4.15.0-194-generic (4.15.0-194.205) ...
Selecting previously unselected package linux-headers-generic.
Preparing to unpack .../21-linux-headers-generic_4.15.0.194.179_amd64.deb ...
Unpacking linux-headers-generic (4.15.0.194.179) ...
Selecting previously unselected package linux-generic.
Preparing to unpack .../22-linux-generic_4.15.0.194.179_amd64.deb ...
Unpacking linux-generic (4.15.0.194.179) ...
Selecting previously unselected package os-prober.
Preparing to unpack .../23-os-prober_1.74ubuntu1_amd64.deb ...
Unpacking os-prober (1.74ubuntu1) ...
Selecting previously unselected package thermald.
Preparing to unpack .../24-thermald_1.7.0-5ubuntu5_amd64.deb ...
Unpacking thermald (1.7.0-5ubuntu5) ...
Setting up libdbus-glib-1-2:amd64 (0.110-2) ...
Setting up wireless-regdb (2022.06.06-0ubuntu1~18.04.1) ...
Setting up iucode-tool (2.3.1-1) ...
Setting up grub-common (2.02-2ubuntu8.23) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Running in chroot, ignoring request: daemon-reload
Running in chroot, ignoring request.
invoke-rc.d: policy-rc.d denied execution of start.
Setting up linux-headers-4.15.0-194 (4.15.0-194.205) ...
Setting up libnl-3-200:amd64 (3.2.29-0ubuntu3) ...
Setting up linux-modules-4.15.0-194-generic (4.15.0-194.205) ...
Setting up amd64-microcode (3.20191021.1+really3.20181128.1~ubuntu0.18.04.1) ...
amd64-microcode: microcode will be updated at next boot
Setting up linux-firmware (1.173.21) ...
Setting up intel-microcode (3.20220809.0ubuntu0.18.04.1) ...
intel-microcode: microcode will be updated at next boot
Setting up grub-pc-bin (2.02-2ubuntu8.23) ...
Setting up thermald (1.7.0-5ubuntu5) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.thermald.service → /lib/systemd/system/thermald.service.
Created symlink /etc/systemd/system/multi-user.target.wants/thermald.service → /lib/systemd/system/thermald.service.
/usr/sbin/policy-rc.d returned 101, not running 'start thermald.service'
Setting up grub2-common (2.02-2ubuntu8.23) ...
Setting up libnl-genl-3-200:amd64 (3.2.29-0ubuntu3) ...
Setting up os-prober (1.74ubuntu1) ...
Setting up linux-headers-4.15.0-194-generic (4.15.0-194.205) ...
Setting up iw (4.14-0.1) ...
Setting up linux-image-4.15.0-194-generic (4.15.0-194.205) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-4.15.0-194-generic
I: /initrd.img.old is now a symlink to boot/initrd.img-4.15.0-194-generic
I: /vmlinuz is now a symlink to boot/vmlinuz-4.15.0-194-generic
I: /initrd.img is now a symlink to boot/initrd.img-4.15.0-194-generic
Setting up linux-headers-generic (4.15.0.194.179) ...
Setting up crda (3.18-1build1) ...
Setting up linux-modules-extra-4.15.0-194-generic (4.15.0-194.205) ...
Setting up linux-image-generic (4.15.0.194.179) ...
Setting up linux-generic (4.15.0.194.179) ...
Setting up grub-gfxpayload-lists (0.7) ...
Setting up grub-pc (2.02-2ubuntu8.23) ...
Creating config file /etc/default/grub with new version
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
Processing triggers for systemd (237-3ubuntu10.56) ...
Processing triggers for dbus (1.12.2-1ubuntu1.3) ...
Processing triggers for install-info (6.5.0.dfsg.1-2) ...
Processing triggers for linux-image-4.15.0-194-generic (4.15.0-194.205) ...
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'apt-get', 'clean'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: SUCCESS: installing kernel
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/setting-up-swap: setting up swap
Running command ['findmnt', '--noheading', '--target', '/tmp/tmperf02snr/target/', '-o', 'FSTYPE'] with allowed return codes [0] (capture=True)
Running command ['sh', '-c', 'rm -f "$1" && umask 0066 && truncate -s 0 "$1" && { chattr +C "$1" || true; } && fallocate -l "${2}M" "$1" && mkswap "$1" || { r=$?; rm -f "$1"; exit $r; }', 'setup_swap', '/tmp/tmperf02snr/target//swap.img', '4096'] with allowed return codes [0] (capture=False)
chattr: Operation not supported while setting flags on /tmp/tmperf02snr/target//swap.img
Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
no label, UUID=7ed67175-5b1e-4b3b-bc43-bb9cd18d8ac6
creating swap file '/swap.img' of 4096MB took 0.092 seconds
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/setting-up-swap: SUCCESS: setting up swap
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/apply-networking-config: apply networking config
applying network_config
Checking cloud-init in target [/tmp/tmperf02snr/target] for network configuration passthrough support.
Checking in-target cloud-init for feature: NETWORK_CONFIG_V2
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', '/usr/bin/cloud-init', 'features'] with allowed return codes [0] (capture=True)
cloud-init feature NETWORK_CONFIG_V2 available? True
TIMED subp(['udevadm', 'settle']): 0.013
Passing network configuration through to target: /tmp/tmperf02snr/target
Writing network config to etc/cloud/cloud.cfg.d/50-curtin-networking.cfg: /tmp/tmperf02snr/target/etc/cloud/cloud.cfg.d/50-curtin-networking.cfg
Failed to find legacy network conf file /tmp/tmperf02snr/target/etc/network/interfaces.d/eth0.cfg
Attempting to remove ipv6 privacy extensions
Removing ipv6 privacy extension config file: /tmp/tmperf02snr/target/etc/sysctl.d/10-ipv6-privacy.conf
del_file: removed /tmp/tmperf02snr/target/etc/sysctl.d/10-ipv6-privacy.conf
Injecting fix for ipv6 mtu settings: /tmp/tmperf02snr/target/etc/network/if-pre-up.d/mtuipv6
Injecting fix for ipv6 mtu settings: /tmp/tmperf02snr/target/etc/network/if-up.d/mtuipv6
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/apply-networking-config: SUCCESS: apply networking config
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-etc-fstab: writing etc/fstab
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-etc-fstab: SUCCESS: writing etc/fstab
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-multipath: configuring multipath
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '--nodeps'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/loop0'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sr0'] with allowed return codes [0] (capture=True)
no devices found to rescan
Running command ['blkid', '-o', 'full'] with allowed return codes [0] (capture=True)
legacy_detect_multipath found blkid info: {'/dev/loop0': {'TYPE': 'squashfs'}, '/dev/sda1': {'PARTUUID': 'e9aae759-d219-4445-984f-852f5366dc0b'}, '/dev/sda2': {'LABEL': 'root', 'UUID': '79136780-ade7-40a5-83a9-03ab9048a191', 'TYPE': 'ext4', 'PARTUUID': 'c01cc892-39cc-4b76-b2e7-1bdb9b074b52'}}
target_devs: ['/dev/sda2']
/dev/sda2: 79136780-ade7-40a5-83a9-03ab9048a191
Multipath detection found: False
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-multipath: SUCCESS: configuring multipath
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/system-upgrade: updating packages on target system
system_upgrade disabled by config.
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/system-upgrade: SUCCESS: updating packages on target system
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/pollinate-user-agent: configuring pollinate user-agent on target
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/pollinate-user-agent: SUCCESS: configuring pollinate user-agent on target
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/updating-initramfs-configuration: updating initramfs configuration
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-divert', '--list'] with allowed return codes [0] (capture=True)
TIMED subp(['udevadm', 'settle']): 0.012
Restoring update-initramfs in target for initrd updates.
del_file: removed /tmp/tmperf02snr/target/usr/sbin/update-initramfs
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-divert', '--rename', '--remove', '/usr/sbin/update-initramfs'] with allowed return codes [0] (capture=False)
Removing 'local diversion of /usr/sbin/update-initramfs to /usr/sbin/update-initramfs.curtin-disabled'
TIMED subp(['udevadm', 'settle']): 0.011
TIMED subp(['udevadm', 'settle']): 0.010
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'update-initramfs', '-c', '-k', '4.15.0-194-generic'] with allowed return codes [0] (capture=False)
update-initramfs: Generating /boot/initrd.img-4.15.0-194-generic
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/updating-initramfs-configuration: SUCCESS: updating initramfs configuration
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-bootloader: configuring target system bootloader
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/install-grub: installing grub to target devices
setup grub on target /tmp/tmperf02snr/target
checking: {'grub_device': True, 'id': 'sda', 'model': 'QEMU HARDDISK', 'name': 'sda', 'ptable': 'gpt', 'serial': 'drive-scsi0', 'type': 'disk', 'wipe': 'superblock'}
install_devices: ['/dev/sda']
Generating grub debconf_selections for devices=['/dev/sda'] uefi=False
Applying grub debconf_selections config:
{'debconf_selections': {'grub': 'grub-pc grub-pc/install_devices multiselect /dev/disk/by-id/scsi-0QEMU_QEMU_HARDDISK_drive-scsi0'}}
The following packages were installed and preseeded, but cannot be unconfigured: ['grub-pc']
installing grub to target=/tmp/tmperf02snr/target devices=['/dev/sda'] [replace_defaults=None]
grub: moved /tmp/tmperf02snr/target/etc/default/grub.d/50-cloudimg-settings.cfg out of the way
updated /tmp/tmperf02snr/target/etc/default/grub to set: GRUB_CMDLINE_LINUX_DEFAULT=""
Using grub install command: grub-install
Grub install cmds:
[['dpkg-reconfigure', 'grub-pc'], ['update-grub'], ['grub-install', '/dev/sda']]
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'dpkg-reconfigure', 'grub-pc'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'update-grub'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmperf02snr/target', 'grub-install', '/dev/sda'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/install-grub: SUCCESS: installing grub to target devices
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-bootloader: SUCCESS: configuring target system bootloader
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: SUCCESS: curtin command curthooks
start: cmd-install/stage-hook/builtin/cmd-hook: curtin command hook
Finalizing /tmp/tmperf02snr/target
finish: cmd-install/stage-hook/builtin/cmd-hook: SUCCESS: curtin command hook
--2022-10-22 13:41:37-- http://192.168.99.254:5248/MAAS/metadata/latest/by-id/dwb6pr/
Connecting to 192.168.99.254:5248... connected.
Length: 2 [text/plain]
Saving to: ‘/dev/null’
0K 100% 292K=0s
2022-10-22 13:41:37 (292 KB/s) - ‘/dev/null’ saved [2/2]
curtin: Installation finished.
Here is the machine output
- list:
- lldp:lldp:
label: LLDP neighbors
- lshw:list:
- lshw:node:
claimed: true
class: system
handle: DMI:0100
- lshw:description:
Computer
- lshw:product:
Standard PC (i440FX + PIIX, 1996)
- lshw:vendor:
QEMU
- lshw:version:
pc-i440fx-7.0
- lshw:width:
units: bits
64
- lshw:configuration:
- lshw:setting:
value: normal
- lshw:setting:
value: D6E59489-B977-1344-A57C-E975B6022C30
- lshw:capabilities:
- lshw:capability:
SMBIOS version 2.8
- lshw:capability:
DMI version 2.8
- lshw:capability:
Symmetric Multi-Processing
- lshw:capability:
32-bit processes
- lshw:node:
claimed: true
class: bus
- lshw:description:
Motherboard
- lshw:physid:
0
- lshw:node:
claimed: true
class: memory
- lshw:description:
BIOS
- lshw:vendor:
SeaBIOS
- lshw:physid:
0
- lshw:version:
rel-1.16.0-0-gd239552ce722-prebuilt.qemu.org
- lshw:date:
04/01/2014
- lshw:size:
units: bytes
98304
- lshw:hints:
- lshw:hint:
value: chip
- lshw:node:
claimed: true
class: processor
handle: DMI:0400
- lshw:description:
CPU
- lshw:product:
Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz
- lshw:vendor:
Intel Corp.
- lshw:physid:
400
- lshw:businfo:
cpu@0
- lshw:version:
pc-i440fx-7.0
- lshw:slot:
CPU 0
- lshw:size:
units: Hz
2000000000
- lshw:capacity:
units: Hz
2000000000
- lshw:width:
units: bits
64
- lshw:setting:
value: 4
- lshw:setting:
value: 4
- lshw:setting:
value: 1
- lshw:capability:
mathematical co-processor
- lshw:capability:
FPU exceptions reporting
- lshw:capability:
- lshw:capability:
virtual mode extensions
- lshw:capability:
debugging extensions
- lshw:capability:
page size extensions
- lshw:capability:
time stamp counter
- lshw:capability:
model-specific registers
- lshw:capability:
4GB+ memory addressing (Physical Address Extension)
- lshw:capability:
machine check exceptions
- lshw:capability:
compare and exchange 8-byte
- lshw:capability:
on-chip advanced programmable interrupt controller (APIC)
- lshw:capability:
fast system calls
- lshw:capability:
memory type range registers
- lshw:capability:
page global enable
- lshw:capability:
machine check architecture
- lshw:capability:
conditional move instruction
- lshw:capability:
page attribute table
- lshw:capability:
36-bit page size extensions
- lshw:capability:
- lshw:capability:
multimedia extensions (MMX)
- lshw:capability:
fast floating point save/restore
- lshw:capability:
streaming SIMD extensions (SSE)
- lshw:capability:
streaming SIMD extensions (SSE2)
- lshw:capability:
self-snoop
- lshw:capability:
HyperThreading
- lshw:capability:
fast system calls
- lshw:capability:
no-execute bit (NX)
- lshw:capability:
- lshw:capability:
- lshw:capability:
64bits extensions (x86-64)
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:capability:
- lshw:hints:
- lshw:hint:
value: cpu
- lshw:node:
claimed: true
class: memory
handle: DMI:1000
- lshw:description:
System Memory
- lshw:physid:
1000
- lshw:size:
units: bytes
8589934592
- lshw:setting:
value: multi-bit-ecc
- lshw:capability:
Multi-bit error-correcting code (ECC)
- lshw:hints:
- lshw:hint:
value: memory
- lshw:node:
claimed: true
class: memory
handle: DMI:1100
- lshw:description:
DIMM RAM
- lshw:vendor:
QEMU
- lshw:physid:
0
- lshw:slot:
DIMM 0
- lshw:size:
units: bytes
8589934592
- lshw:hints:
- lshw:hint:
value: memory
- lshw:node:
claimed: true
class: bridge
handle: PCIBUS:0000:00
modalias: pci:v00008086d00001237sv00001AF4sd00001100bc06sc00i00
- lshw:description:
Host bridge
- lshw:product:
440FX - 82441FX PMC [Natoma]
- lshw:vendor:
Intel Corporation
- lshw:physid:
100
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:00.0
- lshw:version:
02
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:hints:
- lshw:hint:
value: 0x600
- lshw:hint:
value: 0x1237
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x8086
- lshw:node:
claimed: true
class: bridge
handle: PCI:0000:00:01.0
modalias: pci:v00008086d00007000sv00001AF4sd00001100bc06sc01i00
- lshw:description:
ISA bridge
- lshw:product:
82371SB PIIX3 ISA [Natoma/Triton II]
- lshw:vendor:
Intel Corporation
- lshw:physid:
1
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:01.0
- lshw:version:
00
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: 0
- lshw:capability:
- lshw:hints:
- lshw:hint:
value: 0x601
- lshw:hint:
value: 0x7000
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x8086
- lshw:node:
claimed: true
class: storage
handle: PCI:0000:00:01.1
modalias: pci:v00008086d00007010sv00001AF4sd00001100bc01sc01i80
- lshw:description:
IDE interface
- lshw:product:
82371SB PIIX3 IDE [Natoma/Triton II]
- lshw:vendor:
Intel Corporation
- lshw:physid:
1.1
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:01.1
- lshw:version:
00
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: ata_piix
- lshw:setting:
value: 0
- lshw:capability:
- lshw:capability:
ISA compatibility mode
- lshw:capability:
bus mastering
- lshw:resources:
- lshw:resource:
type: irq
value: 0
- lshw:resource:
type: ioport
value: 1f0(size=8)
- lshw:resource:
type: ioport
value: 3f6
- lshw:resource:
type: ioport
value: 170(size=8)
- lshw:resource:
type: ioport
value: 376
- lshw:resource:
type: ioport
value: e0c0(size=16)
- lshw:hints:
- lshw:hint:
value: disc
- lshw:hint:
value: 0x101
- lshw:hint:
value: 0x7010
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x8086
- lshw:node:
claimed: true
class: bus
handle: PCI:0000:00:01.2
modalias: pci:v00008086d00007020sv00001AF4sd00001100bc0Csc03i00
- lshw:description:
USB controller
- lshw:product:
82371SB PIIX3 USB [Natoma/Triton II]
- lshw:vendor:
Intel Corporation
- lshw:physid:
1.2
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:01.2
- lshw:version:
01
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: uhci_hcd
- lshw:setting:
value: 0
- lshw:capability:
Universal Host Controller Interface (USB1)
- lshw:capability:
bus mastering
- lshw:resources:
- lshw:resource:
type: irq
value: 11
- lshw:resource:
type: ioport
value: e080(size=32)
- lshw:hints:
- lshw:hint:
value: usb
- lshw:hint:
value: 0xC03
- lshw:hint:
value: 0x7020
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x8086
- lshw:node:
claimed: true
class: bus
handle: USB:1:1
- lshw:product:
UHCI Host Controller
- lshw:vendor:
Linux 5.4.0-131-generic uhci_hcd
- lshw:physid:
1
- lshw:businfo:
usb@1
- lshw:logicalname:
usb1
- lshw:version:
5.04
- lshw:setting:
value: hub
- lshw:setting:
value: 2
- lshw:setting:
value: 12Mbit/s
- lshw:capability:
USB 1.1
- lshw:hints:
- lshw:hint:
value: usb
- lshw:hint:
value: 0x9
- lshw:hint:
value: 0x0
- lshw:hint:
value: 0x0
- lshw:hint:
value: 0x1
- lshw:hint:
value: 0x1D6B
- lshw:node:
claimed: true
class: input
handle: USB:1:2
- lshw:description:
Human interface device
- lshw:product:
QEMU USB Tablet
- lshw:vendor:
QEMU
- lshw:physid:
1
- lshw:businfo:
usb@1:1
- lshw:version:
0.00
- lshw:serial:
28754-0000:00:01.2-1
- lshw:setting:
value: usbhid
- lshw:setting:
value: 100mA
- lshw:setting:
value: 12Mbit/s
- lshw:capability:
USB 2.0
- lshw:hints:
- lshw:hint:
value: usb
- lshw:hint:
value: 0x0
- lshw:hint:
value: 0x0
- lshw:hint:
value: 0x0
- lshw:hint:
value: 0x1
- lshw:hint:
value: 0x627
- lshw:node:
claimed: true
class: bridge
handle: PCI:0000:00:01.3
modalias: pci:v00008086d00007113sv00001AF4sd00001100bc06sc80i00
- lshw:description:
Bridge
- lshw:product:
82371AB/EB/MB PIIX4 ACPI
- lshw:vendor:
Intel Corporation
- lshw:physid:
1.3
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:01.3
- lshw:version:
03
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: piix4_smbus
- lshw:setting:
value: 0
- lshw:capability:
- lshw:resources:
- lshw:resource:
type: irq
value: 9
- lshw:hints:
- lshw:hint:
value: 0x680
- lshw:hint:
value: 0x7113
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x8086
- lshw:node:
class: display
handle: PCI:0000:00:02.0
modalias: pci:v00001234d00001111sv00001AF4sd00001100bc03sc00i00
- lshw:description:
VGA compatible controller
- lshw:physid:
2
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:02.0
- lshw:version:
02
- lshw:width:
units: bits
32
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: 0
- lshw:capability:
- lshw:resources:
- lshw:resource:
type: memory
value: fd000000-fdffffff
- lshw:resource:
type: memory
value: fea50000-fea50fff
- lshw:resource:
type: memory
value: c0000-dffff
- lshw:hints:
- lshw:hint:
value: display
- lshw:hint:
value: 0x300
- lshw:hint:
value: 0x1111
- lshw:hint:
value: 0x1100
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x1234
- lshw:node:
claimed: true
class: generic
handle: PCI:0000:00:03.0
modalias: pci:v00001AF4d00001002sv00001AF4sd00000005bc00scFFi00
- lshw:description:
Unclassified device
- lshw:product:
Virtio memory balloon
- lshw:vendor:
Red Hat, Inc.
- lshw:physid:
3
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:03.0
- lshw:version:
00
- lshw:width:
units: bits
64
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: virtio-pci
- lshw:setting:
value: 0
- lshw:capability:
bus mastering
- lshw:capability:
PCI capabilities listing
- lshw:resources:
- lshw:resource:
type: irq
value: 10
- lshw:resource:
type: ioport
value: e000(size=64)
- lshw:resource:
type: memory
value: fe400000-fe403fff
- lshw:hints:
- lshw:hint:
value: 0xFF
- lshw:hint:
value: 0x1002
- lshw:hint:
value: 0x5
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x1AF4
- lshw:node:
class: generic
- lshw:description:
Virtual I/O device
- lshw:physid:
0
- lshw:businfo:
virtio@0
- lshw:setting:
value: virtio_balloon
- lshw:node:
claimed: true
class: storage
handle: PCI:0000:00:05.0
modalias: pci:v00001AF4d00001004sv00001AF4sd00000008bc01sc00i00
- lshw:description:
SCSI storage controller
- lshw:product:
Virtio SCSI
- lshw:vendor:
Red Hat, Inc.
- lshw:physid:
5
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:05.0
- lshw:version:
00
- lshw:width:
units: bits
64
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: virtio-pci
- lshw:setting:
value: 0
- lshw:capability:
- lshw:capability:
MSI-X
- lshw:capability:
bus mastering
- lshw:capability:
- lshw:resources:
- lshw:resource:
type: irq
value: 10
- lshw:resource:
type: ioport
value: e040(size=64)
- lshw:resource:
type: memory
value: fea51000-fea51fff
- lshw:resource:
type: memory
value: fe404000-fe407fff
- lshw:hints:
- lshw:hint:
value: scsi
- lshw:hint:
value: 0x100
- lshw:hint:
value: 0x1004
- lshw:hint:
value: 0x8
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x1AF4
- lshw:node:
class: generic
- lshw:description:
Virtual I/O device
- lshw:physid:
0
- lshw:businfo:
virtio@1
- lshw:setting:
value: virtio_scsi
- lshw:node:
claimed: true
class: network
handle: PCI:0000:00:12.0
modalias: pci:v00001AF4d00001000sv00001AF4sd00000001bc02sc00i00
- lshw:description:
Ethernet controller
- lshw:product:
Virtio network device
- lshw:vendor:
Red Hat, Inc.
- lshw:physid:
12
- lshw:subproduct:
Red Hat, Inc.
- lshw:subvendor:
Red Hat, Inc.
- lshw:businfo:
pci@0000:00:12.0
- lshw:version:
00
- lshw:width:
units: bits
64
- lshw:clock:
units: Hz
33000000
- lshw:setting:
value: virtio-pci
- lshw:setting:
value: 0
- lshw:capability:
MSI-X
- lshw:capability:
bus mastering
- lshw:capability:
- lshw:capability:
extension ROM
- lshw:resources:
- lshw:resource:
type: irq
value: 11
- lshw:resource:
type: ioport
value: e0a0(size=32)
- lshw:resource:
type: memory
value: fea52000-fea52fff
- lshw:resource:
type: memory
value: fe408000-fe40bfff
- lshw:resource:
type: memory
value: fea00000-fea3ffff
- lshw:hints:
- lshw:hint:
value: network
- lshw:hint:
value: 0x200
- lshw:hint:
value: 0x1000
- lshw:hint:
value: 0x1
- lshw:hint:
value: 0x1AF4
- lshw:hint:
value: 0x1AF4
- lshw:node:
claimed: true
class: network
- lshw:description:
Ethernet interface
- lshw:physid:
0
- lshw:businfo:
virtio@2
- lshw:logicalname:
ens18
- lshw:serial:
be:a5:a1:23:46:4c
- lshw:setting:
value: off
- lshw:setting:
value: yes
- lshw:setting:
value: virtio_net
- lshw:setting:
value: 1.0.0
- lshw:setting:
value: 192.168.99.15
- lshw:setting:
value: yes
- lshw:setting:
value: yes
- lshw:capability:
- lshw:capability:
Physical interface
- lshw:hints:
- lshw:hint:
value: network
- lshw:node:
claimed: true
class: bridge
handle: PCIBUS:0000:01
modalias: pci:v00001B36d00000001sv00000000sd00000000bc06sc04i00
- lshw:description:
PCI bridge
- lshw:product:
QEMU PCI-PCI bridge
- lshw:vendor:
Red Hat, Inc.
- lshw:physid:
1e
- lshw:businfo:
pci@0000:00:1e.0
- lshw:version:
00
- lshw:slot:
0, chassis 1
- lshw:width:
units: bits
64
- lshw:clock:
units: Hz
66000000
- lshw:capability:
- lshw:capability:
Message Signalled Interrupts
- lshw:capability:
Slot Identification
- lshw:capability:
- lshw:capability:
- lshw:resources:
- lshw:resource:
type: memory
value: fea53000-fea530ff
- lshw:resource:
type: ioport
value: d000(size=4096)
- lshw:resource:
type: memory
value: fe800000-fe9fffff
- lshw:resource:
type: ioport
value: fe200000(size=2097152)
- lshw:hints:
- lshw:hint:
value: 0x604
- lshw:hint:
value: 0x1
- lshw:hint:
value: 0x1B36
- lshw:node:
claimed: true
class: bridge
handle: PCIBUS:0000:02
- lshw:description:
PCI bridge
- lshw:product:
QEMU PCI-PCI bridge
- lshw:vendor:
Red Hat, Inc.
- lshw:physid:
1f
- lshw:businfo:
pci@0000:00:1f.0
- lshw:version:
00
- lshw:slot:
0, chassis 2
- lshw:width:
units: bits
64
- lshw:clock:
units: Hz
66000000
- lshw:capability:
- lshw:capability:
- lshw:capability:
Slot Identification
- lshw:capability:
- lshw:capability:
- lshw:resources:
- lshw:resource:
type: memory
value: fea54000-fea540ff
- lshw:resource:
type: ioport
value: c000(size=4096)
- lshw:resource:
type: memory
value: fe600000-fe7fffff
- lshw:resource:
type: ioport
value: fe000000(size=2097152)
- lshw:hints:
- lshw:hint:
value: 0x604
- lshw:hint:
value: 0x1
- lshw:hint:
value: 0x1B36
- lshw:node:
claimed: true
class: input
- lshw:product:
PnP device PNP0303
- lshw:physid:
1
- lshw:setting:
value: i8042 kbd
- lshw:capability:
- lshw:node:
claimed: true
class: input
- lshw:product:
PnP device PNP0f13
- lshw:physid:
2
- lshw:setting:
value: i8042 aux
- lshw:capability:
- lshw:node:
claimed: true
class: storage
- lshw:product:
PnP device PNP0700
- lshw:physid:
3
- lshw:capability:
- lshw:node:
claimed: true
class: system
- lshw:product:
PnP device PNP0b00
- lshw:physid:
4
- lshw:setting:
value: rtc_cmos
- lshw:capability:
- lshw:node:
claimed: true
class: storage
- lshw:physid:
5
- lshw:logicalname:
scsi1
- lshw:capability:
Emulated device
- lshw:node:
claimed: true
class: disk
handle: SCSI:01:00:00:00
- lshw:description:
DVD reader
- lshw:product:
QEMU DVD-ROM
- lshw:vendor:
QEMU
- lshw:physid:
0.0.0
- lshw:businfo:
scsi@1:0.0.0
- lshw:logicalname:
/dev/cdrom
- lshw:logicalname:
/dev/dvd
- lshw:logicalname:
/dev/sr0
- lshw:dev:
11:0
- lshw:version:
2.5+
- lshw:setting:
value: 5
- lshw:setting:
value: nodisc
- lshw:capability:
support is removable
- lshw:capability:
Audio CD playback
- lshw:capability:
DVD playback
- lshw:hints:
- lshw:hint:
value: scsi
- lshw:hint:
value: cd
- lshw:node:
claimed: true
class: storage
- lshw:physid:
6
- lshw:logicalname:
scsi2
- lshw:node:
claimed: true
class: disk
handle: GUID:c125a91e-1c47-48c9-993e-fae98bd5fb38
- lshw:description:
SCSI Disk
- lshw:product:
QEMU HARDDISK
- lshw:vendor:
QEMU
- lshw:physid:
0.0.0
- lshw:businfo:
scsi@2:0.0.0
- lshw:logicalname:
/dev/sda
- lshw:dev:
8:0
- lshw:version:
2.5+
- lshw:size:
units: bytes
107374182400
- lshw:setting:
value: 5
- lshw:setting:
value: c125a91e-1c47-48c9-993e-fae98bd5fb38
- lshw:setting:
value: 512
- lshw:setting:
value: 512
- lshw:capability:
5400 rotations per minute
- lshw:capability:
GUID Partition Table version 1.00
- lshw:capability:
Partitioned disk
- lshw:capability:
GUID partition table
- lshw:hints:
- lshw:hint:
value: scsi
- lshw:hint:
- lshw:hint:
value: disc
- lshw:hint:
value: 0x80
- lshw:node:
claimed: true
class: volume
handle: GUID:179ce0af-425d-4e7c-ac3c-d0419af9e1eb
- lshw:description:
BIOS Boot partition
- lshw:vendor:
EFI
- lshw:physid:
1
- lshw:businfo:
scsi@2:0.0.0,1
- lshw:logicalname:
/dev/sda1
- lshw:dev:
8:1
- lshw:serial:
- lshw:capacity:
1048064
- lshw:capability:
No filesystem
- lshw:hints:
- lshw:hint:
value: 179ce0af-425d-4e7c-ac3c-d0419af9e1eb
- lshw:hint:
value: 21686148-6449-6e6f-744e-656564454649
- lshw:node:
claimed: true
class: volume
handle: GUID:158a3f15-476f-48e5-b19f-bf86c6814d41
- lshw:description:
EXT4 volume
- lshw:vendor:
Linux
- lshw:physid:
2
- lshw:businfo:
scsi@2:0.0.0,2
- lshw:logicalname:
/dev/sda2
- lshw:dev:
8:2
- lshw:version:
1.0
- lshw:serial:
cba624a8-48c8-4fee-9738-0bc6a4f641ae
- lshw:size:
units: bytes
107372064768
- lshw:capacity:
107372067840
- lshw:setting:
value: 2022-10-22 12:55:01
- lshw:setting:
value: ext4
- lshw:setting:
value: root
- lshw:setting:
value: /
- lshw:setting:
value: 2022-10-22 12:59:00
- lshw:setting:
value: 2022-10-22 12:59:04
- lshw:setting:
value: clean
- lshw:capability:
- lshw:capability:
Extended Attributes
- lshw:capability:
4GB+ files
- lshw:capability:
16TB+ files
- lshw:capability:
directories with 65000+ subdirs
- lshw:capability:
needs recovery
- lshw:capability:
64bit filesystem
- lshw:capability:
extent-based allocation
- lshw:capability:
- lshw:capability:
EXT2/EXT3
- lshw:capability:
initialized volume
- lshw:hints:
- lshw:hint:
value: 158a3f15-476f-48e5-b19f-bf86c6814d41
- lshw:hint:
value: 0fc63daf-8483-4772-8e79-3d69d8477de4
