I’m having problems adding and commissionig a Proxmox 7.1 VM with MAAS.
I can Power it on, but commissioning then stalls.
Is there some walkthrough to do it properly?
Thank you.
Thank you.
Ok, did commission the VM as soon as I put the machine on the right VLAN, with MAAS’ DHCP.
Question: How can I commission machines (or VMs) on VLANs with external DHCP?
hi, @urbaman ,
Yes, external DHCP can be used, but we need some information?
We need to know the version and build (and packaging format) that you’re running.
If you’re using a snap, execute snap listmaas
at the command line, which will return some lines like this:
maas 3.0.0~beta2-9796-g.2182ab55f 13292 latest/edge canonical✓ -
Please add the output of that command to a comment on this post.
If you’re using a deb, execute apt list maas
at the command line, and enter whatever it returns into a comment to this post, as in the snap example above.
Next, you’ll need to specify which interface you’re using, and generally what command(s) you were attempting.
In addition to the explanation above, you should create a step-by-step list of what you did to reproduce the problem.
If at all possible, capture at least the following logfiles, for the time period surrounding your error situation:
On snap, these files are located as follows:
If you’re using packages, you’ll find the files in these locations:
Ideally, you’d want to put these in a pastebin and link the pastebin location in your comment.
Thanks for this. We’ll need at least some of this additional information in to help answer.
