I created a custom image, which had kernel ‘5.4.0.177.175’. An attempt to deploy (**MaaS version = 3.2.10 **) the image on a machine failed during step ‘installing kernel’ - with package dependency error as shown below. The error was thrown after the curom image was successfully copied to the disk.
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: installing kernel
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp4k_jgx77/target', 'lsb_release', '--all'] with allowed return codes [0] (capture=True)
Running command ['dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp4k_jgx77/target', 'lsb_release', '--codename', '--short'] with allowed return codes [0] (capture=True)
Couldn't detect kernel package to install for 5.4.0-182-generic.
Running command ['mount', '--bind', '/dev', '/tmp/tmp4k_jgx77/target/dev'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/proc', '/tmp/tmp4k_jgx77/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/run', '/tmp/tmp4k_jgx77/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/sys', '/tmp/tmp4k_jgx77/target/sys'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/sys/firmware/efi/efivars', '/tmp/tmp4k_jgx77/target/sys/firmware/efi/efivars'] with allowed return codes [0] (capture=False)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp4k_jgx77/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmp6_3n2k4t/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmp6_3n2k4t/sources.list.d', 'update'] with allowed return codes [0] (capture=False)
Running in chroot, ignoring request: start
Get:2 http://archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [128 kB]
Get:1 https://prod-cdn.packages.k8s.io/repositories/isv:/kubernetes:/core:/stable:/v1.28/deb  InRelease [1189 B]
Get:4 http://archive.ubuntu.com/ubuntu focal-security InRelease [128 kB]
Get:5 https://prod-cdn.packages.k8s.io/repositories/isv:/kubernetes:/core:/stable:/v1.28/deb  Packages [16.3 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease [128 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages [970 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal/main i386 Packages [718 kB]
Get:9 http://archive.ubuntu.com/ubuntu focal/main amd64 c-n-f Metadata [29.5 kB]
Get:10 http://archive.ubuntu.com/ubuntu focal/universe i386 Packages [4642 kB]
Get:11 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages [8628 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal/universe amd64 c-n-f Metadata [265 kB]
Get:13 http://archive.ubuntu.com/ubuntu focal/restricted i386 Packages [8112 B]
Get:14 http://archive.ubuntu.com/ubuntu focal/restricted amd64 Packages [22.0 kB]
Get:15 http://archive.ubuntu.com/ubuntu focal/restricted amd64 c-n-f Metadata [392 B]
Get:16 http://archive.ubuntu.com/ubuntu focal/multiverse i386 Packages [74.7 kB]
Get:17 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages [144 kB]
Get:18 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 c-n-f Metadata [9136 B]
Get:19 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [3361 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages [986 kB]
Get:21 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [17.2 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1194 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages [788 kB]
Get:24 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [25.7 kB]
Get:25 http://archive.ubuntu.com/ubuntu focal-updates/restricted i386 Packages [39.4 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [2996 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [552 B]
Get:28 http://archive.ubuntu.com/ubuntu focal-updates/multiverse i386 Packages [8440 B]
Get:29 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [27.1 kB]
Get:30 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [620 B]
Get:31 http://archive.ubuntu.com/ubuntu focal-security/main i386 Packages [763 kB]
Get:32 http://archive.ubuntu.com/ubuntu focal-security/main amd64 Packages [2985 kB]
Get:33 http://archive.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [13.2 kB]
Get:34 http://archive.ubuntu.com/ubuntu focal-security/universe i386 Packages [661 kB]
Get:35 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages [967 kB]
Get:36 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [19.2 kB]
Get:37 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [2863 kB]
Get:38 http://archive.ubuntu.com/ubuntu focal-security/restricted i386 Packages [36.4 kB]
Get:39 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 c-n-f Metadata [552 B]
Get:40 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [24.0 kB]
Get:41 http://archive.ubuntu.com/ubuntu focal-security/multiverse i386 Packages [7200 B]
Get:42 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 c-n-f Metadata [548 B]
Get:43 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [45.7 kB]
Get:44 http://archive.ubuntu.com/ubuntu focal-backports/main i386 Packages [36.1 kB]
Get:45 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 c-n-f Metadata [1420 B]
Get:46 http://archive.ubuntu.com/ubuntu focal-backports/universe i386 Packages [13.8 kB]
Get:47 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [25.0 kB]
Get:48 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 c-n-f Metadata [880 B]
Get:49 http://archive.ubuntu.com/ubuntu focal-backports/restricted amd64 c-n-f Metadata [116 B]
Get:50 http://archive.ubuntu.com/ubuntu focal-backports/multiverse amd64 c-n-f Metadata [116 B]
Fetched 34.1 MB in 7s (4567 kB/s)
Reading package lists...
TIMED subp(['udevadm', 'settle']): 0.012
Running command ['mount', '--make-private', '/tmp/tmp4k_jgx77/target/sys/firmware/efi/efivars'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp4k_jgx77/target/sys/firmware/efi/efivars'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp4k_jgx77/target/sys'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp4k_jgx77/target/sys'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp4k_jgx77/target/run'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp4k_jgx77/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp4k_jgx77/target/proc'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp4k_jgx77/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp4k_jgx77/target/dev'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp4k_jgx77/target/dev'] with allowed return codes [0] (capture=False)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp4k_jgx77/target', 'eatmydata', 'apt-get', '--quiet', '--assume-yes', '--option=Dpkg::options::=--force-unsafe-io', '--option=Dpkg::Options::=--force-confold', 'install', 'linux-generic'] with allowed return codes [0] (capture=False)
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 linux-generic : Depends: linux-image-generic (= 5.4.0.186.184) but 5.4.0.177.175 is to be installed
                 Depends: linux-headers-generic (= 5.4.0.186.184) but 5.4.0.177.175 is to be installed
E: Unable to correct problems, you have held broken packages.
TIMED subp(['udevadm', 'settle']): 0.019
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: FAIL: installing kernel
I tried to troubleshoot further in Rescue mode. I could recreate the issue, by running the command (from installation logs) on the mounted partition:
root@localhost:~# TPM_DIR="/mnt"
root@localhost:~# unshare  --fork --pid -- chroot "${TMP_DIR}" lsb_release --all
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04.6 LTS
Release:	20.04
Codename:	focal
root@localhost:~#
root@localhost:~# unshare  --fork --pid -- chroot "${TMP_DIR}" apt update -y
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:1 https://prod-cdn.packages.k8s.io/repositories/isv:/kubernetes:/core:/stable:/v1.28/deb  InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [3359 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages [986 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1194 kB]
Get:9 http://archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages [788 kB]
Get:10 http://archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [287 kB]
Fetched 6743 kB in 5s (1407 kB/s)
Reading package lists... Done
29 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@localhost:~# unshare  --fork --pid -- chroot "${TMP_DIR}" eatmydata apt-get --assume-yes --option=Dpkg::options::=--force-unsafe-io --option=Dpkg::Options::=--force-confold install linux-generic
root@localhost:~# unshare  --fork --pid -- chroot "${TMP_DIR}" dpkg -l | grep linux-generic
hi  linux-generic                         5.4.0.177.175                     amd64        Complete Generic Linux kernel and headers
root@localhost:~#
A deploy using a freshly created custom image works because the custom image now has the latest kernel. But we don’t want to use new images unless necessary. What should be the recommended approach here? Appreciate any lead here.
Thank you!
