Config-vault
The config-vault command is used to integrate HashiCorp Vault for secure secrets management. This integration enhances security by storing sensitive information, such as credentials and keys, outside the MAAS database in a dedicated secrets management system.
Key functions
  • Configuration: Sets up the connection between MAAS and Vault by specifying parameters like the Vault URL, AppRole ID, wrapped token, secrets path, and mount point.
  • Migration: Transfers existing secrets from the MAAS database to Vault, ensuring they are securely stored.
Integration steps
  1. Prepare Vault
    • Enable the approle authentication method and KV secrets engine in Vault.
    • Create a policy granting MAAS the necessary permissions.
    • Generate a role ID and a wrapped secret ID for MAAS authentication.
  2. Configure MAAS
    • On each region controller, run:
      sudo maas config-vault configure $URL $APPROLE_ID $WRAPPED_TOKEN $SECRETS_PATH --secrets-mount $SECRET_MOUNT
      Replace the placeholders with your Vault details.
  3. Migrate secrets
    • After configuring all region controllers, execute on one:
      sudo maas config-vault migrate
      This moves secrets from the MAAS database to Vault.
Benefits of integration
  • Enhanced Security: Secrets are stored in Vault’s encrypted storage, reducing exposure.
  • Centralized Management: Consolidates secret storage, simplifying audits and compliance.
  • Access Control: Utilizes Vault’s robust policies to control access to secrets.
Integrating MAAS with HashiCorp Vault using the config-vault command ensures that sensitive information is securely managed, aligning with best practices for infrastructure security.
