I wanted to pose this as a question before opening a potential bug report about this issue. I searched the forums and did not find anyone else posting about this.
Problem: All debian nodes I try to deploy via MaaS fail and it seems to be related to MaaS thinking the image is actually Ubuntu and not Debian. I say this for two reasons:
- In the installation log of the node I can see various references to
ubuntu.come.g.:
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-updates Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-security Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-backports Release' does not have a Release file.
- In the end of my installation log, the actual error I receive is from
curthooks.py- https://github.com/canonical/curtin/blob/master/curtin/commands/curthooks.py#L47-L66 :
File "/curtin/curtin/commands/curthooks.py", line 397, in install_kernel
map_suffix = mapping[codename][version]
KeyError: 'bookworm'
The way this file is written leads me to beleive this should only be called on older versions of Ubuntu and not for Debian (or any other type of OS.
Steps to create / reproduce this issue I do:
- Clone the packer/maas repo: https://github.com/canonical/packer-maas
cd packer-maas/debian- Create a debian 12 (bookworm) image
make debian SERIES=bookwormNote: This image builds successfully and I can see packer reaching out todebian.orgso I indeed believe this to be a Debian image not a Ubuntu image - copy this image to my maas server via
scp - Add this new image to MaaS via CLI:
maas admin boot-resources create name='custom/debian-12' title='Debian 12 Custom' architecture='amd64/generic' filetype='tgz' content@=debian-custom-cloudimg.tar.gz
Note: This command comes directly from the README.md in the debian directory within the packer-maas repo we cloned originally.
- Deploy any node with this custom image. Deployment will start successfully and fails pretty early on in the deployment process.
Here is the full installation log if anyone would like to see anything else:
curtin: Installation started. (23.1.1-0ubuntu1~22.04.1)
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: curtin command block-meta
get_path_to_storage_volume for volume sda({'grub_device': True, 'id': 'sda', 'name': 'sda', 'path': '/dev/sda', 'ptable': 'gpt', 'type': 'disk', 'wipe': 'superblock'})
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda'] with allowed return codes [0] (capture=True)
/dev/sda is multipath device member? False
Running command ['partprobe', '/dev/sda'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.087
devsync happy - path /dev/sda now exists
return volume path /dev/sda
get_path_to_storage_volume for volume sda-part1({'device': 'sda', 'flag': 'bios_grub', 'id': 'sda-part1', 'number': 1, 'offset': '4194304B', 'size': '1048576B', 'type': 'partition', 'wipe': 'zero'})
TIMED udevadm_settle(): 0.078
TIMED udevadm_settle(): 0.092
return volume path /dev/sda1
get_path_to_storage_volume for volume sda-part2({'device': 'sda', 'id': 'sda-part2', 'name': 'sda-part2', 'number': 2, 'size': '107365793792B', 'type': 'partition', 'uuid': 'a8a75ab3-34b5-480a-9b52-e8039a71b4e8', 'wipe': 'superblock'})
TIMED udevadm_settle(): 0.097
TIMED udevadm_settle(): 0.091
return volume path /dev/sda2
block-meta: extracted devices to clear: ['/dev/sda', '/dev/sda1', '/dev/sda2']
Declared block devices: ['/dev/sda', '/dev/sda1', '/dev/sda2']
clearing devices=['/dev/sda', '/dev/sda1', '/dev/sda2']
start: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: removing previous storage devices
Running command ['mdadm', '--assemble', '--scan', '-v'] with allowed return codes [0, 1, 2] (capture=True)
mdadm assemble scan results:
mdadm: looking for devices for further assembly
mdadm: cannot open device /dev/sr0: No medium found
mdadm: no recogniseable superblock on /dev/dm-4
mdadm: no recogniseable superblock on /dev/dm-3
mdadm: no recogniseable superblock on /dev/dm-2
mdadm: no recogniseable superblock on /dev/dm-1
mdadm: no recogniseable superblock on /dev/dm-0
mdadm: no recogniseable superblock on /dev/sda2
mdadm: no recogniseable superblock on /dev/sda1
mdadm: Cannot assemble mbr metadata on /dev/sda
mdadm: no recogniseable superblock on /dev/loop3
mdadm: no recogniseable superblock on /dev/loop2
mdadm: no recogniseable superblock on /dev/loop1
mdadm: no recogniseable superblock on /dev/loop0
mdadm: No arrays found in config file or automatically
Running command ['mdadm', '--detail', '--scan', '-v'] with allowed return codes [0, 1] (capture=True)
mdadm detail scan after assemble:
TIMED udevadm_settle(): 0.021
Detected multipath support, reload maps
Running command ['multipath', '-r'] with allowed return codes [0] (capture=False)
Verifying /dev/mapper/mpath* files are symlinks
Running command ['dmsetup', 'ls', '-o', 'blkdevname'] with allowed return codes [0] (capture=True)
multipath: dmsetup ls output:
vg_rhel-lv_home (dm-2)
vg_rhel-lv_var_tmp (dm-4)
vg_rhel-lv_var_log (dm-3)
vg_rhel-lv_root (dm-0)
vg_rhel-lv_opt (dm-1)
Running command ['pvscan', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
Running command ['vgscan', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
Running command ['vgchange', '--activate=y', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.022
Loading kernel module bcache via modprobe
Running command ['modprobe', '--use-blacklist', 'bcache'] with allowed return codes [0] (capture=False)
Generating device storage trees for path(s): ['/dev/sda', '/dev/sda1', '/dev/sda2']
devname '/sys/class/block/sda' had holders: []
/dev/sda is multipath device partition? False
devname '/sys/class/block/sda2' had holders: ['dm-1', 'dm-4', 'dm-2', 'dm-0', 'dm-3']
devname '/sys/class/block/dm-1' had holders: []
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/dm-1'] with allowed return codes [0] (capture=True)
/dev/dm-1 is multipath device partition? False
Running command ['dmsetup', 'info', '/dev/dm-1', '-C', '-o', 'uuid', '--noheadings'] with allowed return codes [0] (capture=True)
devname '/sys/class/block/dm-4' had holders: []
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/dm-4'] with allowed return codes [0] (capture=True)
/dev/dm-4 is multipath device partition? False
Running command ['dmsetup', 'info', '/dev/dm-4', '-C', '-o', 'uuid', '--noheadings'] with allowed return codes [0] (capture=True)
devname '/sys/class/block/dm-2' had holders: []
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/dm-2'] with allowed return codes [0] (capture=True)
/dev/dm-2 is multipath device partition? False
Running command ['dmsetup', 'info', '/dev/dm-2', '-C', '-o', 'uuid', '--noheadings'] with allowed return codes [0] (capture=True)
devname '/sys/class/block/dm-0' had holders: []
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/dm-0'] with allowed return codes [0] (capture=True)
/dev/dm-0 is multipath device partition? False
Running command ['dmsetup', 'info', '/dev/dm-0', '-C', '-o', 'uuid', '--noheadings'] with allowed return codes [0] (capture=True)
devname '/sys/class/block/dm-3' had holders: []
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/dm-3'] with allowed return codes [0] (capture=True)
/dev/dm-3 is multipath device partition? False
Running command ['dmsetup', 'info', '/dev/dm-3', '-C', '-o', 'uuid', '--noheadings'] with allowed return codes [0] (capture=True)
devname '/sys/class/block/sda1' had holders: []
Current device storage tree:
sda
|-- sda2
| |-- dm-1
| |-- dm-4
| |-- dm-2
| |-- dm-0
| `-- dm-3
`-- sda1
sda1
sda2
|-- dm-1
|-- dm-4
|-- dm-2
|-- dm-0
`-- dm-3
Shutdown Plan:
{'level': 6, 'device': '/sys/class/block/dm-1', 'dev_type': 'lvm'}
{'level': 6, 'device': '/sys/class/block/dm-4', 'dev_type': 'lvm'}
{'level': 6, 'device': '/sys/class/block/dm-2', 'dev_type': 'lvm'}
{'level': 6, 'device': '/sys/class/block/dm-0', 'dev_type': 'lvm'}
{'level': 6, 'device': '/sys/class/block/dm-3', 'dev_type': 'lvm'}
{'level': 4, 'device': '/sys/class/block/sda2', 'dev_type': 'partition'}
{'level': 4, 'device': '/sys/class/block/sda1', 'dev_type': 'partition'}
{'level': 2, 'device': '/sys/class/block/sda', 'dev_type': 'disk'}
shutdown running on holder type: 'lvm' syspath: '/sys/class/block/dm-1'
Running command ['dmsetup', 'splitname', 'vg_rhel-lv_opt', '-c', '--noheadings', '--separator', '=', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Wiping lvm logical volume: /dev/vg_rhel/lv_opt
Running command ['wipefs', '--all', '--force', '/dev/vg_rhel/lv_opt'] with allowed return codes [0] (capture=False)
/dev/vg_rhel/lv_opt: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
wiping 1M on /dev/vg_rhel/lv_opt at offsets [0, -1048576]
using "lvremove" on vg_rhel/lv_opt
Running command ['lvremove', '--force', '--force', 'vg_rhel/lv_opt'] with allowed return codes [0] (capture=False)
Logical volume "lv_opt" successfully removed
Running command ['lvdisplay', '-C', '--separator', '=', '--noheadings', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Running command ['pvscan'] with allowed return codes [0] (capture=True)
Running command ['vgscan'] with allowed return codes [0] (capture=True)
shutdown running on holder type: 'lvm' syspath: '/sys/class/block/dm-4'
Running command ['dmsetup', 'splitname', 'vg_rhel-lv_var_tmp', '-c', '--noheadings', '--separator', '=', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Wiping lvm logical volume: /dev/vg_rhel/lv_var_tmp
Running command ['wipefs', '--all', '--force', '/dev/vg_rhel/lv_var_tmp'] with allowed return codes [0] (capture=False)
/dev/vg_rhel/lv_var_tmp: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
wiping 1M on /dev/vg_rhel/lv_var_tmp at offsets [0, -1048576]
using "lvremove" on vg_rhel/lv_var_tmp
Running command ['lvremove', '--force', '--force', 'vg_rhel/lv_var_tmp'] with allowed return codes [0] (capture=False)
Logical volume "lv_var_tmp" successfully removed
shutdown running on holder type: 'lvm' syspath: '/sys/class/block/dm-2'
Running command ['dmsetup', 'splitname', 'vg_rhel-lv_home', '-c', '--noheadings', '--separator', '=', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Wiping lvm logical volume: /dev/vg_rhel/lv_home
Running command ['wipefs', '--all', '--force', '/dev/vg_rhel/lv_home'] with allowed return codes [0] (capture=False)
/dev/vg_rhel/lv_home: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
wiping 1M on /dev/vg_rhel/lv_home at offsets [0, -1048576]
using "lvremove" on vg_rhel/lv_home
Running command ['lvremove', '--force', '--force', 'vg_rhel/lv_home'] with allowed return codes [0] (capture=False)
Logical volume "lv_home" successfully removed
shutdown running on holder type: 'lvm' syspath: '/sys/class/block/dm-0'
Running command ['dmsetup', 'splitname', 'vg_rhel-lv_root', '-c', '--noheadings', '--separator', '=', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Wiping lvm logical volume: /dev/vg_rhel/lv_root
Running command ['wipefs', '--all', '--force', '/dev/vg_rhel/lv_root'] with allowed return codes [0] (capture=False)
/dev/vg_rhel/lv_root: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
wiping 1M on /dev/vg_rhel/lv_root at offsets [0, -1048576]
using "lvremove" on vg_rhel/lv_root
Running command ['lvremove', '--force', '--force', 'vg_rhel/lv_root'] with allowed return codes [0] (capture=False)
Logical volume "lv_root" successfully removed
shutdown running on holder type: 'lvm' syspath: '/sys/class/block/dm-3'
Running command ['dmsetup', 'splitname', 'vg_rhel-lv_var_log', '-c', '--noheadings', '--separator', '=', '-o', 'vg_name,lv_name'] with allowed return codes [0] (capture=True)
Wiping lvm logical volume: /dev/vg_rhel/lv_var_log
Running command ['wipefs', '--all', '--force', '/dev/vg_rhel/lv_var_log'] with allowed return codes [0] (capture=False)
/dev/vg_rhel/lv_var_log: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
wiping 1M on /dev/vg_rhel/lv_var_log at offsets [0, -1048576]
using "lvremove" on vg_rhel/lv_var_log
Running command ['lvremove', '--force', '--force', 'vg_rhel/lv_var_log'] with allowed return codes [0] (capture=False)
Logical volume "lv_var_log" successfully removed
Running command ['pvdisplay', '-C', '--separator', '=', '--noheadings', '-o', 'vg_name,pv_name'] with allowed return codes [0] (capture=True)
Running command ['vgremove', '--force', '--force', 'vg_rhel'] with allowed return codes [0, 5] (capture=False)
Volume group "vg_rhel" successfully removed
Wiping lvm physical volume: /dev/sda2
Running command ['wipefs', '--all', '--force', '/dev/sda2'] with allowed return codes [0] (capture=False)
/dev/sda2: 8 bytes were erased at offset 0x00000218 (LVM2_member): 4c 56 4d 32 20 30 30 31
wiping 1M on /dev/sda2 at offsets [0, -1048576]
shutdown running on holder type: 'partition' syspath: '/sys/class/block/sda2'
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sda'] with allowed return codes [0] (capture=True)
get_blockdev_sector_size: info:
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MODE": "brw-rw----",
"MODEL": "Virtual_disk",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "107374182400",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"device_path": "/dev/sda"
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"device_path": "/dev/sda1"
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "107365793792",
"STATE": "",
"TYPE": "part",
"UUID": "",
"device_path": "/dev/sda2"
get_blockdev_sector_size: (log=512, phys=512)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID'] with allowed return codes [0] (capture=True)
Checking if /dev/sda2 is a swap device
Found swap magic: b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda2'] with allowed return codes [0] (capture=True)
/dev/sda2 is multipath device? False
/dev/sda2 is multipath device member? False
wiping superblock on /dev/sda2
wiping /dev/sda2 attempt 1/4
successfully wiped device /dev/sda2 on attempt 1/4
shutdown running on holder type: 'partition' syspath: '/sys/class/block/sda1'
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "",
"TYPE": "part",
"UUID": "",
Checking if /dev/sda1 is a swap device
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda1'] with allowed return codes [0] (capture=True)
/dev/sda1 is multipath device? False
/dev/sda1 is multipath device member? False
wiping superblock on /dev/sda1
wiping /dev/sda1 attempt 1/4
Running command ['wipefs', '--all', '--force', '/dev/sda1'] with allowed return codes [0] (capture=False)
wiping 1M on /dev/sda1 at offsets [0, -1048576]
successfully wiped device /dev/sda1 on attempt 1/4
shutdown running on holder type: 'disk' syspath: '/sys/class/block/sda'
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"sda2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "",
"TYPE": "part",
"UUID": "",
Checking if /dev/sda is a swap device
/dev/sda is multipath device? False
wiping /dev/sda attempt 1/4
Running command ['wipefs', '--all', '--force', '/dev/sda'] with allowed return codes [0] (capture=False)
/dev/sda: 8 bytes were erased at offset 0x00000200 (gpt): 45 46 49 20 50 41 52 54
/dev/sda: 8 bytes were erased at offset 0x18fffffe00 (gpt): 45 46 49 20 50 41 52 54
/dev/sda: 2 bytes were erased at offset 0x000001fe (PMBR): 55 aa
wiping 1M on /dev/sda at offsets [0, -1048576]
successfully wiped device /dev/sda on attempt 1/4
/sys/class/block/sda had partitions, issuing partition reread
Running command ['blockdev', '--rereadpt', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.119
block.sys_block_path: devname /dev/sda1 does not exist
block.sys_block_path: devname /dev/sda2 does not exist
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: SUCCESS: removing previous storage devices
blockmeta: detected storage config, using mode=custom
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: sda
TIMED udevadm_settle(): 0.067
labeling device: '/dev/sda' with 'gpt' partition table
devname '/dev/sda' had holders: []
TIMED udevadm_settle(): 0.051
Running command ['blkid', '-o', 'export', '/dev/sda'] with allowed return codes [0, 2] (capture=True)
Cannot create disk tag udev rule for /dev/sda [id=sda], missing 'serial' or 'wwn' value
Can't find a uuid for volume: sda. Skipping dname.
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: sda
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sda-part1
TIMED udevadm_settle(): 0.063
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
sda logical_block_size_bytes: 512
adding partition 'sda-part1' to disk 'sda' (ptable: 'gpt')
partnum: 1 offset_sectors: 2048 length_sectors: 2047
Preparing partition location on disk /dev/sda
Wiping 1M on /dev/sda at offset 1048576
Running command ['sgdisk', '--new', '1:2048:4095', '--typecode=1:ef02', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.256
TIMED udevadm_settle(exists='/dev/sda1'): 0.000
Wiping partition /dev/sda1 mode=zero
/dev/sda1 is 1048576 bytes. wiping with buflen=4194304
TIMED udevadm_settle(): 0.159
TIMED udevadm_settle(): 0.168
Running command ['blkid', '-o', 'export', '/dev/sda1'] with allowed return codes [0, 2] (capture=True)
No partition-specific dname
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sda-part1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sda-part2
TIMED udevadm_settle(): 0.136
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sda1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sda1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "256",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
previous partition number for 'sda-part2' found to be '1'
partition_kname=sda1
calc_partition_info: sda1 size_sectors=2048 start_sectors=2048
adding partition 'sda-part2' to disk 'sda' (ptable: 'gpt')
partnum: 2 offset_sectors: 4096 length_sectors: 209698815
Wiping 1M on /dev/sda at offset 2097152
Running command ['sgdisk', '--new', '2:4096:209702911', '--typecode=2:8300', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.295
TIMED udevadm_settle(exists='/dev/sda2'): 0.000
TIMED udevadm_settle(): 0.179
TIMED udevadm_settle(): 0.219
Running command ['blkid', '-o', 'export', '/dev/sda2'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_PART_ENTRY_UUID}=="90c77761-54b5-443f-8617-765b48a93fde"', 'SYMLINK+="disk/by-dname/sda-part2"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sda-part2
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_volgroup: vg_rhel
TIMED udevadm_settle(): 0.163
TIMED udevadm_settle(): 0.197
Running command ['vgcreate', '--force', '--zero=y', '--yes', 'vg_rhel', '/dev/sda2'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_volgroup: vg_rhel
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_partition: vg_rhel-lv_root
Running command ['lvcreate', 'vg_rhel', '--name', 'lv_root', '--zero=y', '--wipesignatures=y', '--yes', '--size', '39996882944.0B'] with allowed return codes [0] (capture=False)
Logical volume "lv_root" created.
get_path_to_storage_volume for volume vg_rhel-lv_root({'id': 'vg_rhel-lv_root', 'name': 'lv_root', 'size': '39996882944B', 'type': 'lvm_partition', 'volgroup': 'vg_rhel'})
Running command ['partprobe', '/dev/vg_rhel/lv_root'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.062
devsync happy - path /dev/vg_rhel/lv_root now exists
return volume path /dev/vg_rhel/lv_root
Wiping logical volume /dev/vg_rhel/lv_root mode=superblock
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/vg_rhel/lv_root'] with allowed return codes [0] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DM_NAME}=="vg_rhel-lv_root"', 'SYMLINK+="disk/by-dname/vg_rhel-lv_root"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_partition: vg_rhel-lv_root
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_partition: vg_rhel-lv_opt
Running command ['lvcreate', 'vg_rhel', '--name', 'lv_opt', '--zero=y', '--wipesignatures=y', '--yes', '--size', '19998441472.0B'] with allowed return codes [0] (capture=False)
Logical volume "lv_opt" created.
get_path_to_storage_volume for volume vg_rhel-lv_opt({'id': 'vg_rhel-lv_opt', 'name': 'lv_opt', 'size': '19998441472B', 'type': 'lvm_partition', 'volgroup': 'vg_rhel'})
Running command ['partprobe', '/dev/vg_rhel/lv_opt'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.068
devsync happy - path /dev/vg_rhel/lv_opt now exists
return volume path /dev/vg_rhel/lv_opt
Wiping logical volume /dev/vg_rhel/lv_opt mode=superblock
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/vg_rhel/lv_opt'] with allowed return codes [0] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DM_NAME}=="vg_rhel-lv_opt"', 'SYMLINK+="disk/by-dname/vg_rhel-lv_opt"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_partition: vg_rhel-lv_opt
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_partition: vg_rhel-lv_home
Running command ['lvcreate', 'vg_rhel', '--name', 'lv_home', '--zero=y', '--wipesignatures=y', '--yes', '--size', '19998441472.0B'] with allowed return codes [0] (capture=False)
Logical volume "lv_home" created.
get_path_to_storage_volume for volume vg_rhel-lv_home({'id': 'vg_rhel-lv_home', 'name': 'lv_home', 'size': '19998441472B', 'type': 'lvm_partition', 'volgroup': 'vg_rhel'})
Running command ['partprobe', '/dev/vg_rhel/lv_home'] with allowed return codes [0, 1] (capture=False)
devsync happy - path /dev/vg_rhel/lv_home now exists
return volume path /dev/vg_rhel/lv_home
Wiping logical volume /dev/vg_rhel/lv_home mode=superblock
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/vg_rhel/lv_home'] with allowed return codes [0] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DM_NAME}=="vg_rhel-lv_home"', 'SYMLINK+="disk/by-dname/vg_rhel-lv_home"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_partition: vg_rhel-lv_home
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_partition: vg_rhel-lv_var_log
Running command ['lvcreate', 'vg_rhel', '--name', 'lv_var_log', '--zero=y', '--wipesignatures=y', '--yes', '--size', '9999220736.0B'] with allowed return codes [0] (capture=False)
Logical volume "lv_var_log" created.
get_path_to_storage_volume for volume vg_rhel-lv_var_log({'id': 'vg_rhel-lv_var_log', 'name': 'lv_var_log', 'size': '9999220736B', 'type': 'lvm_partition', 'volgroup': 'vg_rhel'})
Running command ['partprobe', '/dev/vg_rhel/lv_var_log'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.071
devsync happy - path /dev/vg_rhel/lv_var_log now exists
return volume path /dev/vg_rhel/lv_var_log
Wiping logical volume /dev/vg_rhel/lv_var_log mode=superblock
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/vg_rhel/lv_var_log'] with allowed return codes [0] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DM_NAME}=="vg_rhel-lv_var_log"', 'SYMLINK+="disk/by-dname/vg_rhel-lv_var_log"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_partition: vg_rhel-lv_var_log
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring lvm_partition: vg_rhel-lv_var_tmp
Running command ['lvcreate', 'vg_rhel', '--name', 'lv_var_tmp', '--zero=y', '--wipesignatures=y', '--yes', '--size', '4999610368.0B'] with allowed return codes [0] (capture=False)
Logical volume "lv_var_tmp" created.
get_path_to_storage_volume for volume vg_rhel-lv_var_tmp({'id': 'vg_rhel-lv_var_tmp', 'name': 'lv_var_tmp', 'size': '4999610368B', 'type': 'lvm_partition', 'volgroup': 'vg_rhel'})
Running command ['partprobe', '/dev/vg_rhel/lv_var_tmp'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.059
devsync happy - path /dev/vg_rhel/lv_var_tmp now exists
return volume path /dev/vg_rhel/lv_var_tmp
Wiping logical volume /dev/vg_rhel/lv_var_tmp mode=superblock
TIMED udevadm_settle(): 0.065
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/vg_rhel/lv_var_tmp'] with allowed return codes [0] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DM_NAME}=="vg_rhel-lv_var_tmp"', 'SYMLINK+="disk/by-dname/vg_rhel-lv_var_tmp"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring lvm_partition: vg_rhel-lv_var_tmp
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: vg_rhel-lv_var_tmp_format
mkfs /dev/vg_rhel/lv_var_tmp info: {'fstype': 'xfs', 'id': 'vg_rhel-lv_var_tmp_format', 'label': '', 'type': 'format', 'uuid': '2411a87d-e69d-4688-8b3d-e27e534dee09', 'volume': 'vg_rhel-lv_var_tmp'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/vg_rhel/lv_var_tmp'] with allowed return codes [0] (capture=True)
"dm-4": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "dm-4",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "253:4",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "vg_rhel-lv_var_tmp",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "128",
"SIZE": "4999610368",
"STATE": "running",
"TYPE": "lvm",
"UUID": "",
"device_path": "/dev/dm-4"
Running command ['mkfs.xfs', '-f', '-L', '', '-m', 'uuid=2411a87d-e69d-4688-8b3d-e27e534dee09', '/dev/vg_rhel/lv_var_tmp'] with allowed return codes [0] (capture=True)
Formated device type: lvm_partition
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: vg_rhel-lv_var_tmp_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: vg_rhel-lv_var_log_format
mkfs /dev/vg_rhel/lv_var_log info: {'fstype': 'xfs', 'id': 'vg_rhel-lv_var_log_format', 'label': '', 'type': 'format', 'uuid': '76f15a46-e115-4ba7-b03a-c35c394b8ee6', 'volume': 'vg_rhel-lv_var_log'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/vg_rhel/lv_var_log'] with allowed return codes [0] (capture=True)
"dm-3": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "dm-3",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "253:3",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "vg_rhel-lv_var_log",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "128",
"SIZE": "9999220736",
"STATE": "running",
"TYPE": "lvm",
"UUID": "",
"device_path": "/dev/dm-3"
Running command ['mkfs.xfs', '-f', '-L', '', '-m', 'uuid=76f15a46-e115-4ba7-b03a-c35c394b8ee6', '/dev/vg_rhel/lv_var_log'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: vg_rhel-lv_var_log_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: vg_rhel-lv_home_format
mkfs /dev/vg_rhel/lv_home info: {'fstype': 'xfs', 'id': 'vg_rhel-lv_home_format', 'label': '', 'type': 'format', 'uuid': 'ff2c1a4d-bf18-4a66-83c5-c4c28142d86f', 'volume': 'vg_rhel-lv_home'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/vg_rhel/lv_home'] with allowed return codes [0] (capture=True)
"dm-2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "dm-2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "253:2",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "vg_rhel-lv_home",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "128",
"SIZE": "19998441472",
"STATE": "running",
"TYPE": "lvm",
"UUID": "",
"device_path": "/dev/dm-2"
Running command ['mkfs.xfs', '-f', '-L', '', '-m', 'uuid=ff2c1a4d-bf18-4a66-83c5-c4c28142d86f', '/dev/vg_rhel/lv_home'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: vg_rhel-lv_home_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: vg_rhel-lv_opt_format
TIMED udevadm_settle(): 0.070
mkfs /dev/vg_rhel/lv_opt info: {'fstype': 'xfs', 'id': 'vg_rhel-lv_opt_format', 'label': '', 'type': 'format', 'uuid': '570fbb3d-435d-4017-9120-f9b10424fd1a', 'volume': 'vg_rhel-lv_opt'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/vg_rhel/lv_opt'] with allowed return codes [0] (capture=True)
"dm-1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "dm-1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "253:1",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "vg_rhel-lv_opt",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "128",
"STATE": "running",
"TYPE": "lvm",
"UUID": "",
"device_path": "/dev/dm-1"
Running command ['mkfs.xfs', '-f', '-L', '', '-m', 'uuid=570fbb3d-435d-4017-9120-f9b10424fd1a', '/dev/vg_rhel/lv_opt'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: vg_rhel-lv_opt_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: vg_rhel-lv_root_format
TIMED udevadm_settle(): 0.079
mkfs /dev/vg_rhel/lv_root info: {'fstype': 'xfs', 'id': 'vg_rhel-lv_root_format', 'label': '', 'type': 'format', 'uuid': '377ed463-90cd-4ed4-8909-4c4b28651ace', 'volume': 'vg_rhel-lv_root'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/vg_rhel/lv_root'] with allowed return codes [0] (capture=True)
"dm-0": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "dm-0",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "253:0",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "vg_rhel-lv_root",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "128",
"SIZE": "39996882944",
"STATE": "running",
"TYPE": "lvm",
"UUID": "",
"device_path": "/dev/dm-0"
Running command ['mkfs.xfs', '-f', '-L', '', '-m', 'uuid=377ed463-90cd-4ed4-8909-4c4b28651ace', '/dev/vg_rhel/lv_root'] with allowed return codes [0] (capture=True)
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: vg_rhel-lv_root_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: vg_rhel-lv_root_mount
volume_path=/dev/vg_rhel/lv_root found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname dm-0
kname_is_iscsi: no iscsi disk found for kname sda2
Running command ['mount', '-t', 'xfs', '-o', 'defaults', '/dev/vg_rhel/lv_root', '/tmp/tmpzk179jqj/target/'] with allowed return codes [0] (capture=True)
volspec: path=/dev/vg_rhel/lv_root type=lvm
info[DEVLINKS] = ['/dev/vg_rhel/lv_root', '/dev/disk/by-uuid/377ed463-90cd-4ed4-8909-4c4b28651ace', '/dev/mapper/vg_rhel-lv_root', '/dev/disk/by-id/dm-name-vg_rhel-lv_root', '/dev/disk/by-id/dm-uuid-LVM-LbjJh4zS9z0jTbykd3Q9jPeuTXD1Ql0H1ZpQexUpAZAT5r5X63kfztzOe6uSSJzA']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: vg_rhel-lv_root_mount
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: vg_rhel-lv_home_mount
TIMED udevadm_settle(): 0.055
volume_path=/dev/vg_rhel/lv_home found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname dm-2
Running command ['mount', '-t', 'xfs', '-o', 'defaults', '/dev/vg_rhel/lv_home', '/tmp/tmpzk179jqj/target/home'] with allowed return codes [0] (capture=True)
volspec: path=/dev/vg_rhel/lv_home type=lvm
info[DEVLINKS] = ['/dev/disk/by-uuid/ff2c1a4d-bf18-4a66-83c5-c4c28142d86f', '/dev/disk/by-id/dm-uuid-LVM-LbjJh4zS9z0jTbykd3Q9jPeuTXD1Ql0HiNHe2mmYtKTVp1FGubtn8dp9KNirf2bz', '/dev/mapper/vg_rhel-lv_home', '/dev/vg_rhel/lv_home', '/dev/disk/by-id/dm-name-vg_rhel-lv_home']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: vg_rhel-lv_home_mount
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: vg_rhel-lv_opt_mount
volume_path=/dev/vg_rhel/lv_opt found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname dm-1
Running command ['mount', '-t', 'xfs', '-o', 'defaults', '/dev/vg_rhel/lv_opt', '/tmp/tmpzk179jqj/target/opt'] with allowed return codes [0] (capture=True)
volspec: path=/dev/vg_rhel/lv_opt type=lvm
info[DEVLINKS] = ['/dev/vg_rhel/lv_opt', '/dev/mapper/vg_rhel-lv_opt', '/dev/disk/by-id/dm-name-vg_rhel-lv_opt', '/dev/disk/by-id/dm-uuid-LVM-LbjJh4zS9z0jTbykd3Q9jPeuTXD1Ql0HCb1ZUf110ffFwCYPhkkfusCWQZqTJapN', '/dev/disk/by-uuid/570fbb3d-435d-4017-9120-f9b10424fd1a']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: vg_rhel-lv_opt_mount
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: vg_rhel-lv_var_log_mount
TIMED udevadm_settle(): 0.053
volume_path=/dev/vg_rhel/lv_var_log found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname dm-3
Running command ['mount', '-t', 'xfs', '-o', 'defaults', '/dev/vg_rhel/lv_var_log', '/tmp/tmpzk179jqj/target/var/log'] with allowed return codes [0] (capture=True)
volspec: path=/dev/vg_rhel/lv_var_log type=lvm
info[DEVLINKS] = ['/dev/disk/by-id/dm-name-vg_rhel-lv_var_log', '/dev/disk/by-id/dm-uuid-LVM-LbjJh4zS9z0jTbykd3Q9jPeuTXD1Ql0H5IlCg0StSedbJSTbklUvcclZmnisy1x3', '/dev/vg_rhel/lv_var_log', '/dev/disk/by-uuid/76f15a46-e115-4ba7-b03a-c35c394b8ee6', '/dev/mapper/vg_rhel-lv_var_log']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: vg_rhel-lv_var_log_mount
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: vg_rhel-lv_var_tmp_mount
TIMED udevadm_settle(): 0.054
volume_path=/dev/vg_rhel/lv_var_tmp found slaves: ['sda2']
kname_is_iscsi: no iscsi disk found for kname dm-4
Running command ['mount', '-t', 'xfs', '-o', 'defaults', '/dev/vg_rhel/lv_var_tmp', '/tmp/tmpzk179jqj/target/var/tmp'] with allowed return codes [0] (capture=True)
volspec: path=/dev/vg_rhel/lv_var_tmp type=lvm
info[DEVLINKS] = ['/dev/disk/by-id/dm-name-vg_rhel-lv_var_tmp', '/dev/mapper/vg_rhel-lv_var_tmp', '/dev/vg_rhel/lv_var_tmp', '/dev/disk/by-id/dm-uuid-LVM-LbjJh4zS9z0jTbykd3Q9jPeuTXD1Ql0HsfF6HPD7AmhnBArkB3DklFDljXzO5dLE', '/dev/disk/by-uuid/2411a87d-e69d-4688-8b3d-e27e534dee09']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: vg_rhel-lv_var_tmp_mount
TIMED BLOCK_META: 14.715
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: curtin command block-meta
start: cmd-install/stage-network/builtin/cmd-net-meta: curtin command net-meta
net-meta mode is 'custom'. devices=[]
writing to file /tmp/tmpzk179jqj/state/network_config with network config: network:
ethernets:
eth0:
addresses:
- 192.168.1.62/24
gateway4: 192.168.1.1
match:
macaddress: 00:50:56:be:1b:c8
mtu: 1500
nameservers:
addresses:
- 192.168.1.11
- 192.168.1.12
search:
- maas
set-name: eth0
version: 2
finish: cmd-install/stage-network/builtin/cmd-net-meta: SUCCESS: curtin command net-meta
start: cmd-install/stage-extract/builtin/cmd-extract: curtin command extract
Installing sources: [{'type': 'tgz', 'uri': 'http://192.168.1.39:5248/images/custom/amd64/generic/debian-12/uploaded/root-tgz'}] to target at /tmp/tmpzk179jqj/target
start: cmd-install/stage-extract/builtin/cmd-extract: acquiring and extracting image from http://192.168.1.39:5248/images/custom/amd64/generic/debian-12/uploaded/root-tgz
Running command ['tar', '--help'] with allowed return codes [0] (capture=True)
Running command ['sh', '-cf', 'wget "$1" --progress=dot:mega -O - |smtar -C "$2" --xattrs --xattrs-include=* -Sxpf - --numeric-owner', '--', 'http://192.168.1.39:5248/images/custom/amd64/generic/debian-12/uploaded/root-tgz', '/tmp/tmpzk179jqj/target'] with allowed return codes [0] (capture=False)
--2024-02-06 14:21:57-- http://192.168.1.39:5248/images/custom/amd64/generic/debian-12/uploaded/root-tgz
Connecting to 192.168.1.39:5248... connected.
Length: 422794221 (403M) [application/octet-stream]
Saving to: ‘STDOUT’
0K ........ ........ ........ ........ ........ ........ 0% 19.6M 20s
3072K ........ ........ ........ ........ ........ ........ 1% 60.7M 13s
6144K ........ ........ ........ ........ ........ ........ 2% 41.7M 12s
9216K ........ ........ ........ ........ ........ ........ 2% 28.6M 12s
12288K ........ ........ ........ ........ ........ ........ 3% 38.8M 12s
15360K ........ ........ ........ ........ ........ ........ 4% 62.9M 11s
18432K ........ ........ ........ ........ ........ ........ 5% 61.6M 10s
21504K ........ ........ ........ ........ ........ ........ 5% 58.0M 10s
24576K ........ ........ ........ ........ ........ ........ 6% 60.9M 9s
27648K ........ ........ ........ ........ ........ ........ 7% 60.8M 9s
30720K ........ ........ ........ ........ ........ ........ 8% 60.5M 8s
33792K ........ ........ ........ ........ ........ ........ 8% 66.5M 8s
36864K ........ ........ ........ ........ ........ ........ 9% 64.0M 8s
39936K ........ ........ ........ ........ ........ ........ 10% 64.8M 8s
43008K ........ ........ ........ ........ ........ ........ 11% 64.2M 7s
46080K ........ ........ ........ ........ ........ ........ 11% 49.3M 7s
49152K ........ ........ ........ ........ ........ ........ 12% 23.7M 8s
52224K ........ ........ ........ ........ ........ ........ 13% 23.8M 8s
55296K ........ ........ ........ ........ ........ ........ 14% 24.7M 8s
58368K ........ ........ ........ ........ ........ ........ 14% 24.7M 9s
61440K ........ ........ ........ ........ ........ ........ 15% 23.2M 9s
64512K ........ ........ ........ ........ ........ ........ 16% 23.4M 9s
67584K ........ ........ ........ ........ ........ ........ 17% 23.3M 9s
70656K ........ ........ ........ ........ ........ ........ 17% 24.4M 9s
73728K ........ ........ ........ ........ ........ ........ 18% 24.9M 9s
76800K ........ ........ ........ ........ ........ ........ 19% 25.6M 9s
79872K ........ ........ ........ ........ ........ ........ 20% 12.8M 10s
82944K ........ ........ ........ ........ ........ ........ 20% 42.2M 10s
86016K ........ ........ ........ ........ ........ ........ 21% 30.4M 10s
89088K ........ ........ ........ ........ ........ ........ 22% 28.6M 10s
92160K ........ ........ ........ ........ ........ ........ 23% 26.1M 10s
95232K ........ ........ ........ ........ ........ ........ 23% 24.4M 10s
98304K ........ ........ ........ ........ ........ ........ 24% 25.0M 10s
101376K ........ ........ ........ ........ ........ ........ 25% 27.4M 10s
104448K ........ ........ ........ ........ ........ ........ 26% 22.8M 10s
107520K ........ ........ ........ ........ ........ ........ 26% 28.0M 9s
110592K ........ ........ ........ ........ ........ ........ 27% 25.9M 9s
113664K ........ ........ ........ ........ ........ ........ 28% 22.1M 9s
116736K ........ ........ ........ ........ ........ ........ 29% 12.9M 10s
119808K ........ ........ ........ ........ ........ ........ 29% 29.6M 10s
122880K ........ ........ ........ ........ ........ ........ 30% 31.5M 9s
125952K ........ ........ ........ ........ ........ ........ 31% 28.8M 9s
129024K ........ ........ ........ ........ ........ ........ 31% 52.2M 9s
132096K ........ ........ ........ ........ ........ ........ 32% 45.6M 9s
135168K ........ ........ ........ ........ ........ ........ 33% 38.1M 9s
138240K ........ ........ ........ ........ ........ ........ 34% 35.8M 9s
141312K ........ ........ ........ ........ ........ ........ 34% 33.9M 9s
144384K ........ ........ ........ ........ ........ ........ 35% 24.9M 9s
147456K ........ ........ ........ ........ ........ ........ 36% 26.6M 8s
150528K ........ ........ ........ ........ ........ ........ 37% 27.8M 8s
153600K ........ ........ ........ ........ ........ ........ 37% 27.6M 8s
156672K ........ ........ ........ ........ ........ ........ 38% 19.6M 8s
159744K ........ ........ ........ ........ ........ ........ 39% 29.4M 8s
162816K ........ ........ ........ ........ ........ ........ 40% 26.8M 8s
165888K ........ ........ ........ ........ ........ ........ 40% 28.8M 8s
168960K ........ ........ ........ ........ ........ ........ 41% 34.4M 8s
172032K ........ ........ ........ ........ ........ ........ 42% 16.2M 8s
175104K ........ ........ ........ ........ ........ ........ 43% 15.9M 8s
178176K ........ ........ ........ ........ ........ ........ 43% 18.9M 8s
181248K ........ ........ ........ ........ ........ ........ 44% 32.0M 8s
184320K ........ ........ ........ ........ ........ ........ 45% 19.6M 8s
187392K ........ ........ ........ ........ ........ ........ 46% 39.2M 8s
190464K ........ ........ ........ ........ ........ ........ 46% 23.0M 7s
193536K ........ ........ ........ ........ ........ ........ 47% 32.1M 7s
196608K ........ ........ ........ ........ ........ ........ 48% 27.8M 7s
199680K ........ ........ ........ ........ ........ ........ 49% 30.9M 7s
202752K ........ ........ ........ ........ ........ ........ 49% 33.7M 7s
205824K ........ ........ ........ ........ ........ ........ 50% 31.6M 7s
208896K ........ ........ ........ ........ ........ ........ 51% 29.6M 7s
211968K ........ ........ ........ ........ ........ ........ 52% 31.7M 7s
215040K ........ ........ ........ ........ ........ ........ 52% 29.8M 7s
218112K ........ ........ ........ ........ ........ ........ 53% 26.4M 7s
221184K ........ ........ ........ ........ ........ ........ 54% 25.3M 6s
224256K ........ ........ ........ ........ ........ ........ 55% 29.7M 6s
227328K ........ ........ ........ ........ ........ ........ 55% 34.6M 6s
230400K ........ ........ ........ ........ ........ ........ 56% 33.1M 6s
233472K ........ ........ ........ ........ ........ ........ 57% 31.7M 6s
236544K ........ ........ ........ ........ ........ ........ 58% 28.2M 6s
239616K ........ ........ ........ ........ ........ ........ 58% 28.2M 6s
242688K ........ ........ ........ ........ ........ ........ 59% 20.9M 6s
245760K ........ ........ ........ ........ ........ ........ 60% 19.8M 6s
248832K ........ ........ ........ ........ ........ ........ 61% 29.8M 5s
251904K ........ ........ ........ ........ ........ ........ 61% 28.9M 5s
254976K ........ ........ ........ ........ ........ ........ 62% 30.1M 5s
258048K ........ ........ ........ ........ ........ ........ 63% 31.1M 5s
261120K ........ ........ ........ ........ ........ ........ 63% 28.2M 5s
264192K ........ ........ ........ ........ ........ ........ 64% 30.8M 5s
267264K ........ ........ ........ ........ ........ ........ 65% 29.5M 5s
270336K ........ ........ ........ ........ ........ ........ 66% 16.8M 5s
273408K ........ ........ ........ ........ ........ ........ 66% 15.6M 5s
276480K ........ ........ ........ ........ ........ ........ 67% 22.6M 5s
279552K ........ ........ ........ ........ ........ ........ 68% 23.6M 5s
282624K ........ ........ ........ ........ ........ ........ 69% 25.0M 4s
285696K ........ ........ ........ ........ ........ ........ 69% 23.0M 4s
288768K ........ ........ ........ ........ ........ ........ 70% 23.3M 4s
291840K ........ ........ ........ ........ ........ ........ 71% 22.3M 4s
294912K ........ ........ ........ ........ ........ ........ 72% 20.8M 4s
297984K ........ ........ ........ ........ ........ ........ 72% 25.7M 4s
301056K ........ ........ ........ ........ ........ ........ 73% 26.4M 4s
304128K ........ ........ ........ ........ ........ ........ 74% 19.1M 4s
307200K ........ ........ ........ ........ ........ ........ 75% 23.1M 4s
310272K ........ ........ ........ ........ ........ ........ 75% 21.9M 4s
313344K ........ ........ ........ ........ ........ ........ 76% 26.1M 3s
316416K ........ ........ ........ ........ ........ ........ 77% 26.3M 3s
319488K ........ ........ ........ ........ ........ ........ 78% 26.3M 3s
322560K ........ ........ ........ ........ ........ ........ 78% 18.9M 3s
325632K ........ ........ ........ ........ ........ ........ 79% 20.5M 3s
328704K ........ ........ ........ ........ ........ ........ 80% 24.1M 3s
331776K ........ ........ ........ ........ ........ ........ 81% 25.2M 3s
334848K ........ ........ ........ ........ ........ ........ 81% 24.5M 3s
337920K ........ ........ ........ ........ ........ ........ 82% 25.9M 3s
340992K ........ ........ ........ ........ ........ ........ 83% 26.3M 2s
344064K ........ ........ ........ ........ ........ ........ 84% 24.0M 2s
347136K ........ ........ ........ ........ ........ ........ 84% 16.9M 2s
350208K ........ ........ ........ ........ ........ ........ 85% 23.4M 2s
353280K ........ ........ ........ ........ ........ ........ 86% 19.8M 2s
356352K ........ ........ ........ ........ ........ ........ 87% 15.5M 2s
359424K ........ ........ ........ ........ ........ ........ 87% 21.3M 2s
362496K ........ ........ ........ ........ ........ ........ 88% 20.7M 2s
365568K ........ ........ ........ ........ ........ ........ 89% 20.2M 2s
368640K ........ ........ ........ ........ ........ ........ 90% 26.2M 2s
371712K ........ ........ ........ ........ ........ ........ 90% 23.9M 1s
374784K ........ ........ ........ ........ ........ ........ 91% 17.3M 1s
377856K ........ ........ ........ ........ ........ ........ 92% 24.6M 1s
380928K ........ ........ ........ ........ ........ ........ 93% 22.1M 1s
384000K ........ ........ ........ ........ ........ ........ 93% 23.4M 1s
387072K ........ ........ ........ ........ ........ ........ 94% 21.6M 1s
390144K ........ ........ ........ ........ ........ ........ 95% 24.1M 1s
393216K ........ ........ ........ ........ ........ ........ 95% 18.6M 1s
396288K ........ ........ ........ ........ ........ ........ 96% 30.8M 1s
399360K ........ ........ ........ ........ ........ ........ 97% 29.7M 0s
402432K ........ ........ ........ ........ ........ ........ 98% 22.8M 0s
405504K ........ ........ ........ ........ ........ ........ 98% 29.5M 0s
408576K ........ ........ ........ ........ ........ ........ 99% 21.4M 0s
411648K ........ ........ ... 100% 23.5M=15s
2024-02-06 14:22:12 (26.1 MB/s) - written to stdout [422794221/422794221]
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: acquiring and extracting image from http://192.168.1.39:5248/images/custom/amd64/generic/debian-12/uploaded/root-tgz
Applying write_files from config.
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: curtin command extract
start: cmd-install/stage-curthooks/builtin/cmd-curthooks: curtin command curthooks
Running curtin builtin curthooks
Configuring target system for distro: debian osfamily: debian
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: configuring apt configuring apt
Transferred {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.1.39:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=RBLzVFhKKAZLZ5USkL&oauth_token_key=nWc5vfAwacLppchVY3&oauth_token_secret=24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: RBLzVFhKKAZLZ5USkL\\n endpoint: http://192.168.1.39:5248/MAAS/metadata/status/wcgc3x\\n token_key: nWc5vfAwacLppchVY3\\n token_secret: 24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\\n type: webhook\\n\n'} into new format: {'preserve_sources_list': False, 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports multiverse restricted main universe\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.1.39:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=RBLzVFhKKAZLZ5USkL&oauth_token_key=nWc5vfAwacLppchVY3&oauth_token_secret=24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: RBLzVFhKKAZLZ5USkL\\n endpoint: http://192.168.1.39:5248/MAAS/metadata/status/wcgc3x\\n token_key: nWc5vfAwacLppchVY3\\n token_secret: 24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\\n type: webhook\\n\n'}}
curthooks handling apt to target /tmp/tmpzk179jqj/target with config {'preserve_sources_list': False, 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security multiverse restricted main universe\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports multiverse restricted main universe\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports multiverse restricted main universe\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://192.168.1.39:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=RBLzVFhKKAZLZ5USkL&oauth_token_key=nWc5vfAwacLppchVY3&oauth_token_secret=24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: RBLzVFhKKAZLZ5USkL\\n endpoint: http://192.168.1.39:5248/MAAS/metadata/status/wcgc3x\\n token_key: nWc5vfAwacLppchVY3\\n token_secret: 24WdfzYUYN2WjTDQrEXkSGrN2PmG5k8m\\n type: webhook\\n\n'}}
Running command ['unshare', '--help'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'lsb_release', '--all'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
got primary mirror: None
got security mirror: None
Apt Mirror info: {'PRIMARY': 'http://archive.ubuntu.com/ubuntu/', 'SECURITY': 'http://security.ubuntu.com/ubuntu/', 'MIRROR': 'http://archive.ubuntu.com/ubuntu/'}
Applying debconf selections
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'debconf-set-selections'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'dpkg-query', '--list'] with allowed return codes [0] (capture=True)
unconfiguring cloud-init
cleaning cloud-init config from: ['/tmp/tmpzk179jqj/target/etc/cloud/cloud.cfg.d/90_dpkg.cfg']
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'dpkg-reconfigure', '--frontend=noninteractive', 'cloud-init'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'dpkg-query', '--show', '--showformat', '${Version}', 'cloud-init'] with allowed return codes [0] (capture=True)
Set preserve_sources_list to True in /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg with: {'apt': {'preserve_sources_list': True}}
Running command ['mount', '--bind', '/dev', '/tmp/tmpzk179jqj/target/dev'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/proc', '/tmp/tmpzk179jqj/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/run', '/tmp/tmpzk179jqj/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/sys', '/tmp/tmpzk179jqj/target/sys'] with allowed return codes [0] (capture=False)
Diverting original update-initramfs in target.
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'dpkg-divert', '--add', '--rename', '--divert', '/usr/sbin/update-initramfs.curtin-disabled', '/usr/sbin/update-initramfs'] with allowed return codes [0] (capture=False)
Adding 'local diversion of /usr/sbin/update-initramfs to /usr/sbin/update-initramfs.curtin-disabled'
TIMED subp(['udevadm', 'settle']): 0.025
Running command ['mount', '--make-private', '/tmp/tmpzk179jqj/target/sys'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmpzk179jqj/target/sys'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmpzk179jqj/target/run'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmpzk179jqj/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmpzk179jqj/target/proc'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmpzk179jqj/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmpzk179jqj/target/dev'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmpzk179jqj/target/dev'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: SUCCESS: configuring apt configuring apt
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: installing missing packages
Curtin config dependencies requires additional packages: ['lvm2', 'lvm2', 'xfsprogs']
Skipping install of {'ifenslave', 'vlan', 'bridge-utils'}. Not needed on netplan system.
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: SUCCESS: installing missing packages
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: configuring iscsi service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: SUCCESS: configuring iscsi service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: configuring raid (mdadm) service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: SUCCESS: configuring raid (mdadm) service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: installing kernel
Running command ['dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'lsb_release', '--codename', '--short'] with allowed return codes [0] (capture=True)
Couldn't detect kernel package to install for 5.4.0-170-generic.
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpa9trq_30/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpa9trq_30/sources.list.d', 'update'] with allowed return codes [0] (capture=False)
Ign:1 http://archive.ubuntu.com/ubuntu bookworm InRelease
Ign:2 http://archive.ubuntu.com/ubuntu bookworm-updates InRelease
Ign:3 http://archive.ubuntu.com/ubuntu bookworm-security InRelease
Ign:4 http://archive.ubuntu.com/ubuntu bookworm-backports InRelease
Err:5 http://archive.ubuntu.com/ubuntu bookworm Release
404 Not Found [IP: 185.125.190.39 80]
Err:6 http://archive.ubuntu.com/ubuntu bookworm-updates Release
Err:7 http://archive.ubuntu.com/ubuntu bookworm-security Release
Err:8 http://archive.ubuntu.com/ubuntu bookworm-backports Release
Reading package lists...
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-updates Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-security Release' does not have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu bookworm-backports Release' does not have a Release file.
try 0: command ['apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpa9trq_30/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpa9trq_30/sources.list.d', 'update'] failed, rc: 100
404 Not Found [IP: 185.125.190.36 80]
try 1: command ['apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpa9trq_30/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpa9trq_30/sources.list.d', 'update'] failed, rc: 100
try 2: command ['apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpa9trq_30/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpa9trq_30/sources.list.d', 'update'] failed, rc: 100
TIMED subp(['udevadm', 'settle']): 0.012
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: FAIL: installing kernel
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks
File "/curtin/curtin/commands/curthooks.py", line 397, in install_kernel
map_suffix = mapping[codename][version]
KeyError: 'bookworm'
During handling of the above exception, another exception occurred:
File "/curtin/curtin/commands/main.py", line 202, in main
ret = args.func(args)
File "/curtin/curtin/commands/curthooks.py", line 1918, in curthooks
builtin_curthooks(cfg, target, state)
File "/curtin/curtin/commands/curthooks.py", line 1752, in builtin_curthooks
install_kernel(cfg, target)
File "/curtin/curtin/commands/curthooks.py", line 402, in install_kernel
install(kernel_fallback)
File "/curtin/curtin/commands/curthooks.py", line 362, in install
distro.install_packages([pkg], target=target, env=env)
File "/curtin/curtin/distro.py", line 526, in install_packages
return install_cmd('install', args=pkglist, opts=opts, target=target,
File "/curtin/curtin/distro.py", line 306, in run_apt_command
apt_update(target, env=env, comment=' '.join(cmd))
File "/curtin/curtin/distro.py", line 268, in apt_update
inchroot.subp(update_cmd, env=env, retries=retries)
File "/curtin/curtin/util.py", line 792, in subp
return subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 280, in subp
return _subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 144, in _subp
raise ProcessExecutionError(stdout=out, stderr=err,
Command: ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpzk179jqj/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmpa9trq_30/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmpa9trq_30/sources.list.d', 'update']
Exit code: 100
Reason: -
Stdout: ''
Stderr: ''
Exit code: 100
Reason: -
Stdout: ''
Stderr: ''
curtin: Installation failed with exception: Unexpected error while running command.
Command: ['curtin', 'curthooks']
Exit code: 3
Reason: -
Stdout: start: cmd-install/stage-curthooks/builtin/cmd-curthooks: curtin command curthooks
Exit code: 100
Reason: -
Stdout: ''
Stderr: ''
Exit code: 100
Reason: -
Stdout: ''
Stderr: ''
Stderr: ''
