When i commission with 18.04 it’s working good.
But when i use 20.04 it failed
vm log : https://pastebin.pl/view/ada2b225
It stopped right after the last line:
2021-02-03T16:10:39+00:00 vm02 systemd-resolved[541]: Using degraded feature set (TCP) for DNS server fe80::216:3eff:fe09:5011%2.
2021-02-03T16:10:39+00:00 vm02 systemd-resolved[541]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
2021-02-03T16:10:39+00:00 vm02 systemd-resolved[541]: message repeated 3 times: [ Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.]
2021-02-03T16:10:39+00:00 vm02 systemd[1]: Reloading.
2021-02-03T16:10:41+00:00 vm02 systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
