Did anyone faced issue deploying CentOS 7 instance with Bond interface configure in active/backup model using DHCP ? We are currently running “2.9.2 (9164-g.ac176b5c4-0ubuntu1~20.04.1)” and we came to a deployment issue when deploying CentOS in DHCP but it work just fine on Ubuntu 20.04. It look like the host is not getting IP or proper configuration for the network, using the same host it work fine with Ubuntu.
here is some output from maas admin machine get-curtin-config <nodeid>
Ubuntu:
network:
bonds:
bond0:
dhcp4: true
interfaces:
- ens3f0
- ens3f1
macaddress: ...REMOVED...
mtu: 1500
parameters:
down-delay: 0
gratuitious-arp: 1
mii-monitor-interval: 0
mode: active-backup
transmit-hash-policy: layer2
up-delay: 0
ethernets:
ens3f0:
match:
mtu: 1500
set-name: ens3f0
ens3f1:
match:
mtu: 1500
set-name: ens3f1
version: 2
CentOS:
network:
config:
- id: ens3f0
mac_address: ...REMOVED...
mtu: 1500
subnets:
- type: manual
type: physical
- id: ens3f1
mtu: 1500
subnets:
- type: manual
type: physical
- bond_interfaces:
- ens3f0
- ens3f1
mtu: 1500
params:
bond-downdelay: 0
bond-miimon: 0
bond-mode: active-backup
bond-num-grat-arp: 1
bond-updelay: 0
bond-xmit-hash-policy: layer2
subnets:
- type: dhcp4
type: bond
version: 1
Thanks!
