Deploying MAAS: Best practices
Installing MAAS is straightforward: add the snap, run maas init, and you’re up and running. But if you’ve ever watched a seasoned MAAS operator set up a region or rack, you’ll notice they make different choices than someone new to the tool. This page collects those best practices — lessons learned in real deployments — to help you get off on the right foot.
Plan before you install
  • Separate the roles: For production, don’t run everything on one box. Put the region controller on a stable, well-resourced server. Use one or more rack controllers close to the machines they’ll serve. This separation gives you scale and fault tolerance.
  • Pick your OS version carefully: MAAS is supported on specific Ubuntu LTS releases. Match your MAAS version to an LTS that will be supported for as long as you need it.
  • Size for growth: A small test lab might run on a VM, but in production, give MAAS enough CPU, memory, and disk. Logs and images can grow quickly.
Network architecture matters
  • Use a dedicated MAAS network: Don’t mix your management VLAN with user traffic if you can avoid it. DHCP, PXE, and DNS are sensitive to noise and conflicts.
  • Think about upstream DNS: Configure MAAS to point to a reliable external resolver, or better, an internal recursive DNS. This reduces troubleshooting later.
  • Reserve ranges for MAAS: Make sure DHCP ranges don’t overlap with statically assigned addresses. Carve out space for dynamic ranges, static IPs, and VIPs.
  • Enable HA where it counts: Run multiple rack controllers in large environments. That way, DHCP/TFTP isn’t a single point of failure.
Images and commissioning
  • Mirror close to your machines: If possible, run a local image mirror. This avoids pulling large images across the internet and speeds up commissioning.
  • Keep your image catalog lean: Don’t enable every Ubuntu release under the sun. Stick to the versions you actually deploy. Fewer images mean faster syncs.
  • Customize early if needed: If you’ll need custom images (kernels, cloud-init hooks, drivers), build them up front and test them in a staging environment.
Operating practices
  • Automate with the CLI and API: The web UI is great for exploration, but serious deployments use maas CLI or API calls for repeatability. Keep scripts under version control.
  • Tag and group your machines: Don’t leave hardware unorganized. Use tags, resource pools, and machine names that reflect purpose and role. It saves you later headaches.
  • Track power drivers: Use the right power type for your hardware (IPMI, Redfish, etc.). Test each machine’s power cycling early, so you’re not surprised during deployment.
  • Audit your logs: MAAS keeps detailed logs of events, DHCP, and commissioning. Learn where they live (journalctl, MAAS event logs) and check them regularly.
Keep production and test separate
  • Run a test MAAS: If you want to experiment with new versions or workflows, spin up a sandbox instance. Don’t risk your production environment with trial-and-error.
  • Stagger upgrades: When upgrading MAAS, upgrade a non-critical instance first. Make sure your automation and integrations still work before touching production.
The expert mindset
  • Treat MAAS as infrastructure plumbing: Keep it stable, clean, and predictable.
  • Automate everything you can: Manual clicks in the web UI don’t scale.
  • Document your conventions: Future you (and your teammates) will thank you.
  • Expect to debug networks: Many “MAAS issues” turn out to be VLANs, DNS, or DHCP conflicts. Have a mental model for packet flow before you start.
Bottom line
Anyone can follow the quick-start guide and get MAAS running. The difference between a test install and a production-grade deployment is in the details: network planning, separation of roles, automation, and disciplined operating practices. Think like an infrastructure engineer, not just a software installer, and MAAS will serve you reliably at scale.
