I have this issue in my test env.
Controllers have different versions error pops up.
The leading 1: in front of the version randomly appears and dissapears.
That was supposed to have been fixed in 3.2 Controllers have different versions. Perhaps a regression?
Yes, I saw that also. I have this issue with latest deb version and had it with N-1 as well. Decided to bring this up here as I updated everything today and this issues still exists. Seems to be more of an annoyance than having real impact, but nevertheless, it’s there.
Hi @mitzone
So this happens only with deb version of MAAS? Did you have a chance to check if the same issue exists if MAAS installed via snap?
Also, may I ask you to file a bug report at https://bugs.launchpad.net/maas?
I have the same issue on 3.3.4
regiond versions:
ii maas-cli 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS client and command-line interface
ii maas-common 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS server common files
ii maas-proxy 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS Caching Proxy
ii maas-region-api 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all Region controller API service for MAAS
ii maas-region-controller 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all Region Controller for MAAS
ii python3-django-maas 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS server Django web framework (Python 3)
ii python3-maas-client 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS python API client (Python 3)
ii python3-maas-provisioningserver 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS server provisioning libraries (Python 3)
rackd versions
ii maas-dhcp 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all MAAS DHCP server
ii maas-rack-controller 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all Rack Controller for MAAS
The same issue with:
ii maas 1:3.3.4-13189-g.f88272d1e-0ubuntu1~22.04.1 all "Metal as a Service" is a physical cloud and IPAM
Same issue with latest 3.4.2
MAAS UI
Region and Rack controller
ii maas 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all "Metal as a Service" is a physical cloud and IPAM
ii maas-cli 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS client and command-line interface
ii maas-common 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS server common files
ii maas-dhcp 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS DHCP server
ii maas-netmon 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 amd64 MAAS Network Monitor
ii maas-proxy 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS Caching Proxy
ii maas-rack-controller 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all Rack Controller for MAAS
ii maas-region-api 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all Region controller API service for MAAS
ii maas-region-controller 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all Region Controller for MAAS
ii python3-django-maas 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS server Django web framework (Python 3)
ii python3-maas-client 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS python API client (Python 3)
ii python3-maas-provisioningserver 1:3.4.2-14353-g.5a5221d57-0ubuntu1~22.04.1 all MAAS server provisioning libraries (Python 3)
