Custom Storage Silently Failing
I’ve been trying to commission a machine with a custom storage layout but, no matter what I do commisioning always fails. My bash script writes the custom storage json just fine and gets marked as “passed”, but the 50-maas-01-commissioning step fails. It doesn’t contain any error output and only shows a correct looking json in the stdout tab(with my extra storage config present). Any ideas on what could be going wrong here?
I’m using ubuntu24 with maas 3.6.0
Probably the storage config you provided is not valid. I’d suggest to start simple and try a simple configuration according to the docs
I tried copy pasting one of the suggested configs from the tutorial page but get the same error, here’s what i’m currently testing with:
cat > $MAAS_STORAGE_CONFIG_FILE <<'EOF'
  "layout": {
    "sda": {
      "type": "disk",
      "ptable": "gpt",
      "boot": true,
      "partitions": [
          "name": "sda1",
          "fs": "vfat",
          "size": "500M",
          "bootable": true
          "name": "sda2",
          "size": "5G",
          "fs": "ext4"
          "name": "sda3",
          "size": "2G",
          "fs": "swap"
          "name": "sda4",
          "size": "120G",
          "fS": "ext4"
  "mounts": {
      "device": "sda2",
      "options": "noatime"
    "/boot/efi": {
      "device": "sda1"
    "/data": {
      "device": "sda4"
    "none": {
      "device": "sda3"
EOF
any logs in the regiond?
Not seeing anything useful in logs via “journalctl -t maas-rackd -r”. Is there a way to turn up logging levels?
check maas-regiond plz
journalctl -u snap.maas.pebble.service ended up providing the logs I needed.
Turns out the docs have a typo… One of the “fs” keys uses a capital S.
This has been fixed. Sorry for that mistake. Glad you found it.
