Hi all,
We have a Maas 3.0 snap setup where all nodes (including the Maas servers itself) have just 1 25GbE NIC.
Switches are Linux based with full Ansible support and use vxlan/vlan.
The idea is to create a multi tenant setup where end users can hire bare metal servers, up to around 1300 servers per Maas instance.
I have a setup now with a commission subnet (vlan 0 on the nodes), an ipmi vlan with layer 2 filtering for security and a public ip subnet.
Deploying machines over the rfc1918 subnet and giving a public ip on a vlan works fine. However, after deployment the rfc1918 network is used as a default gateway.
I tried to use the api to change the default gateway before deploying, but the deployment fails since the public ip’s on the rackd controllers are firewalled.
Ideally, I would like to remove the rfc1918 deployment network after it is done. What are my option to do this with Maas?
