Custom images, kernels, and tags
Welcome to the section dedicated to customizing your MAAS environment with custom images, specialized kernels, and efficient tag management. Here, you’ll find comprehensive guides to help you tailor your infrastructure to meet your specific operational needs.
Customizing images
Creating and managing custom images allows you to deploy tailored environments that meet your exact specifications.
Deploying specialized kernels
Deploy specialized kernels to enhance performance and meet specific operational requirements.
Managing tags
Efficiently manage your MAAS environment by using tags to organize and categorize resources.
Use the links above to navigate to the specific guides you need. Each guide provides detailed instructions to help you customize and optimize your MAAS environment effectively.
Hi Bill, this page is referred to in the navigation sidebar as “Building kernels”; it was unclear to me that building custom images was also found under this section. Would it be possible to use “Building custom images” instead?
