Full stacktrace:
The above exception was the direct cause of the following exception:
File "/snap/maas/32469/bin/maas-region", line 8, in <module>
sys.exit(run())
File "/snap/maas/32469/lib/python3.10/site-packages/maasserver/region_script.py", line 81, in run
run_django(is_snap, is_devenv)
File "/snap/maas/32469/lib/python3.10/site-packages/maasserver/region_script.py", line 70, in run_django
management.execute_from_command_line()
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 419, in execute_from_command_line
utility.execute()
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 413, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/base.py", line 354, in run_from_argv
self.execute(*args, **cmd_options)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/base.py", line 398, in execute
output = self.handle(*args, **options)
File "/snap/maas/32469/lib/python3.10/site-packages/maasserver/management/commands/dbupgrade.py", line 125, in handle
call_command(
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 181, in call_command
return command.execute(*args, **defaults)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/base.py", line 89, in wrapped
res = handle_func(*args, **kwargs)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/core/management/commands/migrate.py", line 244, in handle
post_migrate_state = executor.migrate(
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 117, in migrate
state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_initial=fake_initial)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 147, in _migrate_all_forwards
state = self.apply_migration(state, migration, fake=fake, fake_initial=fake_initial)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 227, in apply_migration
state = migration.apply(state, schema_editor)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/migrations/migration.py", line 126, in apply
operation.database_forwards(self.app_label, schema_editor, old_state, project_state)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/migrations/operations/fields.py", line 244, in database_forwards
schema_editor.alter_field(from_model, from_field, to_field)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 608, in alter_field
self._alter_field(model, old_field, new_field, old_type, new_type,
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/postgresql/schema.py", line 196, in _alter_field
super()._alter_field(
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 765, in _alter_field
self.execute(
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 145, in execute
cursor.execute(sql, params)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 66, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 75, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 79, in _execute
with self.db.wrap_database_errors:
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/utils.py", line 90, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
File "/snap/maas/32469/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 84, in _execute
return self.cursor.execute(sql, params)
django.db.utils.ProgrammingError: default for column "extra" cannot be cast automatically to type jsonb
File "/snap/maas/32469/bin/maas", line 8, in <module>
sys.exit(main())
File "/snap/maas/32469/lib/python3.10/site-packages/maascli/__init__.py", line 39, in main
options.execute(options)
File "/snap/maas/32469/lib/python3.10/site-packages/maascli/snap.py", line 481, in __call__
raise exc
File "/snap/maas/32469/lib/python3.10/site-packages/maascli/snap.py", line 478, in __call__
self.handle(options)
File "/snap/maas/32469/lib/python3.10/site-packages/maascli/snap.py", line 1037, in handle
sys.exit(migrate_db())
File "/snap/maas/32469/lib/python3.10/site-packages/maascli/snap.py", line 386, in migrate_db
subprocess.check_call(
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/snap/maas/32469/bin/maas-region', 'dbupgrade']' returned non-zero exit status 1.
