Commissioning and hardware testing scripts (CLI)
MAAS runs scripts during enlistment, commissioning and testing to collect data about nodes. Both enlistment and commissioning run all builtin commissioning scripts, though enlistment runs only builtins. Commissioning also runs any user-uploaded commissioning scripts by default, unless the user manually provides a list of scripts to run. MAAS uses these commissioning scripts to configure hardware and perform other tasks during commissioning, such as updating the firmware. Similarly, MAAS employs hardware testing scripts to evaluate system hardware and report its status.
Scripts can be selected to run from web UI during commissioning, by testing hardware or from the command line. Note that MAAS only runs built-in commissioning scripts during enlistment. Custom scripts can be run when you explicitly choose to commission a machine. A typical administrator workflow (with machine states), using customised commissioning scripts, can be represented as:
This article explains script metadata, parameter passing, and results-reporting. It also offers examples of both commissioning and hardware testing scripts.
Metadata fields
Metadata fields tell MAAS when to use the script, how it should run, and what information it’s gathering. A script can have the following fields:
  • name: The name of the script.
  • title: Human-friendly descriptive version of the name, used within the web UI.
  • description: Brief outline of what the script does.
  • tags: List of tags associated with the script.
  • type: Either commissioning or testing.
  • timeout: Length of time before MAAS automatically fails and kills execution of the script. The time may be specified in seconds or using the HH:MM:SS format.
  • destructive: True or False, depending on whether the script will overwrite system data. You can’t run destructive tests on a deployed machine.
  • comment: Describes changes made in this revision of the script. A comment can be passed via the API when uploading the script. MAAS doesn’t look at the script metadata for this field.
  • hardware_type: Defines the type of hardware the script configures or tests. If the script returns results, hardware type associate the results with specific hardware. The following types are valid:
    • node: Not associated with any hardware type; this is the default.
    • cpu: Configures or tests the CPUs on the machine.
    • memory: Configures or tests memory on the machine.
    • storage: Configures or tests storage on the machine.
    • network: Configures or tests network on the machine.
  • parallel: Enables scripts to be run in parallel and can be one of the following:
    • disabled: The script will run serially on its own.
    • instance: Runs in parallel only with other instances of the same script.
    • any: Runs in parallel alongside any other scripts with parallel set to any.
  • parameters: What parameters the script accepts.
  • results: What results the script will return.
  • packages: List of packages to be installed or extracted before running the script. Packages must be specified as a dictionary. For example, packages: {apt: stress-ng}, would ask apt to install stress-ng. Package sources can be any of the following:
    • apt: Use the Ubuntu apt repositories as configured by MAAS to install a package.
    • snap: Installs packages using [snap][snapcraft]. May also be a list of dictionaries. The dictionary must define the name of the package to be installed, and optionally, the channel, mode and revision.
    • url: The archive will be downloaded and, if possible, extracted or installed when a Debian package or [snap][snapcraft].
  • for_hardware: Specifies the hardware that must be on the machine for the script to run. May be a single string or list of strings of the following:
    • modalias: Starts with ‘modalias:’ may optionally contain wild cards.
    • PCI ID: Must be in the format of ‘pci:VVVV:PPPP’ where VVVV is the vendor ID, and PPPP is the product ID.
    • USB ID: Must be in the format of ‘usb:VVVV:PPPP’ where VVVV is the vendor ID, and PPPP is the product ID.
    • System Vendor: Starts with ‘system_vendor:’.
    • System Product: Starts with ‘system_product:’.
    • System Version: Starts with ‘system_version:’.
    • Mainboard Vendor: Starts with ‘mainboard_vendor:’.
    • Mainboard Product: Starts with ‘mainboard_product:’.
  • may_reboot: When True, indicates to MAAS that the script may reboot the machine. MAAS will allow up to 20 minutes between heartbeats while running a script with may_reboot set to True.
  • recommission: After all commissioning scripts have finished running rerun
  • script_type: commissioning or test. Indicates whether the script should run during commissioning or hardware testing.
Parameters
Scripts can accept exactly three types of parameters, and only three types: storage, interface, and URL. The values of these parameters are strictly checked against existing disks (storage), working interfaces (interface), and valid URLs (URL) No other types of information can be passed as parameters; they are not configured to pass user-specified data.
The key of the dictionary must be a string, and it’s this string that’s used by the UI and API when users are setting parameter values during commissioning or testing. The value is a dictionary with the following fields:
  • type: Every parameter must contain a type field, which describes what the parameter may accept and its default values. It may be one of the following:
    • storage: Allows the selection of a storage device on the currently-running machine.
    • interface: Allows the selection of an interface on the currently-running machine.
    • url: Allows the the passing of a valid URL.
    • runtime: Specifies how long the script may run. This overrides the timeout value. It is currently only passed as the environment variable RUNTIME.
  • title: The title of the parameter field when displayed in the UI. The following types have the following default values:
    • storage: storage device.
    • interface: interface specifer.
    • url: valid URL.
  • argument-format: Specifies how the argument should be passed to the script. Input is described as {input}. The storage type may also use {name}, {path}, {model} or {serial}. MAAS will look up the values of path, model, and serial based on user selection. For storage, {input} is synonymous with {path}. The interface type may also use {name}, {mac_address}, {product}, or {vendor}. For interface {input} is synonymous with {name}. The following types have the following default values:
    • storage: --storage={path}
    • interface: --interface={name}
    • url: --url={input}
  • default: The default value of the parameter. The following types have the following default values. Setting these to ‘’ or None will override these values:
    • storage: all.
    • interface: all.
  • required: Whether or not user input is required. A value of false sets no default, and no user input will mean no parameters passed to the script. Defaults to true.
  • results: What results the script will return on completion. You can only define this parameter within the embedded YAML of the script. Results may be a list of strings or a dictionary of dictionaries.
#!/usr/bin/env python3
# name: example
# parallel: instance
# parameters:
#   storage: {type: storage}
import argparse
parser.add_argument(
args = parser.parse_args()
#!/bin/bash
# name: example
# parameters:
#   storage:
#     type: storage
#     argument-format: '{model}' '{serial}'
echo "Model: $1"
echo "Serial: $2"
Environment variables
The following environment variables are available when a script runs within the MAAS environment:
  • OUTPUT_STDOUT_PATH: The path to the log of STDOUT from the script.
  • OUTPUT_STDERR_PATH: The path to the log of STDERR from the script.
  • OUTPUT_COMBINED_PATH: The path to the log of the combined STDOUT and STDERR from the script.
  • RESULT_PATH: Path for the script to write a result YAML.
  • DOWNLOAD_PATH: The path where MAAS will download all files.
  • RUNTIME: The amount of time the script has to run in seconds.
  • HAS_STARTED: When ‘True’, MAAS has run the script once before but not to completion. Indicates the machine has rebooted.
Results
The YAML file must represent a dictionary with the following fields:
  • result: The completion status of the script. This status can be passed, failed, degraded, or skipped. If no status is defined, an exit code of 0 indicates a pass while a non-zero value indicates a failure.
  • results: A dictionary of results. The key may map to a results key defined as embedded YAML within the script. The value of each result must be a string or a list of strings.
Optionally, a script may define what results to return in the YAML file in the Metadata fields. The results field should contain a dictionary of dictionaries. The key for each dictionary is a name which is returned by the results YAML. Each dictionary may contain the following fields:
  • title - The title for the result, used in the UI.
  • description - The description of the field used as a tooltip in the UI.
Example degrade detection:
# name: example
# results:
#   memspeed:
#     title: Memory Speed
#     description: Bandwidth speed of memory while performing random read writes
import os
import yaml
memspeed = some_test()
results = {
    'results': {
        'memspeed': memspeed,
if memspeed < 100:
if result_path is not None:
Script examples
Built-in scripts
Commissioning script: Configure HPA
Before the script runs, MAAS will download and install the HP RESTful Interface Tool package from HP. After the script completes, the built-in commissioning scripts will be re-run to capture the new configuration.
#!/bin/bash -ex
# name: hp_c610_x99_ahci
# script_type: commissioning
# tags: configure_hpa
# packages:
#  url: http://downloads.linux.hpe.com/SDR/repo/hprest/pool/non-free/hprest-1.5-26_amd64.deb
# for_hardware: pci:8086:8d06
# recommission: True
echo $output
else:
fi
Commissioning script: Update firmware
Below is a sample script to update the mainboard firmware on an ASUS P8P67 Pro using a vendor-provided tool. The tool will is automatically downloaded and extracted by MAAS. The script reboots the system to complete the update. The system will boot back into the MAAS ephemeral environment to finish commissioning and optionally testing.
Vendor tools which use UEFI boot capsules or need to store resource files on disk while rebooting are not currently supported.
#!/bin/bash -ex
# tags: update_firmware
# packages:
#  url: http://example.com/firmware.tar.gz
# may_reboot: True
reboot
Hardware test script: CPU stress test
As a simple example, here’s a functional Bash script replicating part of the stress-ng script bundled with MAAS:
#!/bin/bash -e
# name: stress-ng-cpu-test
# title: CPU validation
# script_type: test
# hardware_type: cpu
# packages: {apt: stress-ng}
# tags: cpu
# timeout: 00:05:00
    --tz --verify --timeout 2m
Automatic script selection by hardware type
When selecting multiple machines in the web UI, scripts which declare the for_hardware field will only run on machines with matching hardware. To automatically run a script when ‘Update firmware’ or ‘Configure HBA’ is selected, you must tag the script with ‘update_firmware’ or ‘configure_hba’.
Upload procedure
select custom script
Debugging
failed script output
enable SSH within Test Hardware
Access individual scripts and log files
Commissioning and testing script files
  • /tmp/user_data.sh.*/scripts/commissioning/: Commissioning scripts
  • /tmp/user_data.sh.*/scripts/testing/: Hardware testing scripts
Log files
  • /tmp/user_data.sh*/out/
  • /var/log/cloud-init-output.log
  • /var/log/cloud-init.log
Run all scripts manually
    [--no-download] \
    [--no-send] \
    /tmp/user_data.sh.*
Where:
  • --no-download: Optional. Do not download the scripts from MAAS again.
  • --no-send: Optional. Do not send the results to MAAS.
Command line access
For information about managing scripts, applying tags to scripts and seeing script results using the CLI, please see CLI Testing Scripts.
