I started setting up a home lab using cheap WiFi smart plugs as PDU with a custom power driver for x86 thin clients. I’d love to get that merged in time for MAAS 2.9. Any sponsors out there?
I have ordered some Raspberry PI 4 and would love to use ESPs as PDU with a small state machine to achieve soft power off with a hard timeout.
Does hooking an ESP8266 to the 40-pin header for
- 3.3V power (pin 1),
- ground (e.g. pin 6),
- gpio-shutdown (pull pin 5 from up to down to initiate shutdown),
- gpio-poweroff (pin 26 transitions from low to high at the end of the shutdown)
and adding a state machine - with a watchdog timer for hard power off - to turn the simple “on/off” signal from MAAS into a “proper PDU” sound like a workable plan?
I’m still scratching my head about the chicken/egg issue with the RPI powering the ESP that will cut it’s power. I think I’ll end up with a separate 5V+3.3V PSU that powers both devices.
