Hello all,
I’m trying to get Debian to work with MAAS.
I’ve tried these instructions with no luck:
https://askubuntu.com/questions/882911/how-do-i-use-maas-to-create-a-debian-image
Download a debian cloud image in raw format.
Mount the image
sudo mkdir /mnt/loop
sudo mount -o ro,loop,offset=1048576 <nameofdebianimage.raw> /mnt/loop
Convert to a gzipped tarball
cd /mnt/loop
sudo tar czvf ~/debian.tgz .
sudo umount /mnt/loop
Upload this to maas
cd ~
maas login your.user http://<maasserver>:5240/MAAS 'user:credentials'
maas your.user boot-resources create name=custom/debian title="debian" architecture=amd64/generic content@=debian.tgz
Edit /etc/maas/preseeds/curtin_userdata_custom and add the following at the top after the comment line and before debconf_selections to override the kernel to install:
kernel:
fallback-package: linux-image-amd64
any ideas on this?
Debian image downloaded from here:
http://cdimage.debian.org/cdimage/openstack/current/debian-9.5.6-20181013-openstack-arm64.raw
