cannot deploy a second same dell R930 hardware server
boot disk set be sdb
Installation Output:
File “/curtin/curtin/commands/main.py”, line 202, in main
ret = args.func(args)
File “/curtin/curtin/commands/curthooks.py”, line 1886, in curthooks
builtin_curthooks(cfg, target, state)
File “/curtin/curtin/commands/curthooks.py”, line 1851, in builtin_curthooks
setup_grub(cfg, target, osfamily=osfamily,
File “/curtin/curtin/commands/curthooks.py”, line 729, in setup_grub
for dev_id in uefi_find_grub_device_ids(storage_cfg_odict)])
File “/curtin/curtin/commands/curthooks.py”, line 678, in uefi_find_grub_device_ids
raise RuntimeError(‘Failed to find primary ESP mounted at /boot/efi’)
RuntimeError: Failed to find primary ESP mounted at /boot/efi
Event Log
Node installation failure - ‘cloudinit’ running modules for final
Thu, 29 Sep. 2022 02:05:57 Node installation - ‘cloudinit’ running config-install-hotplug with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:57 Node installation - ‘cloudinit’ running config-phone-home with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:57 Node installation - ‘cloudinit’ running config-final-message with frequency always
Thu, 29 Sep. 2022 02:05:57 Node installation - ‘cloudinit’ running config-power-state-change with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:56 Node installation failure - ‘cloudinit’ running config-scripts-user with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:56 Node installation - ‘cloudinit’ running config-ssh-authkey-fingerprints with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:56 Node installation - ‘cloudinit’ running config-keys-to-console with frequency once-per-instance
Thu, 29 Sep. 2022 02:05:55 Node installation failure - ‘curtin’ curtin command install
Thu, 29 Sep. 2022 02:05:55 Script - /tmp/install.log failed
Tried removing other disks with storage settings, and selecting flat layout
Goes into an endless loop of tying to deploy
