I understand MAAS don’t accept Merge requests on Github.
What would be the best way to provide some patches / updates for MAAS ?
I would like to provide a fix for Bug #2069059 “Ubuntu 24.04 doesn't deploy on any ARM64 machine” : Bugs : MAAS
Thanks
r00ta
9 July 2024 14:53
2
The code lives here Git : Code : MAAS
And I suggest to look at HACKING.rst
r00ta:
Git : Code : MAAS
Thanks @r00ta
I have pushed my changes here - ~rathore4u/maas - [no description] but not sure how to submit it for review / merging.
Thanks
r00ta
10 July 2024 10:01
4
you can do it here https://code.launchpad.net/~rathore4u/maas/+git/maas/+ref/fix/LP2069059/+register-merge .
However it’s required to implement unit tests and run the entire test suite locally to check if you broke anything (you’d better do it locally because you won’t be able to see the output of the internal pipeline with the test run)
Also, a manual e2e is required for such a change.
Last but not least, you have to sign the CLA Contributor licence agreement | Ubuntu
Thanks for the details.
I have now submitted a MP and signed the CLA
MP - Merge into 3.5 : fix/LP2069059 : lp:~rathore4u/maas : Git : Code : MAAS
@r00ta
As an enhancement, maybe it will be helpful if the build log is posted to some pastebin service maybe like https://paste.ubuntu.com/
That would allow contributors like me to see the log and figure out whats going wrong.
r00ta
11 July 2024 11:47
7
Yeah I know. Unfortunately given the very few amount of community contributions we get we don’t have capacity to improve that right now.
However that pipeline is not doing anything fancy. All it does is
make lint
make test
So you should easily check it by yourself locally before pushing the commit
Thanks for confirming.
TBH, I had issues setting up my dev environment as I am running 24.04.
Using a 22.04 docker container but things aren’t 100% as expected.
@r00ta
If you guys think of implementing the pastebin thingy I just tried
make lint 2>&1 | tee build.log
make test 2>&1 | tee -a build.log
URL=$(cat build.log | nc termbin.com 9999)
echo "Build log url : $URL"
system
Closed
13 July 2024 22:25
10
