Custom Images - Memory Deploy
Hello all,
I’m trying to deploy a custom Ubuntu 22.04 image in memory.
The custom image was generated using the packer at canonical repo: GitHub - canonical/packer-maas: Packer templates to create MAAS deployable images without any modifications, just executed the command make custom-ubuntu.tar.gz
During the boot process, this error was raised:
If I press a key, a grub menu is launched, but nothing works
Images where uploaded through maas cli, with the command:
maas admin boot-resources create name='custom/test-memory-4' title='test memory 4'     architecture='amd64/generic' filetype='tgz' content@=custom-ubuntu.tar.gz`
Looking at logs, we see this error:
If I deploy an ubuntu image provided by maas, everything works as well.
what MAAS version are you using?
Sorry, we are using maas 3.5.7
screenshot of the images page? The commissioning image must be fully synchronized, and from the logs it looks like it is not
I re-run the image creation and upload.
It seems the image was synchronized
can you retry and extract the rackd logs?
I just found this…
Oct 16 19:26:21 maas-rackd02 dhcpd[74085]: DHCPDISCOVER from 00:25:b5:00:00:03 via ens160
Oct 16 19:26:21 maas-rackd02 dhcpd[74085]: DHCPOFFER on 10.107.72.24 to 00:25:b5:00:00:03 via ens160
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[0] = /usr/sbin/maas-dhcp-helper
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[1] = notify
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[2] = --action
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[3] = commit
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[4] = --mac
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[5] = 0:25:b5:0:0:3
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[6] = --ip-family
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[7] = ipv4
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[8] = --ip
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[9] = 10.107.72.24
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[10] = --lease-time
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[11] = 30
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[12] = --hostname
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[13] = (none)
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[14] = --socket
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: execute_statement argv[15] = /var/lib/maas/dhcpd.sock
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: DHCPREQUEST for 10.107.72.24 (10.107.72.11) from 00:25:b5:00:00:03 via ens160
Oct 16 19:26:25 maas-rackd02 dhcpd[74085]: DHCPACK on 10.107.72.24 to 00:25:b5:00:00:03 via ens160
Oct 16 19:26:25 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] bootx64.efi requested by 10.107.72.24
Oct 16 19:26:25 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/bootx64.efi requested by 127.0.0.1
Oct 16 19:26:26 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] grubx64.efi requested by 10.107.72.24
Oct 16 19:26:26 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/grubx64.efi requested by 127.0.0.1
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/x86_64-efi/command.lst requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/grub/x86_64-efi/command.lst requested by 127.0.0.1
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/x86_64-efi/fs.lst requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/grub/x86_64-efi/fs.lst requested by 127.0.0.1
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/x86_64-efi/crypto.lst requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/grub/x86_64-efi/crypto.lst requested by 127.0.0.1
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/x86_64-efi/terminal.lst requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/grub/x86_64-efi/terminal.lst requested by 127.0.0.1
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/grub.cfg requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.tftp: [info] /grub/grub.cfg-00:25:b5:00:00:03 requested by 10.107.72.24
Oct 16 19:26:30 maas-rackd02 rackd[821]: provisioningserver.rackdservices.http: [info] /images/boot-kernel requested by 10.107.72.24
we are running with only one rackd (maas-rackd01), but it was shut down.
@r00ta
I instaslled a new maas 3.5.8 on a single server.
Using the same image…
Same behavior…
See the logs:
Oct 17 10:51:03 router01 maas-log[11957]: maas.node: [info] server01: allocated to user admin
Oct 17 10:51:03 router01 maas-log[11957]: maas.preseed: [info] got bootres <BootResource name=teste-1, arch=amd64/generic, kflavor=None, base=ubuntu/jammy rtype=2>
Oct 17 10:51:03 router01 regiond[11939]: maasserver.preseed: [warn] WARNING: '/etc/maas/preseeds/curtin_userdata_custom' contains deprecated preseed variables. Please remove: main_archive_directory, ports_archive_directory
Oct 17 10:51:03 router01 maas-log[11957]: maas.node: [info] server01: Status transition from ALLOCATED to DEPLOYING
Oct 17 10:51:04 router01 regiond[11939]: maasserver.dhcp: [info] Successfully configured DHCPv4 on rack controller 'router01 (dxspcq)'.
Oct 17 10:51:04 router01 regiond[11939]: maasserver.dhcp: [info] Successfully configured DHCPv6 on rack controller 'router01 (dxspcq)'.
Oct 17 10:51:07 router01 named[859]: client @0x702e3001e7a8 127.0.0.1#35461/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e3001e7a8 127.0.0.1#35461/key maas: updating zone 'maas/IN': adding an RR at 'server01.maas' A 172.16.3.6
Oct 17 10:51:07 router01 named[859]: client @0x702e3001e7a8 127.0.0.1#35461/key maas: updating zone 'maas/IN': deleting an RR at server01.maas A
Oct 17 10:51:07 router01 named[859]: client @0x702e3001e7a8 127.0.0.1#35461/key maas: updating zone 'maas/IN': adding an RR at 'maas' SOA maas. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: client @0x702e38006d78 127.0.0.1#37727/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e38006d78 127.0.0.1#37727/key maas: updating zone 'lab.int/IN': adding an RR at 'lab.int' SOA lab.int. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone lab.int/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e30009578 127.0.0.1#36464/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e30009578 127.0.0.1#36464/key maas: updating zone 'maas-internal/IN': adding an RR at 'maas-internal' SOA maas-internal. nobody.example.com. 221 600 1800 604800 15
Oct 17 10:51:07 router01 named[859]: zone maas-internal/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e3c012308 127.0.0.1#54529/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e3c012308 127.0.0.1#54529/key maas: updating zone '0.168.192.in-addr.arpa/IN': adding an RR at '0.168.192.in-addr.arpa' SOA 0.168.192.in-addr.arpa. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone 0.168.192.in-addr.arpa/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e4802b708 127.0.0.1#43049/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e4802b708 127.0.0.1#43049/key maas: updating zone '0.16.172.in-addr.arpa/IN': adding an RR at '0.16.172.in-addr.arpa' SOA 0.16.172.in-addr.arpa. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone 0.16.172.in-addr.arpa/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e3c012308 127.0.0.1#53519/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e3c012308 127.0.0.1#53519/key maas: updating zone '1.16.172.in-addr.arpa/IN': adding an RR at '1.16.172.in-addr.arpa' SOA 1.16.172.in-addr.arpa. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone 1.16.172.in-addr.arpa/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e30009578 127.0.0.1#40432/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e30009578 127.0.0.1#40432/key maas: updating zone '2.16.172.in-addr.arpa/IN': adding an RR at '2.16.172.in-addr.arpa' SOA 2.16.172.in-addr.arpa. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone 2.16.172.in-addr.arpa/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 named[859]: client @0x702e38018f48 127.0.0.1#33903/key maas: signer "maas" approved
Oct 17 10:51:07 router01 named[859]: client @0x702e38018f48 127.0.0.1#33903/key maas: updating zone '3.16.172.in-addr.arpa/IN': adding an RR at '6.3.16.172.in-addr.arpa' PTR server01.maas.
Oct 17 10:51:07 router01 named[859]: client @0x702e38018f48 127.0.0.1#33903/key maas: updating zone '3.16.172.in-addr.arpa/IN': deleting an RR at 6.3.16.172.in-addr.arpa PTR
Oct 17 10:51:07 router01 named[859]: client @0x702e38018f48 127.0.0.1#33903/key maas: updating zone '3.16.172.in-addr.arpa/IN': adding an RR at '3.16.172.in-addr.arpa' SOA 3.16.172.in-addr.arpa. nobody.example.com. 221 600 1800 604800 30
Oct 17 10:51:07 router01 named[859]: zone 3.16.172.in-addr.arpa/IN: sending notifies (serial 221)
Oct 17 10:51:07 router01 regiond[11939]: maasserver.dhcp: [info] Successfully configured DHCPv4 on rack controller 'router01 (dxspcq)'.
Oct 17 10:51:07 router01 regiond[11939]: maasserver.dhcp: [info] Successfully configured DHCPv6 on rack controller 'router01 (dxspcq)'.
Oct 17 10:51:09 router01 regiond[11855]: maasserver.region_controller: [info] Reloaded DNS configuration; ip 172.16.3.6 allocated
Oct 17 10:51:46 router01 dhcpd[15183]: DHCPDISCOVER from 20:12:13:68:09:5a via enp5s0
Oct 17 10:51:46 router01 dhcpd[15183]: DHCPOFFER on 172.16.3.6 to 20:12:13:68:09:5a via enp5s0
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[0] = /usr/sbin/maas-dhcp-helper
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[1] = notify
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[2] = --action
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[3] = commit
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[4] = --mac
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[5] = 20:12:13:68:9:5a
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[6] = --ip-family
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[7] = ipv4
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[8] = --ip
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[9] = 172.16.3.6
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[10] = --lease-time
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[11] = 30
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[12] = --hostname
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[13] = (none)
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[14] = --socket
Oct 17 10:51:54 router01 dhcpd[15183]: execute_statement argv[15] = /var/lib/maas/dhcpd.sock
Oct 17 10:51:54 router01 dhcpd[15183]: DHCPREQUEST for 172.16.3.6 (172.16.0.1) from 20:12:13:68:09:5a via enp5s0
Oct 17 10:51:54 router01 dhcpd[15183]: DHCPACK on 172.16.3.6 to 20:12:13:68:09:5a via enp5s0
Oct 17 10:51:54 router01 rackd[11854]: provisioningserver.rackdservices.tftp: [info] lpxelinux.0 requested by 172.16.3.6
Oct 17 10:51:54 router01 rackd[11854]: provisioningserver.rackdservices.http: [info] /images/lpxelinux.0 requested by 127.0.0.1
Oct 17 10:51:54 router01 maas-log[11957]: maas.interface: [info] enp5s0 (physical) on router01: New MAC, IP binding observed: 20:12:13:68:09:5a, 172.16.3.6
Oct 17 10:51:54 router01 regiond[11939]: maasserver.rpc.leases: [info] Lease update: commit for 172.16.3.6 on 20:12:13:68:09:5a at 2025-10-17 10:51:54 (lease time: 30s)
Oct 17 10:51:57 router01 rackd[11854]: provisioningserver.rackdservices.http: [info] ldlinux.c32 requested by 172.16.3.6
Oct 17 10:51:57 router01 rackd[11854]: provisioningserver.rackdservices.http: [info] /images/ldlinux.c32 requested by 127.0.0.1
Oct 17 10:51:57 router01 rackd[11854]: provisioningserver.rackdservices.http: [info] pxelinux.cfg/01-20-12-13-68-09-5a requested by 172.16.3.6
Oct 17 10:51:57 router01 maas-log[11957]: maas.rpc.boot: [warn] failed to compute a bootable amd64/ga-22.04 system for custom/teste-1
Oct 17 10:51:57 router01 rackd[11854]: provisioningserver.rackdservices.http: [info] /images/boot-kernel requested by 172.16.3.6
Oct 17 10:51:57 router01 maas-log[11957]: maas.node: [info] server01: Status transition from DEPLOYING to FAILED_DEPLOYMENT
Oct 17 10:51:58 router01 maas-log[11957]: maas.node: [info] server01: Status transition from DEPLOYING to FAILED_DEPLOYMENT
Oct 17 10:51:58 router01 maas-log[11957]: maas.node: [error] server01: Marking node failed: Missing boot image ubuntu/amd64/ga-22.04/jammy.
Oct 17 10:51:58 router01 regiond[11939]: regiond: [info] 127.0.0.1 GET /MAAS/rpc/ HTTP/1.1 --> 200 OK (referrer: -; agent: provisioningserver.rpc.clusterservice.ClusterClientService)
@r00ta another test. This time I installed a new maas using snap, on version 3.6.2. Same image, same behavior.
2025-10-17T17:27:28Z maas-log[3405]: maas.node: [info] equal-osprey: allocated to user admin
2025-10-17T17:27:28Z maas-log[3405]: maas.preseed: [info] got bootres <BootResource name=teste-1, alias=None, arch=amd64/generic, kflavor=None, base=ubuntu/noble rtype=2>
2025-10-17T17:27:28Z maas-regiond[3364]: maasserver.preseed: [warn] WARNING: '/snap/maas/40614/etc/maas/preseeds/curtin_userdata_custom' contains deprecated preseed variables. Please remove: main_archive_directory, ports_archive_directory
2025-10-17T17:27:28Z maas-log[3405]: maas.node: [info] equal-osprey: Status transition from ALLOCATED to DEPLOYING
2025-10-17T17:27:28Z maas.pebble[3249]: 2025-10-17T17:27:28.403Z [pebble] GET /v1/services?names=dhcpd 72.088µs 200
2025-10-17T17:27:28Z maas-regiond[3364]: maasserver.dhcp: [info] Successfully configured DHCPv4 on rack controller 'maas (b67pfd)'.
2025-10-17T17:27:28Z maas.pebble[3249]: 2025-10-17T17:27:28.406Z [pebble] GET /v1/services?names=dhcpd6 81.477µs 200
2025-10-17T17:27:28Z maas-regiond[3364]: maasserver.dhcp: [info] Successfully configured DHCPv6 on rack controller 'maas (b67pfd)'.
2025-10-17T17:27:31Z maas-temporal-worker[3374]: {"message": "Starting workflow DeployManyWorkflow.run", "taskName": "run (workflow: deploy-many, id: f96c6ef0-b646-4d12-97bc-0091bacdd628, run: 4d512c60-eaba-4149-ae07-633c11fc0012)", "context_id": "20609e1e-a670-4019-b8cc-35df1ab67eb6", "timestamp": "2025-10-17T17:27:31.378261Z", "logger": "maastemporalworker.workflow.utils:51", "level": "INFO", "thread": "temporal_workflow__0:133810175866560"}
2025-10-17T17:27:31Z maas-temporal-worker[3374]: {"message": "Starting workflow DeployWorkflow.run", "taskName": "run (workflow: deploy, id: deploy:sk6fqk, run: 281c9f5e-72d2-485f-97d1-28bf67d74185)", "context_id": "99ac6ed2-dd69-455f-a7aa-8c7565f3a16d", "timestamp": "2025-10-17T17:27:31.433174Z", "logger": "maastemporalworker.workflow.utils:51", "level": "INFO", "thread": "temporal_workflow__0:133810175866560"}
2025-10-17T17:27:31Z maas.pebble[3249]: 2025-10-17T17:27:31.502Z [pebble] GET /v1/services?names=dhcpd 172.198µs 200
2025-10-17T17:27:31Z maas.pebble[3249]: 2025-10-17T17:27:31.505Z [pebble] GET /v1/services?names=dhcpd 39.638µs 200
2025-10-17T17:27:31Z maas-regiond[3364]: maasserver.dhcp: [info] Successfully configured DHCPv4 on rack controller 'maas (b67pfd)'.
2025-10-17T17:27:31Z maas.pebble[3249]: 2025-10-17T17:27:31.518Z [pebble] GET /v1/services?names=dhcpd6 40.641µs 200
2025-10-17T17:27:31Z maas-regiond[3364]: maasserver.dhcp: [info] Successfully configured DHCPv6 on rack controller 'maas (b67pfd)'.
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.524 client @0x7d26c0023ba8 127.0.0.1#46007/key maas: signer "maas" approved
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.527 client @0x7d26c0023ba8 127.0.0.1#46007/key maas: updating zone 'maas/IN': adding an RR at 'equal-osprey.maas' A 172.16.32.4
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.527 client @0x7d26c0023ba8 127.0.0.1#46007/key maas: updating zone 'maas/IN': deleting an RR at equal-osprey.maas A
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.527 client @0x7d26c0023ba8 127.0.0.1#46007/key maas: updating zone 'maas/IN': adding an RR at 'maas' SOA maas. nobody.example.com. 74 600 1800 604800 30
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.562 client @0x7d26c806de78 127.0.0.1#42884/key maas: signer "maas" approved
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.562 client @0x7d26c806de78 127.0.0.1#42884/key maas: updating zone 'maas-internal/IN': adding an RR at 'maas-internal' SOA maas-internal. nobody.example.com. 74 600 1800 604800 15
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.574 zone maas-internal/IN: sending notifies (serial 74)
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.591 client @0x7d26c004ea68 127.0.0.1#37188/key maas: signer "maas" approved
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.591 client @0x7d26c004ea68 127.0.0.1#37188/key maas: updating zone '0.168.192.in-addr.arpa/IN': adding an RR at '0.168.192.in-addr.arpa' SOA 0.168.192.in-addr.arpa. nobody.example.com. 74 600 1800 604800 30
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.609 zone 0.168.192.in-addr.arpa/IN: sending notifies (serial 74)
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.632 client @0x7d26c9b940e8 127.0.0.1#40869/key maas: signer "maas" approved
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.632 client @0x7d26c9b940e8 127.0.0.1#40869/key maas: updating zone '32.16.172.in-addr.arpa/IN': adding an RR at '4.32.16.172.in-addr.arpa' PTR equal-osprey.maas.
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.632 client @0x7d26c9b940e8 127.0.0.1#40869/key maas: updating zone '32.16.172.in-addr.arpa/IN': deleting an RR at 4.32.16.172.in-addr.arpa PTR
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.632 client @0x7d26c9b940e8 127.0.0.1#40869/key maas: updating zone '32.16.172.in-addr.arpa/IN': adding an RR at '32.16.172.in-addr.arpa' SOA 32.16.172.in-addr.arpa. nobody.example.com. 74 600 1800 604800 30
2025-10-17T17:27:31Z named[5627]: 17-Oct-2025 17:27:31.637 zone 32.16.172.in-addr.arpa/IN: sending notifies (serial 74)
2025-10-17T17:27:33Z maas-agent[3828]: ERR Activity error. ActivityType=power-on Attempt=1 Error="BMC is in the wrong power state" Namespace=default RunID=281c9f5e-72d2-485f-97d1-28bf67d74185 TaskQueue=b67pfd@agent:power WorkerID=b67pfd@agent:3828 WorkflowID=deploy:sk6fqk
2025-10-17T17:27:33Z maas-regiond[3286]: maasserver.region_controller: [info] Reloaded DNS configuration; ip 172.16.32.4 allocated
2025-10-17T17:27:34Z maas-agent[3828]: ERR Activity error. ActivityType=power-on Attempt=2 Error="BMC is in the wrong power state" Namespace=default RunID=281c9f5e-72d2-485f-97d1-28bf67d74185 TaskQueue=b67pfd@agent:power WorkerID=b67pfd@agent:3828 WorkflowID=deploy:sk6fqk
2025-10-17T17:27:37Z maas-agent[3828]: ERR Activity error. ActivityType=power-on Attempt=3 Error="BMC is in the wrong power state" Namespace=default RunID=281c9f5e-72d2-485f-97d1-28bf67d74185 TaskQueue=b67pfd@agent:power WorkerID=b67pfd@agent:3828 WorkflowID=deploy:sk6fqk
2025-10-17T17:27:42Z maas-agent[3828]: ERR Activity error. ActivityType=power-on Attempt=4 Error="BMC is in the wrong power state" Namespace=default RunID=281c9f5e-72d2-485f-97d1-28bf67d74185 TaskQueue=b67pfd@agent:power WorkerID=b67pfd@agent:3828 WorkflowID=deploy:sk6fqk
2025-10-17T17:27:42Z dhcpd[4038]: DHCPDISCOVER from 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:42Z dhcpd[4038]: DHCPOFFER on 172.16.32.4 to 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:43Z maas.pebble[3249]: 2025-10-17T17:27:43.094Z [pebble] GET /v1/services?names=dhcpd6 46.481µs 200
2025-10-17T17:27:43Z maas.pebble[3249]: 2025-10-17T17:27:43.095Z [pebble] GET /v1/services?names=dhcpd 17.016µs 200
2025-10-17T17:27:43Z maas.pebble[3249]: 2025-10-17T17:27:43.095Z [pebble] GET /v1/services?names=agent 9.792µs 200
2025-10-17T17:27:43Z maas.pebble[3249]: 2025-10-17T17:27:43.095Z [pebble] GET /v1/services?names=http 30.197µs 200
2025-10-17T17:27:43Z dhcpd[4038]: DHCPDISCOVER from 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:43Z dhcpd[4038]: DHCPOFFER on 172.16.32.4 to 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=temporal-worker 49.155µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=temporal 11.715µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=http 9.497µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=syslog 7.772µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=ntp 7.696µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.415Z [pebble] GET /v1/services?names=bind9 10.035µs 200
2025-10-17T17:27:44Z maas.pebble[3249]: 2025-10-17T17:27:44.417Z [pebble] GET /v1/services?names=proxy 31.274µs 200
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[0] = /snap/maas/40614/usr/sbin/maas-dhcp-helper
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[1] = notify
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[2] = --action
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[3] = commit
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[4] = --mac
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[5] = 8:0:27:c4:2a:92
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[6] = --ip-family
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[7] = ipv4
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[8] = --ip
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[9] = 172.16.32.4
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[10] = --lease-time
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[11] = 30
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[12] = --hostname
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[13] = (none)
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[14] = --socket
2025-10-17T17:27:45Z dhcpd[4038]: execute_statement argv[15] = /var/snap/maas/common/maas/dhcpd.sock
2025-10-17T17:27:45Z dhcpd[4038]: DHCPREQUEST for 172.16.32.4 (172.16.32.1) from 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:45Z dhcpd[4038]: DHCPACK on 172.16.32.4 to 08:00:27:c4:2a:92 via enp0s8
2025-10-17T17:27:45Z maas-log[3405]: maas.interface: [info] enp0s8 (physical) on maas: New MAC, IP binding observed: 08:00:27:c4:2a:92, 172.16.32.4
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] ipxe.cfg requested by 172.16.32.4
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:45 +0000] "GET /ipxe.cfg HTTP/1.1" 200 233 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] ipxe.cfg-08:00:27:c4:2a:92 requested by 172.16.32.4
2025-10-17T17:27:45Z maas-log[3405]: maas.rpc.boot: [warn] failed to compute a bootable amd64/ga-24.04 system for custom/teste-1
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:45 +0000] "GET /ipxe.cfg-08:00:27:c4:2a:92 HTTP/1.1" 200 467 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] /images/boot-kernel requested by 172.16.32.4
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.1 - - [17/Oct/2025:17:27:45 +0000] "GET /MAAS/boot-resources/boot-kernel HTTP/1.1" 404 134 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:45 +0000] "GET /images/boot-kernel HTTP/1.1" 404 173 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] ipxe.cfg-default-amd64 requested by 172.16.32.4
2025-10-17T17:27:45Z maas-log[3405]: maas.node: [info] equal-osprey: Status transition from DEPLOYING to FAILED_DEPLOYMENT
2025-10-17T17:27:45Z maas-log[3405]: maas.node: [error] equal-osprey: Marking node failed: Missing boot image ubuntu/amd64/ga-24.04/noble.
2025-10-17T17:27:45Z maas-temporal-worker[3374]: {"message": "Workflow has completed", "taskName": "run (workflow: deploy-many, id: f96c6ef0-b646-4d12-97bc-0091bacdd628, run: 4d512c60-eaba-4149-ae07-633c11fc0012)", "elapsed_time_seconds": 14.499726057052612, "context_id": "20609e1e-a670-4019-b8cc-35df1ab67eb6", "timestamp": "2025-10-17T17:27:45.877980Z", "logger": "maastemporalworker.workflow.utils:53", "level": "INFO", "thread": "temporal_workflow__0:133810175866560"}
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:45 +0000] "GET /ipxe.cfg-default-amd64 HTTP/1.1" 200 616 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] /images/9a674ed/ubuntu/amd64/ga-22.04/jammy/stable/boot-kernel requested by 172.16.32.4
2025-10-17T17:27:45Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:45 +0000] "GET /images/9a674ed/ubuntu/amd64/ga-22.04/jammy/stable/boot-kernel HTTP/1.1" 200 11710472 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:45Z maas-rackd[3291]: provisioningserver.rackdservices.http: [info] /images/7388520/ubuntu/amd64/ga-22.04/jammy/stable/boot-initrd requested by 172.16.32.4
2025-10-17T17:27:46Z maas-http[3405]:  172.16.32.4 - - [17/Oct/2025:17:27:46 +0000] "GET /images/7388520/ubuntu/amd64/ga-22.04/jammy/stable/boot-initrd HTTP/1.1" 200 115868197 "-" "iPXE/1.21.1+ (g5c49e)"
2025-10-17T17:27:49Z maas-apiserver[3290]: {"message": "Start processing request", "taskName": "Task-1918", "request_method": "POST", "request_path": "/MAAS/a/v3internal/leases", "request_query": "", "request_remote_ip": null, "context_id": "3045b44d-1b88-4f61-90a3-9eba8897ea2b", "timestamp": "2025-10-17T17:27:49.158919Z", "logger": "maasapiserver.v3.middlewares.context:34", "level": "INFO", "thread": "MainThread:139694884775744"}
2025-10-17T17:27:49Z maas-apiserver[3290]: {"message": "Lease update: commit for 172.16.32.4 on 08:00:27:c4:2a:92 at 2025-10-17 17:27:45 (lease time: 30s)", "taskName": "starlette.middleware.base.BaseHTTPMiddleware.__call__.<locals>.call_next.<locals>.coro", "context_id": "3045b44d-1b88-4f61-90a3-9eba8897ea2b", "timestamp": "2025-10-17T17:27:49.162463Z", "logger": "maasservicelayer.services.leases:83", "level": "INFO", "thread": "MainThread:139694884775744"}
2025-10-17T17:27:49Z maas-apiserver[3290]: {"message": "End processing request", "taskName": "Task-1918", "status_code": 204, "elapsed_time_seconds": 0.005640268325805664, "context_id": "3045b44d-1b88-4f61-90a3-9eba8897ea2b", "timestamp": "2025-10-17T17:27:49.164523Z", "logger": "maasapiserver.v3.middlewares.context:43", "level": "INFO", "thread": "MainThread:139694884775744"}
@r00ta any news about this?
Sorry I’m actually busy with some other stuff, I might be able to try that in the next days
I think you are missing pointing the base image used for the custom image (base option in the maas upload command).
Hi @andre-ruiz are you talking about the option base_image=ubuntu/jammy in boot-resources create ?
For example:
maas admin boot-resources create name='custom/test-memory-4' title='test memory 4'     architecture='amd64/generic' filetype='tgz' base_image=ubuntu/jammy  content@=custom-ubuntu.tar.gz
If it was, I tested in versions: 3.5.7 and 3.6.2. Same error.
BTW, If I install the same image on disk, everythings works…
Fixed in MaaS 3.5.10.
