Hello
I am using the latest Maas version (3.4) and I have a problem with a step in the commissioning of my physical machines. It’s the “lldpd” installation step (script 20-maas-01-install-lldpd).
Here’s the error in question:
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package lldpd
I specify that I’m in an disconnected environment from the Internet, that I have a mirror of the official Ubuntu repo in my infrastructure and that it can be reached from my MAAS VM.
In the MAAS settings, I’ve specified to use the latter as a proxy (to allow machines to type in the repo).
The repo works correctly because I’ve set up a VM on the same network and with the same Ubuntu version (20.04) as my physical machines and I’m able to install lldpd correctly.
I can confirm that my machines can type in my repo because in the commissioning logs, I can see GET requests on my repo and I can’t see any errors on them :
2024-01-10T09:41:40+01:00 Serveur2 cloud-init[2798]: Get:6 http://192.168.1.100/repos/archive.ubuntu.com/ubuntu focal/main amd64 Packages [970 kB]
2024-01-10T09:41:40+01:00 Serveur2 cloud-init[2798]: Get:7 http://192.168.1.100/repos/archive.ubuntu.com/ubuntu focal/main Translation-en [506 kB]
2024-01-10T09:41:40+01:00 Serveur2 cloud-init[2798]: Get:8 http://192.168.1.100/repos/archive.ubuntu.com/ubuntu focal/main amd64 c-n-f Metadata [29.5 kB]
thank you in advance for your help
BR
