Am I correct in thinking that to deploy Debian images the commercial Ubuntu Advantage is needed
https://docs.maas.io/2.5/en/installconfig-images
Not truly correct⦠You can deal with it! (I successfully did) But I guess you will get good support if you purchase the commercial version
As anyone been able to boot Debian images? I can upload an image but it looks like the following when the machines boots.
#Image upload.
maas coldadmin boot-resources create name=custom/debian99 title=āDebian 9.9ā architecture=amd64/generic content@=/home/coldadmin/debian-9.9.1-20190515-openstack-amd64-source.tar.gz
maas coldadmin boot-resources import
#Output from curtin when the machines attempts to load the Debian image.
āIDā
curtin: Installation failed with exception: Unexpected error while running command.
Command: [ācurtinā, ācurthooksā]
Exit code: 3
Reason: -
Stdout: āIDā
Stderr: āā
have you updated your curtain config on the region controller. when using snap 2.9 you can create a file in /var/snap/maas/current/preseeds/curtin_userdata_custom with the following.
#cloud-config
kernel:
fallback-package: linux-image-amd64
apt:
preserve_sources_list: true
early_commands:
000_update_repositories: apt update
010_install_apt_https: apt install -y apt-transport-https ca-certificates efibootmgr xfsprogs
debconf_selections:
maas: |
{{for line in str(curtin_preseed).splitlines()}}
{{line}}
{{endfor}}
late_commands:
maas: [wget, '--no-proxy', '{{node_disable_pxe_url}}', '--post-data', '{{node_disable_pxe_data}}', '-O', '/dev/null']```
how do you resolve the problem ? can you explain with more detail? thank you.
I found these very helpful
https://github.com/juan-vg/maas/wiki/Create-a-Debian-9-(Stretch)-image-that-works-with-UEFI-secure-booting
https://askubuntu.com/questions/882911/how-do-i-use-maas-to-create-a-debian-image
although Iām still struggling with debian 10 Debian10 fails on final reboot
thank you very much;
i am dealing with debian10, i am sink into the same issueļ¼
there is no 90_*.cfg fileļ¼ so the cloud-init act as no datasource.
have you already resolved the problem? i am going to debug the curtin source codeć
Have you been able to make Debian 10/11 working in the end ?
closing this thread, deferring all comments to Debian10 fails on final reboot.
