thats mean if mass not possible connect to booted machine (busybox) because is network disconnected and all next activities is time outed and commissioning result is fail
Machine is still booted to busybox and accessible (via icmp ) to 192.168.70.203
How I permanently changing network from fabric-0 and VLAN1 to fabric-1 and VLAN7 for commissioning?
hey, @sat01, in the very top of your console screenshot, it looks like the boot failed and dropped into initrd, so something wrong must be showing before that.
can you repeat this and capture the whole output leading up to that partially visible line at the top of the console screenshot?
@sat01, this shows me a few things. let me talk to a colleague this afternoon who specializes in this part of the process, and we’ll get back to you. thanks for the screenshots, very helpful!
It looks like the SquashFS root filesystem may be corrupted. I would try deleting the images on each rack controller and reimporting them
# If using the Debian packages
sudo rm -rf /var/lib/maas/boot-resources/*
# If using the Snap
sudo rm -rf /var/snap/maas/current/var/lib/maas/boot-resources/*
# Reimport the images from the rack controller
maas $PROFILE rack-controllers import-boot-images
Can you confirm the machine has networking in the initrd with ifconfig? If you do have networking what happens when you try to manually download the SquashFS or interact with MAAS? The URLs are in the kernel command line.
Fixed. There was problem with server network configuration on BIOS level, were in server was , old config with enabled VLAN only option with set vid number.
